Nope, snipers are known to have poor layup qty: gelcoat is part of structural strenght so very heavy and brittle and cracks easely. wings have weak main spar.
I don't want to bring you down but the availability if good qty epoxy resin planes in this class is close to zero. Only foamies,polyesther planes (Velocity-rc is polyesther as well) or hybrids (cloth covered foam planes at Jepe.org) and many chinese OEM products ready to bin. For this reason I haven't bought a 70mm arf edf jet for over a decade but I build them from plans or kits. The next best plane close tot he Sniper would be the RBC F100. The build is very straightforward and instead of strip planking one can use large sheets of balsa to get a nice surface. and you can add a rudder if you want. However, if there are good epoxy resin kits available I'd like to be noted on that. They all seem to have dissapeared because the masses want cheap only. br, Erik |
Joined Jun 2012
Thanks, again for the feedback! I will check out the sites you mentioned. If in the future I climbed to a 90mm size, are decent quality ARFs suddenly available? Best Regards, Andy |
I think the El Bandito might be still the best epoxy resin kit around fo 90mm. Sniper90 is a dog too. Aeronaut Panther is still the best alround everyday jet not needing bunghee or retracts. Eliminator not available anymore due to lack of interest.
Salamander: http://www.air-tech.info/html/modell...in/modell.html Grumania jets has nice stock too. Good qty composite jets starts from 100mm and up. |
What about a Sapac L-39 or Viper? Sapac is out of business, but Graves RC still has a number of their ARF kits for sale. Might be worth a look.
Josh |
Latest blog entry: VIDEO: Real Helicopter Rescues Hangar 9...
I had a Schreiner Viperjet which was a good qty product but not cheap at all and very hard to get. after seeing a Sapac Viperjet which is very similar to the schreiner version I was pretty well shocked the layup was very thick (fuse not flexible at all) and felt very heavy. Tough it performed quite well I personally made up my mind not to spend my money on this brand.
The velocity-rc layup appeared to be more refined as Sapac. Very remarkable new brands last only for a few years. |
| Thread Tools | |
| Discussion Fiberglass Twin EDF 70mm Jet Project | PONDS | Composites Fabrication | 14 | Jan 22, 2012 04:43 AM |
| New Product OKModel A4 Skyhawk 70mm EDF w/ fiberglass fuselage | -PaX- | Electric Ducted Fan Jet Talk | 50 | Oct 03, 2011 12:00 AM |
| Discussion New jet 4/12/11: AVRO CF105 Arrow, Fiberglass 70mm ARF | texbird | Electric Ducted Fan Jet Talk | 32 | Aug 13, 2011 10:20 AM |
| Discussion HK F-22 Raptor Fiberglass EDF Jet 70mm x 2 | Zeke0504 | Foamy EDFs | 12 | Apr 24, 2011 05:52 AM |
| New Product E-flite Hawk 70mm Class EDF w/ Fiberglass Fuselage | Bajora | Electric Ducted Fan Jet Talk | 263 | Feb 21, 2010 04:54 AM |
