Old Feb 13, 2013, 09:07 PM
Lozki is offline
Find More Posts by Lozki
chopper chopper chopper!!!
Lozki's Avatar
United States, CA, Shasta Lake
Joined Sep 2012
Question
Changing up the pitch
Hey everybody I have a question, I fly blade 300x and I use a DX 6I I use a setting that the provided for me in the manual but I want to change the pitch so I can get that snap when doing 3d the manual shows
Norm, L 30% 2,40%3,50%4,75%H100%
Stunt L 0% 2,25%3,50%4,75%H100%
Hold L 0% 2,25%3,50%4,75%H100%
can s do I need to switch anything in my pitch or kinda give me an idea what to do
any help is much appreciated thanks ... Lozki
Lozki is offline Find More Posts by Lozki
Latest blog entry: My Helis
Old Feb 17, 2013, 09:01 AM
freperry is offline
Find More Posts by freperry
freperry's Avatar
United States, VA, Virginia Beach
Joined Feb 2013
Your radio settings for the pitch curve are fine, don't change them!
Here a few things to check.
- check your control behavior setting (AR7200BX parameter menue step B)
- check your collective pitch range step (AR7200BX step K)
- what headspeed are you running
freperry is offline Find More Posts by freperry
Old Feb 17, 2013, 10:11 AM
Lozki is offline
Lozki's Avatar
Joined Sep 2012
not to sure about the head speed im useing all stock i just got my new motor stock is 4400v
kv the new one is 4800kv my BX settingd seem to be set well not wrong with that...as far as i can think
Old Feb 17, 2013, 10:45 AM
freperry is offline
freperry's Avatar
Joined Feb 2013
What't the setting for the control behavior on the AR7200BX right now?
I guess it's set to sport. Switch to 'pro' or 'extreme' for faster cyclic control.
I actually prefer 'transmitter mode' meaning I change the cyclic control via D/R and or expo.
Give it a try!
Old Feb 17, 2013, 11:09 AM
Lozki is offline
Lozki's Avatar
Joined Sep 2012
Im thinking that the BX is set up on sport mode..but your saying change up my D/R and expo a lil huh right now their all set at..
100% INH
100%INH
100%INH
then idle up is ...
85%INH
85%INH
85% INH
Old Feb 17, 2013, 01:52 PM
freperry is offline
freperry's Avatar
Joined Feb 2013
Not while you are in sport mode!!! Only in transmitter mode since D/R ann expo is already programmed in the sport/pro/extreme.
If you use transmitter mode you could programm expo and D/R the way you like it!
Old Feb 17, 2013, 01:59 PM
freperry is offline
freperry's Avatar
Joined Feb 2013
Maybe start with
elevator expo + 30%
aileron expo +30%
ruddr expo +20%
D/R elevator 80%
D/R aileron 80%
D/R rudder 100%
If it's to tame arround midstick reduce expo.
If you the heli quicker raise D/R accordingly.
With transmitter mode you can set it up the way you like and not how it's preset!
Old Feb 17, 2013, 02:07 PM
Lozki is offline
Lozki's Avatar
Joined Sep 2012
ok ill give that a try and she how she does..thanks
Discussion V911 pitch setting is messed up rkovvur Micro Helis 3 Feb 07, 2013 03:20 PM
Discussion HELP Right pitch causes motors to spin up loosescrews Multirotor Talk 1 Jan 24, 2013 04:15 AM
Discussion why doesn't pitch change with radio change rmasu Mini Helis 8 Jun 24, 2006 01:02 PM
Causes of pitch-up in fixed-pitch heli in forward flight? slowpoke Power Systems 2 May 01, 2002 08:32 AM
Pitch change with diameter change? Frank B Power Systems 9 Mar 12, 2002 04:33 AM
