Old Dec 28, 2003, 08:29 PM
Jeff Charlot is offline
Find More Posts by Jeff Charlot
Insert custom witicism
Jeff Charlot's Avatar
San Diego
Joined Jun 2001
L.E.G. 60" Kingcobra build
Hi guys,
I opened up my new kit on Christmas morning, but didn't start on it until this afternoon. There's quite a bit of pre-fab already done for me which was a bit of a shock, but very appreciated. Jack built the tail for me so I could see how you master builders do it. Very impressive! Sheeted with balsa and capped with spruce on the leading edges. It would have taken me days to do it and it wouldn't have turned out nearly as well.
I'm going to deviate a bit from my standard build and learn some new techniques, so if you guys spot something goofy, please chime in and help me out.
Alright, let's get building. Here's the kit out of the box.
Jeff
Jeff Charlot is offline Find More Posts by Jeff Charlot
Old Dec 28, 2003, 08:31 PM
San Diego
Joined Jun 2001
....and the tail. Man, this thing is beautiful.
Old Dec 28, 2003, 08:34 PM
San Diego
Joined Jun 2001
Three spars, two of them already glued up for me, the other one with scarf joints already cut. I don't have a table saw, so the likelihood of me getting the joint cut exactly perfect is just about zero.
Old Dec 28, 2003, 08:37 PM
San Diego
Joined Jun 2001
After talking to Jack, he recommended using this technique, so I'm giving it a shot. Remember I'm trying to learn some new techniques? This is the first one. I joined the main spar with epoxy and clamped it down.
Old Dec 28, 2003, 08:40 PM
San Diego
Joined Jun 2001
Here's the three spars. The short one will be glued to the front of the main spar and the long one will be aft.
Old Dec 28, 2003, 08:41 PM
Carlski is offline
Find More Posts by Carlski
Team member-One day PSS Build!
Carlski's Avatar
Joined Sep 2003
Dang, When Brian and I built the first Laird P-63 prototypes, all we had was a block of EPP! That LEG kit looks great! Nice work on the fuse Jack, and keep up the good building Jeff!
Carl
Carlski is offline Find More Posts by Carlski
Old Dec 28, 2003, 08:43 PM
San Diego
Joined Jun 2001
I glued the spars together with 5-minute epoxy and just clamped them together. I did make sure that the scarf joints were opposing each other. Main spar to the right and the short spars to the left. Should be plenty strong!
Old Dec 28, 2003, 08:49 PM
San Diego
Joined Jun 2001
Thanks Carl! I was thinking that this would be just a standard foamie kit......I was WRONG! Lots of work has already been put into this before I ever got my hands on it. Some of the other work I noticed was the trailing edge material has been cut to length, pre-bent torque rods, carbon fiber rods are cut to length and a COMPLETE package of hardware. No fumbling around in the toolbox looking for a missing clevis. Not exactly an ARF, but still more than I was expecting.
Jeff
Old Dec 28, 2003, 08:51 PM
San Diego
Joined Jun 2001
Okay, where were we....here's the third spar glued down.
Old Dec 28, 2003, 08:53 PM
San Diego
Joined Jun 2001
.....and the finished product showing the opposing scarf joints....
Old Dec 28, 2003, 08:54 PM
San Diego
Joined Jun 2001
Here's what it looks like all together.
Old Dec 28, 2003, 08:57 PM
San Diego
Joined Jun 2001
After the spar is built, I laid it down on the wing core and traced around the other two spars.
Old Dec 28, 2003, 08:58 PM
San Diego
Joined Jun 2001
...then cut it out with a 9mm blade. Thanks for the tip Jack! I used to just gouge it out with a flat screwdriver. The blade worked much better, a very clean channel.
Old Dec 28, 2003, 09:02 PM
San Diego
Joined Jun 2001
Although an option would have been to use hot melt glue, I didn't think I could work fast enough to feel comfortable with it, so I went to the old standby of goop and then laid the spar in with a little weight to hold everything flat. The other end of the spar is braced up and I DID remember to bevel the edges of the core prior to gluing this in. I just didn't get a picture of it.
Old Dec 28, 2003, 09:08 PM
San Diego
Joined Jun 2001
So, with the spar drying, the wing is kinda on hold. Tomorrow I'll glue the other spar in and the wing together as well.
Well, should I keep going at this pace or ease off on the pictures a bit? Some of this stuff might be a little old news to you guys.
Jeff
Sold For Sale: RTF L.E.G. 60" Reno Racer pmccleave Aircraft - Sailplanes (FS/W) 1 Dec 19, 2005 07:40 AM
L.E.G. 48" P-40 Build jdcook54 Slope 186 May 30, 2005 11:36 AM
L.E.G. P-63 Kingcobra Build averen Slope 18 Jan 06, 2005 09:51 PM
L.E.G P51 Build Thread? colin wavell Slope 7 Dec 29, 2004 08:30 AM
Question L.E.G. Me-109 Build Question jimboyzguy Slope 6 Aug 19, 2004 03:29 AM
