Old Feb 13, 2013, 03:19 PM
Merk is offline
Find More Posts by Merk
Merk's Avatar
United States, SC, Clover
Joined Sep 2004
CNC Molds and Cores for DLG's
I have had my CNC for about 1 yr now and just now getting the time to do some real work on it.
So I have cut some Corian Molds for a DLG. They turned out great. Now I have been trying to cut the cores. Just about got it. on the first attempt.
But I ran into a problem I have a vacuum table to hold the core down so I could cut the second side.
Russ
Merk is offline Find More Posts by Merk
Old Feb 13, 2013, 06:15 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
An air leak is an easy way to "turn it down".
Roto Rob is offline Find More Posts by Roto Rob
Old Feb 13, 2013, 06:34 PM
Merk is offline
Merk's Avatar
Joined Sep 2004
Thanks I will have work on that.
Russ
Old Feb 13, 2013, 07:48 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
A sliding or pivoting gate over a hole works good. Or a valve on the hose open to the air.
Old Feb 13, 2013, 08:06 PM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
have also seen where someone uses a rubber 1/16th flap on the inside of the bucket, then the flap just opens what it needs to before caving in the bucket similar to a diaphragm.
doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Feb 13, 2013, 08:08 PM
Glendale,Az.
is your other vacuum hold down for the initial block of foam just a flat rectangle on the inside?
Nice work,
doug
Old Feb 14, 2013, 10:32 AM
Merk is offline
Merk's Avatar
Joined Sep 2004
Doug,
Yes. the holdown is just a flat rectangle.
Do you think I should make a new Vacuum table with a bull nose bit?
Russ
Old Feb 14, 2013, 01:31 PM
Glendale,Az.
More info on your vacuum table with bullbose bit?
Old Apr 30, 2013, 03:31 AM
eghelman is offline
Find More Posts by eghelman
Canada, ON, Toronto
Joined Oct 2009
Russ,
What are your speeds and feeds to cut Corian? Is the material too abrasive on the cutters? I have a home made MDF CNC router and I am not sure if it can handle tough materials. I am making molds in basswood covered with resin wood finish and although is not a mirror finish it looks fine to me.
Eduardo
eghelman is offline Find More Posts by eghelman
Old May 01, 2013, 06:57 AM
Merk is offline
Merk's Avatar
Joined Sep 2004
Eduardo,
Corian is very easy to cut. Use a carbide bit and it will cut very nicely. I have been turned on to these bits. http://www.lakeshorecarbide.com/corn...sendmills.aspx and they work great.(I use the 60 deg radius bits.)
As of feed rates and RPM’s I would have to look at my program. (Mach3)
I just look at the chips and listen to the chatter of the bit and adjust from there.
But I really like these bits they work well.
I have cut some more molds I will have to post some pics soon.
Russ
Old May 01, 2013, 07:48 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Totally depends on the machine, the bit, and what you're trying to do.
Last night I cut some finish passes with 1/4 ball mill in a Joe's 4x4 with a 3 1/4hp Hitachi router at 10000 rpm and 60ipm. That seems to be a good finish speed for my machine in Corian.
Roughing is typically 1/2 ballmill or 1/4 ballmill with deeper cuts, larger steps, and around 40ipm. My machine is limited by the lack of cutting power in my router, not by the machine's mechanics.
Looking forward to the pictures Russ. I just did another fuse mold / canopy mold and after four years I feel like I'm starting to get pretty good at this stuff. Scary how much I still don't know though.
tom43004 is offline Find More Posts by tom43004
Old May 02, 2013, 09:10 PM
eghelman is offline
Canada, ON, Toronto
Joined Oct 2009
I understand... I use an edge trimmer at 27000 rpm and 1/4" end mill for roughing. I think I get good results for the set up I have. As I said, its a MDF machine with Nema 23 steppers. Nothing fancy but it does the job. Attached, a picture of the CNC machine and the mold for a BD I cut in basswood.
Old May 03, 2013, 05:00 AM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
nice work eghelman
dpot is offline Find More Posts by dpot
Old May 03, 2013, 07:58 AM
Merk is offline
Merk's Avatar
Joined Sep 2004
That is some nice work.
I built a Joe's CNC and I have a cutting surface of 47"x57"
Russ
Old May 28, 2013, 01:13 AM
bendix1 is offline
Find More Posts by bendix1
bendix1's Avatar
United States, CA, San Jose
Joined Jan 2013
I have a cnc router 8x16'
bendix1 is offline Find More Posts by bendix1
For Sale Mini DLG fuse and CNC'ed wing cores Wave Glider Aircraft - Sailplanes (FS/W) 2 Feb 15, 2013 08:59 AM
Sold Zone V2 Four Panel CNC Cores for DLG heliwill10 Aircraft - Sailplanes (FS/W) 2 Sep 06, 2012 01:49 AM
For Sale CNC DLG foam cut wing cores for sale, with Drela Airfoils RobertTHaas Aircraft - Sailplanes (FS/W) 9 Dec 30, 2008 11:48 AM
Discussion CNC Foam Cores for My DLG yanivlevi Hand Launch 2 Mar 28, 2008 07:19 AM
Update for NEW CNC molded DLG RobertTHaas Hand Launch 50 Feb 09, 2005 08:42 AM
