USA
Joined Jan 2002
In my experience, the technique demonstrated by both Lucien and MP Jet both yield excellent results. I fail to see how your technique yields "a far more consistent and reliable connection". If you cannot hold the wire steady enough then by all means, use a helping hands device.
Perhaps you can post of video of your technique? Quote:
Thank you, Ohmic and Mark. Those last few posts have been very informative.
Filling the container with solder, then wicking it out is new to me, but I will add that step to my process and see if that improves the end result. If I may venture off-topic for a moment, that process reminds me of another issue I run into with bullet connectors. The connectors I use have a hole in one side of the connector. When filling the container with molten solder, How do you prevent it from flowing out the hole? Seems I'm always fighting this and ending up with a lot of unwanted solder on the outside of the connector. Bob |
So. Cal.
![]() BTW, tinning and wicking of the connector is not entirely necessary but will minimize the amount of gold in the resultant solder connection. Excessive gold causes brittle solder joints that can fatigue and fracture over time so it's best to remove it. This process is mandatory for high reliability military and space applications. For our hobby, it's obviously optional. Mark |
So. Cal.
As the instructors had a tendency to hover over us while being certified, anyone caught making solder joints via the MPJet technique would be remedial trained and would be sent packing if caught a second time. This would have greatly displeased my leadership. ![]() I will try to shoot some photos or make a video sometime. Mark |
USA
Joined Jan 2002
So. Cal.
Not a video but below is a macro image of a 12AWG wire / 4mm connector solder connection that I made earlier this morning with the above described technique.
Will have to dig out a tripod and figure out how to get a close up video. It's supposed to hit 80 degrees here today so my indoor activities are going to be limited... ![]() Mark |
| Thread Tools | |
| Question Best way to connect motors and ESC's: Use solder or bullet connectors? | 2MacGyver | Multirotor Talk | 13 | Jan 06, 2013 11:03 AM |
| Discussion Which soldering station will be enough to solder batteries esc & motor connectors? | ath512 | The Builders Workshop | 15 | Nov 04, 2009 03:17 PM |
| soldering battery connectors | _Lunchbox_ | Batteries and Chargers | 19 | Aug 25, 2005 11:24 AM |
| Soldering connectors on batteries | dacaur | Micro Helis | 3 | Jun 22, 2005 11:43 PM |
