Old Feb 14, 2013, 06:32 PM
Dave Craig is offline
Find More Posts by Dave Craig
Go ARMY! Beat Navy.
Dave Craig's Avatar
United States, NC, Southern Pines
Joined Dec 2012
Building a GLH II, CG question
Hi, I'm building a GLH II from an old kit and I'm close to finishing (pics later tonight). My question is: should I balance it with a full tank or with an empty tank for better glide when the engine shuts off?
I'm using a 1oz tank and a TD .051 with no throttle. So, it's gonna fly until it's empty, hopefully.
Dave Craig is offline Find More Posts by Dave Craig
Old Feb 14, 2013, 07:13 PM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
Empty! If you do it full, as the fuel burns off it will become tail heavy. A nose heavy plane flies poorly, a tail heavy plane flies once.
John
Rubbernecker is offline Find More Posts by Rubbernecker
Old Feb 14, 2013, 10:55 PM
Go ARMY! Beat Navy.
Dave Craig's Avatar
Joined Dec 2012
Thanks John. I thought as much but I wasn't sure.
Old Feb 15, 2013, 04:07 PM
madsci_guy is online now
Find More Posts by madsci_guy
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
Yup empty. Rubbernecker is exactly correct. Nice GLH, Dave!
madsci_guy is online now Find More Posts by madsci_guy
Old Feb 15, 2013, 04:55 PM
Go ARMY! Beat Navy.
Dave Craig's Avatar
Joined Dec 2012
Thanks, tonight is final sanding and covering. Let's see scotch and monokote, they go together don't they?
Old Feb 15, 2013, 08:13 PM
Joined Nov 2009
Not if you have too much Scotch.
Personally I prefer burbon and dope. Butyrate that is............. & Jim Beam.
Looks good,
John
Old Feb 18, 2013, 12:54 AM
Go ARMY! Beat Navy.
Dave Craig's Avatar
Joined Dec 2012
Ready for maiden flight. The kit called for foam sheeting on top and bottom of fuselage, seemed a little flimsy for my taste so I replaced it with 3/32 balsa sheet. Left the wheels off. The specs called for an all up weight of 20 oz, That would have been with 30 year old radio gear, as it turned out all up is 15oz. with no fuel. TD .051 with a 1oz tank. For an older design this puppy should be pretty quick, I hope.
Old Feb 18, 2013, 11:03 AM
Joined Nov 2009
That looks great! Hope she flys as good. I have an old kit that is partically built that I played with a couple of weeks ago. The die crunched ribs were so bad, I will cut new ones. Good luck.
John
Old Feb 18, 2013, 07:57 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Damn, that looks fast just sitting there.
Top notch!
Curare is offline Find More Posts by Curare
Old Feb 19, 2013, 11:48 AM
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
Looks like you are light enough, that's for sure, but George Kurreck flew his GLH's with foam top and bottom, just fine.
Old Feb 19, 2013, 01:17 PM
Go ARMY! Beat Navy.
Dave Craig's Avatar
Joined Dec 2012
No disrespect to George's original design intended. My motivation was more because the foam in the 25+ year old kit was a little beat up when I got it, plus I am not very good at sanding foam and I only had high temp covering on hand. I was more concerned about any negative effect I might create with the change.Hopefully it will still balance out and fly as well as the original.
Old Feb 20, 2013, 04:58 PM
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
It's your airplane, make it yours
Old Feb 20, 2013, 06:46 PM
Jaspur_x is offline
Find More Posts by Jaspur_x
Somerset Pa
Joined Dec 2009
nice job,she should be sweet in the sky that light
Jaspur_x is offline Find More Posts by Jaspur_x
Old Feb 25, 2013, 04:27 PM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Its all good
Wow
Nice covering job. With the weight reduction you have the diference with balsa instead of foam should be nuttin' worth frettin' 'bout! Makes me wanna break out my GLH from the collection shelf!
ozmo01 is offline Find More Posts by ozmo01
Sold "SOLD"ACE GLH II Kit & ACE Pacer Kit (1/2 A) "SOLD" Yardbee Aircraft - Fuel - Airplanes (FS/W) 6 Nov 24, 2006 12:41 PM
Sold ACE R/C GLH II--Goes Like Heck! lenci1938e Aircraft - Fuel - Airplanes (FS/W) 5 Jul 03, 2006 05:49 PM
FS: Ace R/C GLH II Foam Wing Semi-Kit N925WB Aircraft - Fuel - Airplanes (FS/W) 1 Mar 21, 2005 10:57 AM
Just got a GLH II, need a engine ... skid2964 1/2A Planes 7 Nov 30, 2004 11:28 AM
Ace GLH II electrified Crash-N-Burn High Performance 3 Oct 25, 2002 09:58 PM
