Old Feb 14, 2013, 11:57 AM
Jeff Kelety is offline
Find More Posts by Jeff Kelety
Port Townsend, WA
Joined Jan 2002
Build Log
Peanut Scale Citabria 12"
Hi all -
This is just a reference (along with a single photo) pointing to the original post of my newly completed Peanut Scale Citabria under Scale Models. Since the little peanut qualifies as both scale and indoor/micro thought I'd touch base in both Forums.
http://www.rcgroups.com/forums/showthread.php?t=1831048
Cheers!
jgk
Jeff Kelety is offline Find More Posts by Jeff Kelety
Old Feb 14, 2013, 12:17 PM
MUTCAKE is online now
Find More Posts by MUTCAKE
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Jeff, That is one of the best looking peanut model, rubber or other wise I have ever seen of the Citabria! Fantastic job. Especially the color tissue combination. It is so nice to see a model expertly done.
MUTCAKE is online now Find More Posts by MUTCAKE
Old Feb 14, 2013, 12:39 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Lovely model..very nicely built.
Oddly I have a 36" span version. Very similar.. except being of Red /White stick/film for 049 power and 36" span
It is surprisingly Aerobatic= Citabria.
Bare is offline Find More Posts by Bare
Old Feb 14, 2013, 12:42 PM
Port Townsend, WA
Joined Jan 2002
Thanks for the kind words, MC. It took a rediculously long time to complete, almost too much effort per gram of output <g>. But it was nonetheless a gratifying return to the building methods of my youth. That I can fly it as indoor RC is just icing on the cake.
Old Feb 14, 2013, 12:45 PM
Port Townsend, WA
Joined Jan 2002
Beautiful work, Bare!! And I have those plans as well. I referenced them prior to starting this project as a possible starting point. In the end, I drew plans directly from a set of 3-views. How does your Citabria fly? Can't tell if you included ailerons.
Old Feb 14, 2013, 01:40 PM
Bare is offline
Canada
Joined Nov 2000
thanx She's an Oldster, built in mid *80's and not flown since mid 90's.
Too pretty to play model baseball with.. So I kept it safe..
If memory serves, it was a surprisingly agile model, Loops and stall turns with ease and light enough so landings needed lots of gliding room.
I'm thinking that yours will do similar.. a fair turn of speed and long approaches
Sans ailerons though (which I would not omit if building it today)
Photo is surprisingly blurry.. sorry.
Simple appearing stick builds DO take an inordinate amount of work. Worthwhile when it's finally over tho :-)
Was thinking of installing a 24 gm 2730 in it .. soon.. it needs using.
Somewhere? I have a PDF of the plan. Typically, it remains elusive when needed.
Old Feb 14, 2013, 01:53 PM
Port Townsend, WA
Joined Jan 2002
"It needs using."
Yup! My longtime flier friends are re-powering and upgrading hardware in our long neglected older birds. Planes that haven't flown in decades are getting a whole new life with dsm, brushless and lipo technology.
Old Feb 15, 2013, 01:50 PM
Port Townsend, WA
Joined Jan 2002
Just a flying update. Was able to get in a brief outdoor flight this morning. I am pleased to report that the bitty Citabria flies wonderfully! More than enough power. Climbed realistically on about half throttle, straight and level. Flew very steady for such a wisp of a thing. The Ember/MinoiVapor power/Rx proved to be a very good combo for peanut scale at @20g. No need to go brushless. Tests were cut short regrettably because I lost rudder function on the brick. No harm to the plane, but forces me to order and replace the brick. I had ! previous signs of malfunction but thought if was transitory. Guess not. Anyway, that's what I know.
Cheers!
Build Log Bud Nosen 1/4 scale Citabria/Decathlon epoxyearl Balsa Builders 213 Aug 18, 2015 01:10 PM
Discussion Citabria Pro at 1/8 scale (48") tim hooper Scale Kit/Scratch Built 31 Jul 24, 2013 07:00 PM
Poll Peanut scale free plans? addictedtoplanes Free Flight 29 Mar 07, 2013 06:47 PM
Build Log Peanut Citabria Jeff Kelety Scale Kit/Scratch Built 21 Feb 20, 2013 12:15 PM
Discussion Symmetrical wing conversion Citabria 1/4 scale HELP ! epoxyearl The Builders Workshop 23 Jan 10, 2013 03:41 PM
