Old Feb 13, 2013, 06:33 PM
Charlescd is offline
Find More Posts by Charlescd
RC Paraglider / Sailplanes
Charlescd's Avatar
Canada, QC, st-jean-sur-richelieu
Joined May 2010
Question
Ubec for ignition on G62
Hi folks,
I'm planning on installing a 5v bec with a 2s lipo for the ignition on a G62. Is there a minimum amperage is or a regular 5v, 5amp bec enough?
thanks
Charlescd is offline Find More Posts by Charlescd
Old Feb 13, 2013, 07:42 PM
ace4rc is offline
Find More Posts by ace4rc
ace4rc's Avatar
tampa,florida
Joined Nov 2007
For a ignition it's all about volts, 5-6 is good.
ace4rc is offline Find More Posts by ace4rc
Old Feb 14, 2013, 11:31 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Most CDI units draw less than 1 ampere. But there are a few odd ball ones that consume more though. So if the voltage regulator can handle 5 amps, that is perfectly fine. It doesn't hurt to have some extra current handling capability for those hot summer days where the airplane is exposed to the sunlight for extended periods of time at the flying field. Albeit in Canada it wouldn't be as hot in the summer as it is down here in Texas.
earlwb is offline Find More Posts by earlwb
Old Feb 14, 2013, 11:39 AM
Charlescd's Avatar
Joined May 2010
At peak in the summer in Quebec, 90f is a real scorcher for us. Summer is around 75-90.
I found this while browsing Hobbyking and may just go for it. I'm new to larger models so I need a little bit of guidance for 2 models concerning power to the servos.
Direct question: is this item enough for the Amr trainer 50 (g62) and the my 5 meter sailplane?
I will be powering the trainer 50 and the sailplane with 2 x 2s 2000mah batteries. To save weight on the Fashionista, I will be using a smaller 6s battery for the motor.
Trainer 50: 7 servos: 2 aileron,2flaps,1 rudder, 1 elevator, 1 motor
Fashionista: 6 sevos, 2 airbrakes: 2 aileron, 2flaps, 1 rudder, 1 elevator, 2 electric airbrakes.
here is the hobbyking link:
http://www.hobbyking.com/hobbyking/s...C_Yellow_.html
Turnigy introduce the Min Power Distributor Ubec suited to 30cc plus gas powered models.
This unit has great features, which include: Dual battery input, 5v isolated linear RX BEC, 30 Amp voltage adjustable Ubec on all output channels, 8 channel RX input with dual outputs on each channel - simplifying dual servo control surfaces.
Great inclusions are the independent 5V linear regulator providing a separate power source for the receiver, optically isolated CDI power & in built remote ignition kill. Receiver, Servo & CDI power sources are completely isolated from each other.
This is the first Power Distributor system to securely nest the receiver within the power distribution 'block' thereby shortening cable runs, adding protection to your all important receiver & speeding set up time.
Features:
• 5v Linear RX BEC
• 30 Amp Servo UBEC
• Users adjustable UBEC voltage
• 8 (+1 CDI cut) input channels
• 16 output channels
• 5 Status check LEDs
• Padded receiver tray & Secure mounting
• CDI isolated power
• CDI remote ignition control (remote cut)
• CDI power status indicator light
• CDI power output terminal
• CDI voltage monitor LED
Optional: Input/output voltage display with external power switch
Spec:
Input Channels: 8 (+1 CDI Cut)
Output Channels: 16
Input voltage: 7-13V
Servo UBEC Current: 30A (40Amp Burst)
Output voltage: 4.8-9.7V (user adjustable; Default is 5.2V)
RX power: 5v linear bec
Working temperature: -20 to 85 degrees c
Weight: 80g
Dimensions: 116mm x 88mm x 13mm
Sold zenoah g62 EZ link carb adapter/g62 bendix1 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 07, 2013 11:00 PM
For Sale Zenoah G62 with electronic ignition NEW johncpen Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 17, 2013 12:57 PM
For Sale Reichmuth ignition for g62 bildnfli Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 30, 2010 11:04 AM
Sold Anyone looking for a RALPH CUNNINGHAM Zenoah G62 w electronic ignition? flyinjrc74 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Sep 11, 2010 10:02 PM
Wanted Ignition for G62 fabmaster911 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jan 07, 2009 09:43 PM
