Old Feb 13, 2013, 03:09 PM
XeCutor is offline
Find More Posts by XeCutor
Sweden, Stockholm
Joined Jul 2012
Build Log
Dumas A6M3 Zero RC Conversion
This is my first thread in the micro-section, I hope it'll be a good place for my little build thread.
I just finished converting a free-flight J3C Cub for the balsa builders section free-flight to RC kitbash contest. If you're interested, the
build thread is here. Since I still need something to keep busy with during evenings, I've started on a little warbird. I already had a vintage Comet A26 Invader kit that I plan on building, but I think I need some more building experience before I tackle a twin engine plane which will need some hefty modifications for RC flight.
The plane in this thread will get it's eletronics from a scrapped UMX Beast (v1), except the engine will be swapped for a NTM motor that I've ordered from Hobbyking (failing to realize it's the chinese new year so I'm gonna have to wait a while until that ships..). I'm hoping that the motor will be more efficient, it's certainly going to be lighter with mount and propeller adapter included.
I've started looking at the fuselage but I decided I'll skip any major work on that until I know what the engine I'll use looks like. Instead I've focused on the main wing. The kit balsa is very light, therefore also quite soft so I'm fearing it'll be sensitive to hangar rash and things like clumsy handling, but at least it will be light without swapping out wood! The laser cut parts are so far a joy to work with. Everything fits together very nicely, and where it deviates a little bit from outlined in the plans, it's easy to adapt so far.
The kit includes parts and instructions for building either a Type 22 or a Type 32 (22 has rounded wing tips, 32 much straighter tips and no protruding antenna tower behind the cockpit). I'm making my wingtips a hybrid by using the shape from the Type 32 but making the wings slightly longer (see last picture).
The wings have a pretty thick profile, but the servos wouldn't fit inside the wing out where the ailerons are supposed to go so I'm leaning towards putting ailerons on carbon fiber torque rods, but if anyone has any ideas or tips on this, I'm all ears.
I'm considering making the whole plane without any access hatch and instead make the wing removeable in order to get to battery and pushrod adjustments etc. At least that's the plan for now.
I'm thinking that I'll increase the aileron size from what's outlined on the plans and thereby foresake some scale appearance in favor of control authority. I'm probably going to use both servos even though I could do it with one and some mechanics, but with two I can easily get electronic adjustability with my radio which is handy, flaperons is also a potential option this way which can be simply programed. It would be cool to use the potential spare servo for flaps, but I'll try to keep this bird simple so I dare to fly it regularly. I'm also not sure if flaps would do me any real good on a bird this small. I'll try to keep weight low (no landing gear) instead.
XeCutor is offline Find More Posts by XeCutor
Old Feb 13, 2013, 04:44 PM
MPP is offline
MPP
Find More Posts by MPP
MPP
In Unusual Attitude Recovery
MPP's Avatar
Danbury CT (DXR)
Joined Oct 2005
Sounds cool, I was able to bury the aileron servos in the small micro Avenger i built. It is nice to have them in direct contact with the control horn. See if you have more room between R2 and R3 and even if they are recessed a little it could be a good solution. I have also set up two servos and torque rods with good results. I think you would be fine with the beast motor and 2S set up. Either way this is what makes these conversions fun as there is no right or wrong way to do them .
Subbed in
Mark
MPP is offline Find More Posts by MPP
Old Feb 13, 2013, 05:50 PM
chulian1819 is offline
Find More Posts by chulian1819
chulian1819's Avatar
Medellín, Colombia
Joined Apr 2010
great job! any space for retracts? lights?
chulian1819 is offline Find More Posts by chulian1819
Old Feb 13, 2013, 08:39 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Run some teflon or nylon/plastic tubing out to the ailerons and you can use a single servo mounted to move transversely using a fine guitar string as a flexible push rod.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Feb 13, 2013, 09:45 PM
davidterrell80 is offline
Find More Posts by davidterrell80
AMA 986339 FCC KB5LAM/4
davidterrell80's Avatar
United States, VA, Round Hill
Joined Apr 2012
Subscribed and watching with interest.
davidterrell80 is offline Find More Posts by davidterrell80
Old Feb 13, 2013, 11:31 PM
RFreak is offline
Find More Posts by RFreak
United States, MI, Ann Arbor
Joined Dec 2004
I have a question for you guys- I just built a Dumas T-34 using the guts from a V-2 Beast, and I put the aleron servos in the wing with the control horns on the bottom as usual. I built it with no landing gear, and now that I am looking at the finished plane, it occured to me that one or both contol horns are probably going to get ripped off on the first landing. How do you guys protect your small linar servos on belly landers?
RFreak is offline Find More Posts by RFreak
Old Feb 14, 2013, 02:17 AM
XeCutor is offline
Sweden, Stockholm
Joined Jul 2012
RFreak raises a concern I had as well, and a further reason I'll probably build the servos into the center section of the wing. A further reason to have them there, is to not have to extend the length of the cables, which I'd have to do to put them in line with the ailerons themselves. The cables would be long enough to go the distance without extension, but not long enough to allow for the required slack I'd need to use the whole wing as a hatch.
@MPP the Beast motor would certainly work. It's just on the heavy side with all the plastic it comes with. Besides, I've got a a still flying Beast which has a motor with a bad bearing, so I'll have a use for the motor, just not in this build! Oh, it'll still be 2S. I've got loads of appropriate 2S batteries and no 1S, so it's a matter of use what I have.
Old Feb 14, 2013, 02:32 AM
XeCutor is offline
Sweden, Stockholm
Joined Jul 2012
While doable, it's not actually something I'll do. I haven't found any good light kits with the appropriate size and I don't want to build my own at the moment. I'm kind of tempted to build micro retracts if I can't find any off the shelf that are small enough, but I'll try to build this particular plane with simplicity and low weight in mind primarily. Some day, I'll definitely build something small with retracts, just because it's awesome.
Old Feb 14, 2013, 02:36 AM
ror is offline
ror
Find More Posts by ror
ror
France, Languedoc-Roussillon, Thuir
Joined Aug 2009
suscribed too, my next project being a FW 190 D from blue bottle squadron, I have to wath this with interest.
Any chance you use a retract gear like this one ?
http://www.rcgroups.com/forums/showthread.php?t=1493173
bye
ror is offline Find More Posts by ror
Old Feb 14, 2013, 04:42 AM
Joined Apr 2012
I've used covers, similar to those that come installed on the UMX Carbon Cub, to protect the linear servos. Once, I took plastic spoons and cut away part of the bowl. I also have thought of using parts of medicine bottles and suitable shaped pieces of clear molded packaging, recycled from purchased items.
HERE is a example of an commercial alternative.
HERE is a blog entry describing the use of foam egg crates... Omelets anyone?
Old Feb 15, 2013, 09:45 PM
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
I built the Dumas Corsair with the electronics from the V1 Beast, it was a quick little airplane. I used the scale outline for my ailerons which was a mistake. Your Zero should do very nicely with full span ailerons.
I'm also working on a Zero, though its slightly smaller than yours.
Eclipse_7 is offline Find More Posts by Eclipse_7
Old Feb 16, 2013, 06:30 AM
ror is offline
ror
ror
Joined Aug 2009
@eclipe 7: what was the problem with your aileron ? not enought strenght ?
Old Feb 28, 2013, 08:14 PM
Medellín, Colombia
Joined Apr 2010
hows the zero going?
Old Mar 01, 2013, 03:27 AM
XeCutor is offline
Sweden, Stockholm
Joined Jul 2012
Very slowly. Other real-life-concerns have put a hold on the build. I've partially sheeted the wing, but it's still far from done so I haven't bothered posting any pictures yet.
This weekend won't give me much time to build either, but at least I finally (after 4 weeks) got the motor I ordered from hobbyking. Unfortunately, the prop-adapters I also ordered were crap so I think I'll need something else.
Old Mar 01, 2013, 05:23 AM
Joined Apr 2012
The next conversion contest is starting in the Balsa Builders forum, you should add this build in...
Sold Royal 1/2A Zero A6M3 Kit W/Cockpit Kit NIB - Free Shipping! Johnny Angel Aircraft - Fuel - Airplanes (FS/W) 1 Sep 12, 2011 03:27 PM
Cool 2009 Scale Fly In Giant Meister Scale A6M3 Zero At_your_six Giant Scale Airplanes 0 Jul 27, 2009 12:23 PM
Sold JEMCO A6m3 ZERO KIT horrido Aircraft - Fuel - Airplanes (FS/W) 1 Feb 12, 2009 04:43 PM
Sold Ryan A6M3 Zero St. Martin Aircraft - Electric - Airplanes (FS/W) 2 Oct 17, 2007 07:25 AM
