Old Feb 14, 2013, 08:36 PM
Shark_fighter78 is offline
Find More Posts by Shark_fighter78
Joined Mar 2012
what is a good 800mm ish trainer
I am looking for a good 800mm ish trainer, a slow flyer , some dihedral would be good, something ARF............. what about the hobbyking or FMS super cub? any suggestions?
Shark_fighter78 is offline Find More Posts by Shark_fighter78
Old Feb 14, 2013, 08:45 PM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
the mini cub is that size http://www.horizonhobby.com/products...rtf-HBZ4800#t2
cmdl is online now Find More Posts by cmdl
Old Feb 14, 2013, 08:55 PM
Edmond Y is offline
Find More Posts by Edmond Y
Canada, BC, Port Coquitlam
Joined Nov 2008
If you can take another 100mm more, looks like the new FMS red dragonfly will suit your need. haven't really found any review yet but this plane should be a nice flyer so as any other fms plane.
Edmond
Edmond Y is offline Find More Posts by Edmond Y
Old Feb 14, 2013, 09:09 PM
Joined Mar 2012
Cool, is it 4ch? I'm looking for 4ch, I have a fms t28 , but I wanna take a step away from warbirds
Old Feb 14, 2013, 10:33 PM
Edmond Y is offline
Joined Nov 2008
Yes 4 ch.
Edmond
Old Feb 15, 2013, 08:17 AM
Joined Mar 2012
Can that hz hobby cub be modified to 4ch? Add ailerons ? That would be sweet
Old Feb 15, 2013, 08:26 AM
Rayne is offline
Find More Posts by Rayne
"Landing" in a tree somewhere
Rochester, NY
Joined Sep 2009
The mini super cub isn't as easy to upgrade to 4-channel as it's big brother is. You would have to replace pretty much all the electronics except the motor (which most people usually upgrade to brushless anyway when upgrading). Also the wing would probably be tricky to add ailerons to but I suppose it's doable.
If you don't mind me asking, are you experienced flying the T-28 and if so why are you looking for a trainer? Also why the 800mm size?
Rayne is offline Find More Posts by Rayne
Old Feb 15, 2013, 08:41 AM
Joined Mar 2012
I like the 800mm size , good for the area where I fly, I have 2 flights with the t28 flying was ok, landing was not, resulted in slight damage, nothing too bad, I guess trainer was a bad choice of words I guess a slow flyer would be better, the hz champ is so easy to fly, if I could get a bigger version of something like that, but 4ch, I have some 4ch experience, but mostly on micros, I guess I'm still just a rookie on the parkflyers .... Maybe I should just cowboy up and go fly the t28, if I destroy it, it's not the end of the world, it wasn't too expensive...
Old Feb 15, 2013, 08:43 AM
Joined Mar 2012
Fms super cub looks tempting.... Your thoughts?
Old Feb 15, 2013, 08:59 AM
Rayne is offline
Rochester, NY
Joined Sep 2009
I see, how big is the area you fly?
If you don't mind doing a little building the Hacker Super Decathlon would make a nice transition plane to ailerons. It has a 1000mm wingspan but if built lightweight it should be able to fly relatively slow and easy compared to your t-28. Plus it's made of EPP foam which is fairly flexible and thus resistant to damage. It'd probably cost you around $120 to build not including the transmitter, receiver, batteries and battery charger.
Hacker Super Decathlon ARF (8 min 15 sec)
Despite the video I probably wouldn't count on smooth takeoffs or landings on grass with the included landing gear.
Old Feb 15, 2013, 09:25 AM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
Take a look at the Ares Gamma 370 Pro from Hobby Town. It is a 4 channel brushless model that is very stable in flight. You can purchase the non-aileron wing with it and use it as a 3 channel if you like and install the 4 channel wing when you get comfortable with the plane. The plane retails for $99.99 reveiver ready and the non-aileron wing goes for around 20 bucks.
chucksolo69 is offline Find More Posts by chucksolo69
Old Feb 15, 2013, 11:19 AM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
which micros do you fly?
Old Feb 15, 2013, 11:47 AM
hot glue is offline
Find More Posts by hot glue
Minnesota
Joined Jun 2007
The blackdogrc cherokee was one of my favorite planes. It is 3ch (Aileron, elevator, throttle) although you could add a rudder if you wanted. It is very simple to build and one of the easiest planes to build. One of the toughest ive ever flown. You could land the thing upside down and wouldnt hurt it. http://blackdogrc.com/brody/index.jsp#_EPP_CHEROKEE-KIT
hot glue is offline Find More Posts by hot glue
Old Feb 15, 2013, 12:55 PM
FlyBoy20 is offline
Find More Posts by FlyBoy20
FlyBoy20's Avatar
United Kingdom, Lincs
Joined Aug 2012
Personally, I'd go for a 4 ch. and start as you mean to go on. My Art-Tech Decathalon foamie - a cheapo - was possibly not the best choice for a newbie, but with 50% dual rates and 25% expo and a smooth area for half-throttle take-offs (all of them seem to have quite small wheels), I did finally got two lipos worth of nice flights and landings out of it today - but only after fitting 'Jumbo' wheels.
I just wish I'd known about dual rates and expo when I first started, and maybe I wouldn't have crashed it. Still, it does tick all the 'trainer' boxes. Just make sure you pick a place without any trees until you get the hang of it!
FlyBoy20 is offline Find More Posts by FlyBoy20
Old Feb 16, 2013, 03:11 AM
wnppmy is offline
Find More Posts by wnppmy
Slow Flyer
sterling, Illinois
Joined Feb 2006
Slightly larger just over 900MM is Parkzones New Archer. Takes bouncy landings with no damage due to its light weight . Had exactly same issues my early days with T28, damaging the front nose wheel more than frequently.
Not a cheapie but a nice scale flyer. Share of bounced landings and unscathed last couple dozen flights.
My maiden blew first landing, abit fast on 2nd landing but dead sticking it in. It floats slow speeds.
Abusive first flight, it's a real fun flyer easy to handle
Parkzone Archer Zero Degrees Flight Low Wing RC (2 min 22 sec)
wnppmy is offline Find More Posts by wnppmy
Discussion Looking for a good .10 size trainer dmbaerry 1/2A Planes 77 Mar 20, 2014 09:39 PM
Discussion Whats wrong with my camera?? red-ish image n00ber420 FPV Talk 3 Feb 08, 2013 07:51 PM
Sold High Wing Trainer 60 size - Very good condition $100 LPU Priced Reduced!!! Winterdd Aircraft - Fuel - Airplanes (FS/W) 3 Jan 12, 2013 08:33 PM
Discussion What makes a good trainer? Lukey Trainer Video on video page. TANGOSIERRAROM Foamies (Scratchbuilt) 80 Apr 20, 2011 08:21 AM
Question Whats a good cheap(ish) pattern plane? aerofanatic Sport Planes 9 Sep 01, 2009 10:48 AM
