Old Feb 14, 2013, 05:43 PM
acesimmer is online now
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
76" Scale twin 90mm Composite Typhoon Scratch Build
I'm just about to start building my 76" Typhoon. The end result should be a fully composite scale model that will more than likely have twin 90 mm EDF's or larger and be contest capable in both flight and looks. I will also be making the molds for this model for my own reproduction.
My goal is to have a flying prototype ready by Sept 2013 for the Las Vegas Ace in the hole event. I attended my first one in 2012 with my Su35 Flanker and felt like an idiot after seeing the quality of both the builders and the flying. So I came home inspired to build better and more accurate scale birds from molds that I will make.
I have just finished up the prototype of an all composite T-28 that will be test flown tomorrow. I still have to make the molds for the wing skin but no big deal. With that said........ Today I began my preliminary build of the Typhoon. Now I am totally open to input and ideas for all the stages. I have built many prop jobs but this is my first scratch built large EDF/Turbine. I will be needing ideas on power plant once further along and also wing airfoil decision.
I have completed the plans for thwe DA4 version (twin seater) and have cut out temporary station patterns to prove the design flow before committing to expensive materials and the final plug. A couple of pics from today and a link to my T28 thread if interested.
For the next couple of weeks any updates will be slow then it will get real busy real fast.
http://www.rcgroups.com/forums/showthread.php?t=1767143
acesimmer is online now Find More Posts by acesimmer
Old Feb 14, 2013, 10:35 PM
Wilfor is online now
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Subbed , really enjoy your builds
Wilfor is online now Find More Posts by Wilfor
Old Feb 15, 2013, 03:01 AM
meerkat13 is offline
Find More Posts by meerkat13
meerkat13's Avatar
United Kingdom, Birmingham
Joined Jan 2013
Looking forward to this one.... bring on the learning!
meerkat13 is offline Find More Posts by meerkat13
Old Feb 15, 2013, 04:41 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Four's in.
The way you go, it'll be flying by June!
Odysis is offline Find More Posts by Odysis
Old Feb 15, 2013, 07:04 AM
acesimmer's Avatar
Joined Oct 2011
Thanks for the support and interest in my projects. I will choose the power plant and internal ducting once I layup the first fuse from the molds and know the weight. This will be the same for the landing gear which will be servo less. I would like to keep things simple and have a target of two 90mm quality fans that may be all metal with a high blade count for the sound. It would be nice to power them on 6S per side so that I do not get into exotic batteries and ESC's. My goal is to share bats, ESC's and fans across all my models to save cash whenever possible.
My plan is to have a digital cockpit with back lit displays and a couple of Gi Joe pilots or equivalent that will be animated.
I would also like to have the option of thrust vectoring.
I will add afterburner or reheaters as we call them in the tail pipes to simulate flames.
Functioning Dream list.
Chaff dispenser..... Start cutting up tin foil?
Flare dispenser...... Have seen one on the Russian jet?
EMF braking system...... now available
Variable in flight automated slats.... Should not be to difficult
Vortex pressure wave when pulling G loads....... Dream on
Bomb drop... no problem
Functioning speed brake ..... Just need a cheap actuator.
Okay she now weighs in at 50Lbs plus laugh... Okay, so all you brilliant types begin putting in ideas and or designs for the toys.
Old Feb 15, 2013, 07:12 AM
Odysis is offline
Joined May 2007
Vortex - electric smoke. Just a bit, so it disperses quickly! Lots of fine holes in the wing upper surface
Flare - match heads? Lots of phosphourus...
Old Feb 15, 2013, 07:51 AM
raipe is offline
Find More Posts by raipe
raipe's Avatar
Finland
Joined Oct 2008
Signing in to follow.
raipe
raipe is offline Find More Posts by raipe
Old Feb 15, 2013, 08:45 AM
acesimmer's Avatar
Joined Oct 2011
I need a chemical that smokes like hell when exposed to air?
Old Feb 15, 2013, 06:51 PM
Odysis is offline
Joined May 2007
Rubidium or caesium? Finely ground, mixed with something to go smokey.
(I just don't want to be around when you're trying to grind the stuff up!)
Old Feb 15, 2013, 08:10 PM
acesimmer's Avatar
Joined Oct 2011
Where the hell do you buy that?
Old Feb 15, 2013, 08:15 PM
Odysis is offline
Joined May 2007
I doubt anywhere that Homeland Security isn't keeping a close eye on!
Old Feb 15, 2013, 08:19 PM
acesimmer's Avatar
Joined Oct 2011
LOL....Nods as good as a wink!
Old Feb 16, 2013, 04:57 AM
Radar-Guy is offline
Find More Posts by Radar-Guy
EDF Vulcan To The Sky
Radar-Guy's Avatar
Near Koblenz, Germany
Joined Jul 2002
FANtastic, checkin' in!
Here are some pics of real one I took a while ago at ETSI. Maybe you find them helpful, although taken through the fence.
And here an affordable reference book
http://www.sampublications.com/books...n/prod_26.html
Frank
Radar-Guy is offline Find More Posts by Radar-Guy
Old Feb 16, 2013, 10:45 PM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Your T28 build was cool so I will follow along here as well
cbarnes0061 is offline Find More Posts by cbarnes0061
Old Feb 17, 2013, 05:42 AM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
"I would like to keep things simple"
Yeah right! Should be an awesome build just as your T-28 modification is.
Fair warning, I will keep your butt to the fire to get this one done for Vegas!
J
J Morgan is offline Find More Posts by J Morgan
Discussion Looking for a composite lightweight 90mm jet? firehawkzach Electric Ducted Fan Jet Talk 25 Dec 27, 2015 03:32 AM
Build Log Scratch Build Composite UAS System parri0923 UAV - Unmanned Aerial Vehicles 8 Jun 16, 2015 03:33 AM
Discussion Scratch Build RQ-7 Shadow Composite/Balsa parri0923 Balsa Builders 2 Jan 17, 2013 04:17 PM
Sold Stearman PT-17 scratch-build from Barron's Scale Classics Plans 1/6th Scale spitfire1999 Aircraft - Fuel - Airplanes (FS/W) 5 Jan 06, 2013 10:01 PM
Discussion Euro Fighter Typhoon scratch built for 90mm fan Lboogie Electric Ducted Fan Jet Talk 56 Jul 22, 2009 12:59 PM
