Old Feb 14, 2013, 10:13 AM
Blackrat is offline
Find More Posts by Blackrat
Registered Loon
Blackrat's Avatar
South Africa, WC, Knysna
Joined May 2006
quad prop mold
after playing with my router for a while and trying different stuffs ive decided to have a go at making a MDF mold and pulling a part directly from there
it worked pretty well
http://www.rcgroups.com/forums/showthread.php?t=1823592
next was trying to make some carbon propellers as the plastic ones are too flimsy and the carbon ones are very $$$
this is what i would like to make http://www.rctigermotor.com/show.php?contentid=183
anyways here we go
Blackrat is offline Find More Posts by Blackrat
Old Feb 14, 2013, 10:20 AM
Blackrat is offline
Registered Loon
Blackrat's Avatar
Joined May 2006
the plan was to rough cut the mdf to shape and then vacuum bag the mold to draw the epoxy into the mold, then coat with a tooling coat of epoxy
so i layed the mdf onto a sheet of plastic to create a barrier for when i had to vacuum the epoxy .... unfortunately i machined thru this :S so the barrier was broken and i could only get around .2-.3 vacuum ... oh well so we learn
the next mistake was machining a finish cut on the same height.. i should have lifted the cut .2 mm , the mdf swells once it draws the epoxy in , thats why the molds look so blotchy
the bottom half of the mold was cut on .3 steps and the router marks are clearly visable
the top half was cut on .1 steps and im very happy with the finish ! it looks great but takes quite some time to cut
Old Feb 14, 2013, 10:27 AM
Blackrat is offline
Registered Loon
Blackrat's Avatar
Joined May 2006
oh and a big thanks to http://www.rcgroups.com/forums/member.php?u=183875 Nhadrian for the drawing
Old Feb 14, 2013, 10:53 AM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
That is actually pretty awesome! Any photos of the finished props?
SB7 is offline Find More Posts by SB7
Old Feb 14, 2013, 01:25 PM
Charlvanvuuren is offline
Find More Posts by Charlvanvuuren
Charlvanvuuren's Avatar
South Africa, EC, Jeffreys Bay
Joined Dec 2010
You rock dude you're my Hero Can't wait for you to cut my DLG
Charlvanvuuren is offline Find More Posts by Charlvanvuuren
Old Feb 14, 2013, 01:26 PM
Blackrat is offline
Registered Loon
Blackrat's Avatar
Joined May 2006
DLG ? pfffft once you got a quad on FPV you aint gonna touch fixed wing for a while
Old Feb 14, 2013, 01:27 PM
Blackrat is offline
Registered Loon
Blackrat's Avatar
Joined May 2006
finished props pics coming soon
Old Feb 19, 2013, 05:21 PM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
Have an update on these moulded props?
Sad Sack is offline Find More Posts by Sad Sack
Old Feb 22, 2013, 10:14 AM
Blackrat is offline
Registered Loon
Blackrat's Avatar
Joined May 2006
been so busy with other stuffs ...
anyways here a few pics
next time .. i will pre cut all the tow to the exact size ...
i think ill also take the hole nipple piece out as it makes the layup a pain, and rather just have a little dimple where to drill
Old Feb 22, 2013, 10:16 AM
Blackrat is offline
Registered Loon
Blackrat's Avatar
Joined May 2006
sanded to shape
i cant remember the weight, but it was just over 6 grams each ... they still needed balancing
i did fly just the two on my quad, but i think my quad is a little big heavy for this size prop
Old Feb 25, 2013, 01:38 AM
SB7 is offline
SB7
SB7
Brisbane
Joined Jun 2008
Gotta cut all the fabric to the right size before you close the moulds. You will get a thinner seam line this way. If you havnt removed it already keep the center pin. You dont have to do the whole blade from one peice of cloth. Instead use two peices but bring them as close to the center pin as possible. Usually the prop nut tightened down on the hub will stop the hub twisting so its not necessary to run the cloth right though the hub.
Old Feb 26, 2013, 02:21 AM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Looking good!
I would ditch the pin and drill a hole in the mold and insert a drill guide. Insert a plug into the drill guide during the layup. Once cured, pull the plug, drill the hole in the prop through the guide, then demold the prop. At least this is how I would do it.
wyowindworks is offline Find More Posts by wyowindworks
Old Feb 26, 2013, 10:36 AM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
Originally Posted by wyowindworks View Post
Looking good!
I like your idea Adam if you have a much beefier hub but I'd be concerned with drilling through the continuous fibers on a small prop hub like this. Having the pin already in the tool gives you something to wrap the uni carbon around and if you cut your cloth right (like slowbarless mentions) then you have a pretty easy lay up. You really only need the +/-45 cloth for blade torsion so it can stop short of the center pin. The square corners can get some epoxy/cabosil/milled fibers to minimize trapped air in the corners and prevent voids in the hub.
Troy is offline Find More Posts by Troy
Old Feb 26, 2013, 01:03 PM
Just fly it!
Cody, WY
Joined Nov 2007
that makes sense, Troy
For Sale Chip Hyde 36" carbon fiber e-prop aluminum MOLD punkindrublik Aircraft - Electric - Power Systems (FS/W) 2 Jun 11, 2013 06:26 AM
Question Differences between bi-blade and tri/quad-blade props karikamiya Scratchbuilt Multirotors 18 Feb 18, 2013 01:09 AM
Discussion solidworks prop mold Blackrat CAD/CAM 1 Feb 11, 2013 08:44 AM
Sold X525 V3 Quad with everything including radio, extra props, charger and lipo. Navy Jet Mech Aircraft - Electric - Multirotor (FS/W) 9 Jan 06, 2013 05:13 PM
New Product You thought you had a cool quad...new variable pitch prop quad!! Bigcats30 Multirotor Talk 3 Feb 28, 2012 04:22 PM
