Espritmodel.com Heli Air
Old Feb 14, 2013, 07:38 AM
Things go better with joke
Pleasant Valley Modelport
Joined Sep 2006
New PVC Foam ?
Is this stuff something new ? I saw it being used for ornamental building construction and it was very light. PVC foam. Should be very strong, and I have info on the way from the mgfr, it is called Celtec.
1mm to 6mm thickness.
http://www.eplastics.com/PVC_Foam_Board
Chophop is offline Find More Posts by Chophop
Old Feb 14, 2013, 08:32 AM
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Have you looked at the price of that? Unless they offer some substantial discounts off retail, that's too rich for my blood!
JohnsPop is offline Find More Posts by JohnsPop
Old Feb 14, 2013, 08:58 AM
Envies his own avatar
rockyabq's Avatar
Albuquerque, NM
Joined Apr 2008
Also, I didn't see anything about density (weight), did you?
rockyabq is online now Find More Posts by rockyabq
Old Feb 14, 2013, 01:55 PM
Joined Sep 2006
I think this stuff is more dense. I think coroplast will win.
Email got here :
Standard sheet size measures 48” x 96”. Various weights below
3mm (.125”) = 15 lbs
6mm (.250) = 30 lbs
10mm (.375) = 37 lbs
I think that is .45lbs/sq ft with 3mm. Too much.
Old Feb 15, 2013, 01:00 AM
rockyabq's Avatar
Albuquerque, NM
Joined Apr 2008
Wow! That is heavy!
Old Feb 15, 2013, 04:33 AM
Joined Sep 2006
It isn't what I saw, the stuff was tough and light weight. I'll try to find the stuff they were sculpting door frames from.
Old Feb 16, 2013, 12:33 AM
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
If I was going to *order* foam, I'd probably just go with that Model Plane Foam or whatever it's called that the guys here are selling. Everyone who's tried it seems to really like it. I just always go with whatever I can find locally, whether it's Home Depot or Dollar Tree stuff. It's not like my building skills OR my flying skills will matter much which I build with.
Old Feb 16, 2013, 05:45 AM
Joined Sep 2006
I was looking for some hardware store stock to build 80 inch gassers with. The PVC would be much more suitable.
Old Feb 16, 2013, 12:04 PM
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Gotcha.
Old Feb 16, 2013, 04:28 PM
Joined Sep 2006
Not much good stuff in local stock. Most aircraft building suppliers have it all honed down.
Old Feb 18, 2013, 02:47 PM
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
experience with this stuff
IT IS HEAVY but it can be hot air welded with plastic welding rod to PVC pipe and to itself. BUT IT IS HEAVY. would make a killer material for your flight box!
back in he 80s I used to make a poratble booth for conventions for work. Its tough ,nice colors, comes in 4' x 8' sheets.
ozmo01 is offline Find More Posts by ozmo01
Old Feb 18, 2013, 02:55 PM
Joined Sep 2006
I will ask the construction crew if they are still working, but it is 50 miles away, not sure but I plan to go that way this week. The stuff they had was very light and foamy, but very hard and strong.
New PVC Pedal Launcher Schluter60 Foamies (Kits) 480 Mar 23, 2013 01:48 PM
For Sale serpent foam tires for 1/8 scale onroad NEW in the bag<<< ED3 Cars - Accessories (FS/W) 7 Jan 22, 2013 03:18 AM
Discussion Trying to get the most out of a PVC motor mice1m Rocketry 1 Jan 15, 2013 06:48 PM
Discussion Foam-Tac...beyond foam to foam? Disco Stew Foamies (Scratchbuilt) 9 Jan 11, 2013 08:17 PM
