A 60 watt iron is a bit bigger, carries more heat.
http://www.amazon.com/60-Watts-Solde.../dp/B0006NGZK0 http://www.hobbywarehouse.com/910-90...FQThQgodM3kAuw http://compare.ebay.com/like/1109800...Types&var=sbar http://www.ebay.com/itm/60-Watt-Sold...6777%26ps%3D54 Make sure you aren't using lead-free solder. |
Barbados
Joined Jan 2011
http://www.rcgroups.com/forums/showthread.php?t=1722684
Get one of these and a chisle tip 40/60 solder and flux from Flea bay worth every penny,in this hobby soldering is a must.HK finally came through lol. |
Latest blog entry: My 87” 3DHS Extra 300 SHP w/DA-60
For our hobby, just use the Radio Shack 60/40 rosen core lead based solder. We do not need the silver bearing type solder for 99% of our use in RC and it needs more heat than the lead based stuff.
IMO, buy this: http://www.radioshack.com/product/in...ductId=2049774 and this: http://www.radioshack.com/product/in...ductId=2062713 though you can buy shorter lengths than this. Trust me, larger diameter is better as it dispenses more flux per solder joint. More flux = better flow, better solder joint (in our use) and better cleaning. Rick |
Latest blog entry: mean well S-210-12 power supply
See my link above.
Rosen flux. Do NOT use no-clean. Rick |
| Thread Tools | |
| Question Best way to connect motors and ESC's: Use solder or bullet connectors? | 2MacGyver | Multirotor Talk | 13 | Jan 06, 2013 11:03 AM |
| Discussion Which soldering station will be enough to solder batteries esc & motor connectors? | ath512 | The Builders Workshop | 15 | Nov 04, 2009 03:17 PM |
| soldering battery connectors | _Lunchbox_ | Batteries and Chargers | 19 | Aug 25, 2005 11:24 AM |
| Soldering connectors on batteries | dacaur | Micro Helis | 3 | Jun 22, 2005 11:43 PM |
