Old Feb 14, 2013, 12:52 AM
drac is offline
Find More Posts by drac
drac's Avatar
Australia, TAS, Burnie
Joined Jul 2008
Help!
JR DS362 Voltage
Hi Guys,
I am using a JR DS362 servo on throttle, which is currently regulated to 5.6 volts as i am using a Li Ion battery.
I am considering changing to LiFe batteries and would like to know if any one is using this servo on LiFe's unregulated, without any problems.
Thanks for any advice given.
drac is offline Find More Posts by drac
Old Feb 14, 2013, 08:00 AM
Dr Honda is offline
Find More Posts by Dr Honda
Dr Honda's Avatar
Pittsburgh Allegheny, Pennsylvania, United States
Joined May 2004
Micro servo on a Jet's throttle?????
Regardless... it's a 4.8v servo... so NO... DO NOT run it with out a regulator. And honestly... 5.6 v is too much for it too. You should have it between 4.8v and 5v.
You can run the rest of the system with a LiFe battery without a regulator... and just put an inline reg on that servo. OR... put a different servo in it.
Dr Honda is offline Find More Posts by Dr Honda
Help! MX-22 (JR 9303) , PCM10X + Spektrum Module: Voltage Display Error modellbobby Radios 33 Aug 31, 2009 02:03 PM
Discussion JR Receiver and Servo voltages? UncleOOPS Fuel Plane Talk 3 Apr 21, 2006 10:50 PM
Anyone know the voltage levels of JR trainer? Lewis H. Cobb DIY Electronics 4 May 08, 2005 06:38 PM
JR XF622 0 voltage problem hhccakes Radios 1 Aug 28, 2004 08:06 PM
JR Quattro voltage indicator question spark363 Electric Plane Talk 1 May 26, 2002 02:50 PM
