Old Feb 13, 2013, 09:23 PM
SuperBarlow is offline
Find More Posts by SuperBarlow
No place like cloud base......
SuperBarlow's Avatar
United States, VT
Joined Aug 2012
Mini-HowTo
Parkzone/Hobbyzone 1s charger double charge port
So for all you who have a PZ/HZ charger and want to charge multiple batteries, but don't want to buy a new charger, this thread is for you! I figured out a very simple way to do it, but you have to have a soldering iron. I'm sure somebody has a better method, and if you do, please share it!
I'll take pictures and start my how-to tomorrow.
SuperBarlow is offline Find More Posts by SuperBarlow
Old Feb 14, 2013, 07:09 PM
United States, VT
Joined Aug 2012
So I finally got around to getting this together! Follow in picture order.
1.) Here's your basic charger. Take the batteries out and flip it over.
2.) Take the pads off the base, and put them somewhere you can find them later.
3.) Open up the charger, and cut the sticker that hods it together. For all that bulk there really isn't much inside.
4.) Wedge out the glue and take out the screws from the charger port and LED.
5.) The led is going to go in the screw hole, so drill or scrape out the plastic till the led fits snugly. also cut two holes for your female charger connectors.
6.) Find a second female charger plug.
7.) Put the plugs in the holes you cut out, and solder the wires to the second plug in parallel to the first, and glue the LED and plugs in.
7.5.) There is a potentiometer on the circuitry. Break the glue and turn it all the way to the right.
8.) Make a stand and admire your handywork!
Warning! Unless you want the life span of your batteries to decrease, only charge two at a time.
Old Feb 14, 2013, 07:10 PM
United States, VT
Joined Aug 2012
I have been using data found online to know the charge rate with the dial all the way to the right. I don't know what mine is. If the thing explodes for some odd reason, I will feel sorry for you, but take no blame.
If someone could test it, that would be great.
Old Feb 14, 2013, 09:45 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Nice mod, SB!
On the PZ version of this charger that i have, wIth the pot turned all the way CW, the charge current is ~350mA, and ~180mA with it turned all the way CCW.
With this mod, I guess you can now charge 2 lipo's in the time it would have taken to charge just one, or charge just 1 lipo in about half the time. Cool!
KC is offline Find More Posts by KC
Old Feb 15, 2013, 12:02 PM
United States, VT
Joined Aug 2012
Great! those look just like the specs that I saw. Thanks!
Sold Turnigy 4-port charger/balancer 1S-6S XtremeWingRC Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 09, 2013 01:19 AM
For Sale Modified celectra 4 port charger & celectra variable 1s charger specgie Aircraft - Electric - Batteries & Chargers (FS/W) 4 Feb 05, 2013 11:42 AM
Sold Celectra 4 port with 1s variable rate charger and wall adapter 3d astronaut Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 30, 2013 03:31 PM
Sold Eflight 4 port 1s ac charger X 2 Johnnymeg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jan 13, 2013 06:18 PM
For Sale Hobbyzone Parkzone eFlite 1s charger for ultra micros motoguy1 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Dec 10, 2012 02:25 PM
