Old Feb 14, 2013, 02:40 PM
Zachb657 is offline
Find More Posts by Zachb657
Zachb657's Avatar
United States, PA, Middleburg
Joined Jan 2013
Question
Wingtip staling
How do you prevent wingtip staling on the Spirit 2 meter sailplane? I heard that you can put 1/32 balsa sheeting on the wingtips but i don't know if that will work.
Zachb657 is offline Find More Posts by Zachb657
Old Feb 14, 2013, 02:48 PM
Chris Sutton is offline
Find More Posts by Chris Sutton
Spy's sappin' my thermal!
Chris Sutton's Avatar
United States, WA, Everett
Joined May 2009
The easiest solution: don't fly slow and turn!
In all seriousness, yes, sheeting the wingtips is a solution. You can find more details on that, and lots of other improvements to the Spirit, here: http://www.charlesriverrc.org/articl...spiritmods.htm
Chris Sutton is offline Find More Posts by Chris Sutton
Old Feb 14, 2013, 06:39 PM
LVsoaring is online now
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
Have you checked your washout?
LVsoaring is online now Find More Posts by LVsoaring
Old Feb 14, 2013, 06:57 PM
slopemeno is offline
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
The Charles River site has some great setup tips for the Spirit.
I maidened one for a guy and I thought it flew great. It flew noticeably faster than a Gentle Lady, and retained energy pretty well. I was able to core a thermal up well above the launch height from a high start.
My advice? Fly it faster, and try to be aware of how tight it will circle, and where the point of diminishing returns is.
Fun plane- I wouldn't mind picking a kit version of one.
slopemeno is offline Find More Posts by slopemeno
Old Feb 16, 2013, 12:05 AM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
if its a built up wing , twist the tip at the rear up and shrink the covering , also can sand a blunter radius on the leading edge at the tip ...
Dennis Everett is offline Find More Posts by Dennis Everett
Old Feb 16, 2013, 11:57 AM
superskeg is offline
Find More Posts by superskeg
superskeg's Avatar
Joined Jul 2002
superskeg is offline Find More Posts by superskeg
Old Feb 17, 2013, 05:51 PM
fishfingers is offline
Find More Posts by fishfingers
Murfreesboro
Joined Jun 2009
How do you know just the tip stalled? If flying slowly while turning its very likely the entire inside wing stalled, especially if adequate washout.
Dive test will do nothing to prevent this, and is unrelated to the angle of attack. Flying a little faster will probably go a long way to solving your problem.
fishfingers is offline Find More Posts by fishfingers
Old Feb 19, 2013, 02:05 PM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
The Spirit is well known for havign tip stall issues caused by a combination of covering sag forward of the spar in the tips, too much incidence, and shifty washout.
The Charles River article linked above goes in to each problem and possible soutions in depth.
rdeis is offline Find More Posts by rdeis
Old Feb 19, 2013, 05:07 PM
R2R is offline
R2R
Find More Posts by R2R
R2R
R2R's Avatar
United States, FL, St Johns
Joined Nov 2009
Adding about 1/4" - 3/8" washout did wonders for my Spirit in reducing tipstalls. Keeping the speed up helps too. That bird like to be flown fast in thermal turns and landing approaches.
R2R is offline Find More Posts by R2R
Old Feb 19, 2013, 06:49 PM
Al M is offline
Find More Posts by Al M
Wallingford, Ct
Joined Sep 2001
The sheeting doesn't do much. Washout is much more effective. It needs a lot.
Al M is offline Find More Posts by Al M
Old Feb 19, 2013, 08:03 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
It may help to make the fin a bit larger, too. It's undersized, and that means it gets wiggly when you slow down. But of course, make sure you have some washout first, the same on both sides.
If I had one, I'd probably leave the fin the same size and make the fuselage a bit longer instead. But if I did that, I might have to rebuild the tail surfaces lighter to avoid having to put in too much nose weight. At some point I'd probably give up and build a Chrysalis or something.
lincoln is offline Find More Posts by lincoln
Old Feb 20, 2013, 09:35 AM
rdeis is offline
AMA 353531
rdeis's Avatar
Joined Aug 2003
I had a fair amont of washout and no sheeting on mine and it worked pretty well.
Old Mar 18, 2013, 09:12 PM
bobthefish50 is offline
Find More Posts by bobthefish50
bobthefish50
United States, OR, Salem
Joined Jul 2006
Correcting Tip Stall in a 2M Spirit
Please see The attached thread:
http://www.rcgroups.com/forums/showthread.php?t=559452
Although I didn't mention it in this old exchange, the tip stall was afflicting my 2M Spirit. The correction, which worked immediately, was graciously provided by Mark Drela of the Massachusetts Institute of Technology.
Be well,
Bob
bobthefish50 is offline Find More Posts by bobthefish50
Old Mar 19, 2013, 12:50 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
One other thing to consider is that every turn in a R/E controlled plane begins with a skid. The combination of a high aspect ratio planform and slow speeds, makes skidding turns just about the most risky maneuver performed at low level.
Here's a link to a good article by Frank Reid about Skids on a full scale soaring site.
http://www.glider.org/
Go to: Individual Instruction Course page, then Skids article at bottom of page. Sorry, no direct link.
DT56 is offline Find More Posts by DT56
Old Mar 19, 2013, 04:20 AM
socommk23 is offline
Find More Posts by socommk23
always looking for clouds
socommk23's Avatar
Joined Aug 2010
just fly faster id say.
socommk23 is offline Find More Posts by socommk23
Question Wingtip rudder? JYVAI Flying Wings 8 Feb 08, 2013 08:37 AM
Stale Epoxy Reed Composites Fabrication 5 Mar 31, 2005 11:41 PM
Has anybody had their Lithiums go stale? HankF Batteries and Chargers 2 Jan 12, 2004 08:27 AM
Stale links... Jim Winget Site Chat 0 Oct 17, 2001 12:58 PM
