Old Feb 13, 2013, 05:37 PM
flysohigh is offline
Find More Posts by flysohigh
flysohigh's Avatar
Miami Fl
Joined Feb 2011
losi ten scte gearing / mamba max pro on 2s
Hi i am planning on gearing my truck but just trying to get the concept on hiw motor temps change when gearing the motor. I hear that if you increase the pinion gear tooth count it will make more torque anD opposite for the spur gear if you increase the teeth it will decrease torque? Hiw exactly foes this work i want a general good top end and good torque? Anyone using a 48t spur instead of the stock 40t? Whats a good gearing to start with for track
flysohigh is offline Find More Posts by flysohigh
Old Feb 13, 2013, 07:57 PM
mredzadventure is offline
Find More Posts by mredzadventure
Kowalski !.....Options
mredzadventure's Avatar
USA, MI, Hastings
Joined Jan 2007
Gearing will depend on the track. You need to find out the final gear ratio It should be in the manual. Here is a little thing that might help.http://gearing.rcgearhead.com/Gearing/Browse There is always a trade off when it comes to gearing. Top speed or acceleration. You can tune that truck with different fluids in the diffs for traction. You have three diffs in that car you have to find the right gear combo that will work. Experimentation and lots of notes will help. Tire sizes will affect the final gear ratio. If your running the car to hard the temps will rise make small changes. The final drive ratio that has the speed your looking for and a cool motor is what your striving for.
mredzadventure is offline Find More Posts by mredzadventure
Old Feb 13, 2013, 08:07 PM
flysohigh's Avatar
Miami Fl
Joined Feb 2011
I am running 7r 5c 3f diff fluid i had the stock motor that came with the truck and speed controller but I have sold it so I am now looking to get another motor but don't want to rush I want to make sure I get the right motor but I want somebody who is already have had the motor and knows a good gear ratio for all around good top speed and torque
Old Feb 13, 2013, 08:15 PM
USA, MI, Hastings
Joined Jan 2007
Check at the track That will be the best solution. See what the fast guy's are running and ask them.
Old Feb 14, 2013, 01:35 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Triple posted:
Originally Posted by SoloProFan View Post
Short answer:
- lower pinion gear teeth count means more torque/acceleration, less top speed, less motor heat
(Increasing spur gear count has the same effect)
- higher pinion gear teeth count means less torque/acceleration, more top speed, more motor heat
(decreasing spur gear count has the same effect)
SoloProFan is online now Find More Posts by SoloProFan
Old Feb 14, 2013, 11:54 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Holy multiple threads... why start three threads for the same thing? You now have two with good info spread apart instead of in one concise place.
As I said in the other thread, you've swapped in a slightly lower kv motor with more torque than the stock motor so run it on the stock size pinion/spur (get the stock tooth count in a 5mm bore for the motor) to see how it runs.
wparsons is offline Find More Posts by wparsons
For Sale Losi Ten SCTE weezypain Cars - Trucks and Parts (FS/W) 13 Jul 10, 2013 04:10 PM
Discussion short course racing/mamba max pro gearing question flysohigh Off-road Cars 6 Feb 14, 2013 11:50 AM
Sold new tekin pro4 motor and mamba max pro esc for scte slash 4x4 sc10 all - boss777 Cars - Trucks and Parts (FS/W) 0 Nov 10, 2012 01:26 PM
Sold new tekin pro4 motor and mamba max pro esc for scte slash 4x4 sc10 all - boss777 Cars - Cars and Parts (FS/W) 0 Nov 10, 2012 01:25 PM
For Sale losi scte artr and losi ten t brushless converted GP racer Cars - Trucks and Parts (FS/W) 1 Dec 09, 2011 07:35 PM
