Old Feb 14, 2013, 11:58 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
I've been using this easy clean stuff:
http://www.superiorflux.com/superior...ring_flux.html
grimbeaver is offline Find More Posts by grimbeaver
Old Feb 14, 2013, 12:50 PM
Muddie is offline
Find More Posts by Muddie
A Snickering Hound
Muddie's Avatar
United States, SC, Myrtle Beach
Joined Jan 2012
Thanks so much to everyone for all the great information. I can see a couple of mistakes I've been making right off the bat, the biggest one probably using a much smaller tip than the job requires.
Soldering is such a key skill for this hobby and these suggestions will certainly help take my mine to the next level.
Thanks again!
Muddie is offline Find More Posts by Muddie
Old Feb 14, 2013, 01:37 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Hey grim,
Just a heads-up that you need to be extremely careful with how you use Superior No. 30 as it's an organic acid flux and will make a mess of things if it's not 100% removed post-soldering. It's great for circuit cards and such that are then thoroughly cleaned in a hot aqueous solution. However, No. 30 is horrible for soldering stranded wire as it has a tendency to capillary up the strands under the insulation and is then next to impossible to remove. As it's an organic acid, it will then continue to eat through the wire under the insulation adjacent the solder joint and the wire will eventually break. I have witnessed precisely this on several occasions. The ugliest part is that the degradation cannot be seen since it's under the insulation and takes several years before it manifests a failure.
The best flux for soldering stranded wire is RMA rosin flux as it is plenty active and is still safe for stranded wire. I prefer to use rosin cored solder wire and avoid external flux application altogether. My favorite solder of all time is Kester #44. It's my gold standard.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Feb 14, 2013, 03:11 PM
United States, MN
Joined Feb 2011
I knew someone would probably chime in and tell me my choice of flux was wrong. I don't use it much since most of my battery connections are now all APPs. On the other hand if it takes several years to manifest as a failure that means the airplane has to last that long first
The other challenge I've had is finding places to buy electronics grade flux. All you'll find at your local hardware store is stuff for pipe and says right on it not for electronic use.
Mark is the Kester #44 you use the 60/40 or the 63/37?
Old Feb 14, 2013, 03:58 PM
So. Cal.
I always buy SN63 eutectic but would have no issue with SN60 and view them as interchangeable. Melting point is very slightly higher with SN60 but one would be hard-pressed to notice any difference when soldering.
BTW, eBay and Radio Shack are good places to buy flux if you cannot find rosin based flux at a local supplier.
Mark
Old Feb 14, 2013, 04:18 PM
United States, MN
Joined Feb 2011
Last time I went into a RadioShack most of the electronics stuff had all but disappeared so I never really think to go there. Though those kinds of things might be making a comeback since they started carrying microcontroller stuff.
Old Feb 14, 2013, 04:29 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
The several by my house/drive to work all carry both that I linked above and several quantities (oz sizes) at that.
They seem to never die for some reason.
Rick
rampman is offline Find More Posts by rampman
Old Feb 14, 2013, 05:24 PM
So. Cal.
I've used the Radio Shack solder and agree that it's really good stuff. As I don't particularly like driving all around LA, I typically buy most of my supplies online. My last 1lb. roll of .031" Kester 44 came from eBay and was quite a bit cheaper than my local Frys Electronics for the exact same stuff. I've also used Almit KR-19 and Alpha Reliacore solders in the past but Kester 44 is my favorite.
Mark
Old Feb 14, 2013, 05:27 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
I use Kester 63/37 myself. I like it better than 60/40.
I get my soldering supplies from here:
http://www.hmcelectronics.com/
For small quantities you may want to try here (I haven't ordered from them myself):
http://store.curiousinventor.com/soldering.html
Ohmic is offline Find More Posts by Ohmic
Old Feb 14, 2013, 11:49 PM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I use :
Standard 1/4" chisel tip 40W iron
Rosin core solder - from local DIY shop on a reel
No trouble - as others say - clean tip, touch of solder on tip to help transfer heat to wire ... feed in solder to point where iron and wire meet ...
I prefer wire to be at a 45 degree angle UP ... so solder flows into the strands .... I don't like vertical as then solder tends to flow too quickly into strands and into area covered by insulation ... horizontal means I have to feed solder along it and can end up with the 'drip' lump !
Nigel
solentlife is online now Find More Posts by solentlife
Old Feb 15, 2013, 01:34 AM
BVH is online now
BVH
Find More Posts by BVH
BVH
BVH's Avatar
United States, CA, Pismo Beach
Joined Dec 2006
If you get into 8 AWG or larger, try buying and using one of the micro butane torches available at the big box stores. You can really dial down the tiny flame and do an excellent job of soldering the larger wires without burning the insulation once you get the hang of it. And of course, as many have said, use plenty of liquid flux on the fitting and wire. I use a needle tip bottle to apply liquid flux on the fitting and wire, then tin both pieces then do the final soldering.
BVH is online now Find More Posts by BVH
Old Feb 15, 2013, 02:05 AM
still4given is offline
Find More Posts by still4given
Sky Pilot
still4given's Avatar
Victorville, CA
Joined Jun 2006
This video is has some pretty good soldering techniques.
How to Solder Bullet Connectors By Innov8tive Designs (13 min 30 sec)
still4given is offline Find More Posts by still4given
Old Feb 15, 2013, 02:02 PM
stvinvegas is offline
Find More Posts by stvinvegas
stvinvegas's Avatar
United States, NV, Las Vegas
Joined Dec 2006
Forget Soldering, I got so sick of my stupid deans, melting and failing. Cost me a couple of planes.
I only use Powerpole connectors... Went to those and never looked back..
I will never solder again!!!!
Installing 45A Anderson Powerpole connectors for RC applications (4 min 49 sec)
www.powerwerx.com/
stvinvegas is offline Find More Posts by stvinvegas
Old Feb 15, 2013, 03:29 PM
Sky Pilot
Victorville, CA
Joined Jun 2006
That's all well and good but the largest I see is 45A. Anyone running 100A with these?
Old Feb 15, 2013, 03:34 PM
Ohmic is offline
USA
Joined Jan 2002
Powerpole connectors are available in sizes up to 180A. They are quite large though.
Question Best way to connect motors and ESC's: Use solder or bullet connectors? 2MacGyver Multirotor Talk 27 Jul 01, 2015 05:31 PM
Discussion Which soldering station will be enough to solder batteries esc & motor connectors? ath512 The Builders Workshop 17 May 19, 2015 09:34 AM
soldering battery connectors _Lunchbox_ Batteries and Chargers 19 Aug 25, 2005 12:24 PM
Soldering connectors on batteries dacaur Micro Helis 3 Jun 23, 2005 12:43 AM
