Old Mar 04, 2013, 08:25 PM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Originally Posted by Dutchraptor View Post
The raw value from the transmitter is for example 11645..................
And raw value is what you will be passing to the raspi for all events, whether they are servo or pin events, correct?
Here's is how I currently have the throttle mapped:
11500 full reverse <-> 11750 idle <-> 12000 full ahead
Pete
blutoh is offline Find More Posts by blutoh
Old Mar 05, 2013, 02:26 AM
Dutchraptor is online now
Find More Posts by Dutchraptor
Dutchraptor's Avatar
The Netherlands, ZH, Hoogvliet
Joined Jul 2008
No,I'll send the complete command to the rasppi. In the rasppi the splitting takes place. Or else the rasppi doesn't know which group/subgroup you want. A throttlerange is only from 0 to 255. A servo only has 256 steps (if your lucky). The arduino reads a pot in 1024 (10K), then I map that 0-255 so the arduino can use that for the servo PWM. I know there is a gap of 244 steps between the subgroups, but I left that for logical numbers each channel/group starting with either 0 or 500.
Danny
Dutchraptor is online now Find More Posts by Dutchraptor
Old Mar 05, 2013, 09:03 AM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
OK, let me clarify I few things so I get it right:
By complete command you are referring to strings like these: 21070 (pin example) or 115200 (servo example)? Or is there more data in the complete command that I missed?
A throttlerange is only from 0 to 255. A servo only has 256 steps (if your lucky). ........ I know there is a gap of 244 steps between the subgroups, but I left that for logical numbers each channel/group starting with either 0 or 500.
WIll the throttle data consistently be in the lower half or upper half of the group range? As an example will it always be between 11500 and 11755, or between 11756 and 12000, but not span the two ranges, like 11700 and 11855?
Pete
Old Mar 05, 2013, 12:57 PM
Joined Jul 2008
Pete,
The complete raw command always consists of 5 numbers. The throttle range will always be between 0-255 (11000 to 11255 / 11500 to 11755 / 12000 to 12255 and so on). The arduino doesn't go beyond 255 in it's PWM range.
Danny
Old Mar 05, 2013, 01:35 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
OK, got it.
I have all the info I need to proceed now. It's going to take a few days to get all this coded in a full serial version for testing.
Pete
Old Mar 05, 2013, 01:41 PM
Joined Jul 2008
I'll make preparations for the communication to the raspberry on the receiver shield.
Danny.
Old Mar 06, 2013, 03:01 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Toggling sounds
Danny and lurker(s),
We have addressed sounds that run for a finite length of time (e.g. horn, engine start, etc) and we have addressed some sounds that run infinitely until terminated (e.g. ambient and enginesounds). In order to toggle an infinite sound on or off, we can:
  • use 1 pin - when activated, if sound is off, turn it on or if it's on turn it off (like we are doing with the ambient sound effect)
  • use 2 pins- one pin turns it on, one pin turns it off
  • monitor the servo - control the sound with the servo movement (like we are doing with the engine sound effect)
I want to identify any additional sounds that need to be tied to a variable length of operation. Here are the ones we have identified so far:
  • winch - should run only while the feature is operating, on / off switch
  • crane - monitor the servo position, start when servo leaves neutral, stop when servo returns to neutral (??)
What other feature sounds would you like to add, and which activation method does it require?
Pete
Old Mar 07, 2013, 08:35 AM
Joined Jul 2008
Pete,
I think most of us, also the standard transmitters, use 1 button/command to activate a function/sound. When released the sound stops. Even the ambient and motor sound can each be controlled by 1 switch. Most transmitters have latching switches for functions like engine sounds and moment switches for short functions like horns or crane functions.
I haven't come across any systems that uses 2 seperate commands for on and off. Come to think of it, most cranes function with motors and wires, not with servo's.
Just my idea.
Danny
Old Mar 07, 2013, 09:06 AM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
OK,
I'll set the crane sound to run only while the crane is operating, on / off switch. If I am "using a 1 button/command to activate a sound, when released the sound stops". Will the receiver continually send that pin value until the user releases the button? Or will you toggle it,send once for on, send once again for off?
If anyone has any other equipment sounds that should be included, please post them here.
Pete
Old Mar 07, 2013, 09:59 AM
Joined Jul 2008
The system (serial based) sends the command once. After splitting it checks if a value has changed or not.
Other sounds:
welding and hammering by the deck crew
anchourchains
drunk singing
sirene (firefighting boats)
telegraph (sos)
(bridge) crew yelling commands (at random intervals random commands perhaps)
Just to name a few.
Danny
Old Mar 07, 2013, 12:34 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Danny,
You lost me on that one. If the value changes, isn't it a differrent pin? Or are you saying if the pin changes, stop the playing sound?
Good sound stuff. I am thinking that these:
anchourchains
drunk singing
Should be part of the ambient sound?
But these:
telegraph (sos)
Should be push button activated, to play at will.
And this one: drunk singing We should all get together and record
Here is an interim release (attached):
Download the file
Change name to install_soundfx.bin after downloading by renaming, do not unzip:
mv install_soundfx.bin.zip install_soundfx.bin
Change permissions if necessary:
chmod 755 install_soundfx.bin
Install the package:
./install_soundfx.bin
new versions: mnuSoundfx.py and serSoundfx.py.. mnuSoundfx.py is for testing
There is now a configuration file, soundfx.ini, to make it easy to assign the throttle servo. We will be adding more config settings to this file as necessary.
[EDIT: For a quick synopsis and the latest installation package, go directly to this post.
Old Mar 07, 2013, 03:30 PM
Joined Jul 2008
1 pin has 2 states on/off, 1/0 and it adds or substracts (1/2/4/8/16/32/64/128 depending on the pinnumber) from the commandcode.
To bad we live on the other side of the globe together. A bottle of rum on a deadman's chest, yoohoo, yoohoo.
Danny
Old Mar 07, 2013, 10:07 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Danny,
Here are the current serial command assignments, please reivew.
Pete
Functional Group 1
servo 2: 11500 - 11755 throttle range (soundfx.ini)
Functional Group 2
command: 21128; Group: 1; Pin: 22; Start Engine
command: 21064; Group: 1; Pin: 23; Shutdown Engine
command: 21032; Group: 1; Pin: 24; Toggle Ambient Sounds On / Off
command: 21016; Group: 1; Pin: 25; Foghorn
command: 21008; Group: 1; Pin: 26; Horn
command: 21004; Group: 1; Pin: 27; Whistle
command: 21002; Group: 1; Pin: 28; Small Winch
command: 21001; Group: 1; Pin: 29; Not assigned
command: 22128; Group: 2; Pin: 32; Not assigned
command: 22064; Group: 2; Pin: 33; Not assigned
command: 22032; Group: 2; Pin: 34; Not assigned
command: 22016; Group: 2; Pin: 35; Not assigned
command: 22008; Group: 2; Pin: 36; Not assigned
command: 22004; Group: 2; Pin: 37; Not assigned
command: 22002; Group: 2; Pin: 38; Large Winch
command: 22001; Group: 2; Pin: 39; Not assigned
command: 23128; Group: 3; Pin: 42; Not assigned
command: 23064; Group: 3; Pin: 43; Not assigned
command: 23032; Group: 3; Pin: 44; Not assigned
command: 23016; Group: 3; Pin: 45; Not assigned
command: 23008; Group: 3; Pin: 46; Not assigned
command: 23004; Group: 3; Pin: 47; Not assigned
command: 23002; Group: 3; Pin: 48; Not assigned
command: 23001; Group: 3; Pin: 49; Not assigned
Old Mar 08, 2013, 09:36 AM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Danny, we need to clarify this, lets take an example:
  • The operator pushes and holds button #28 to start the small winch.
  • The transmitter sends command: 21002 (= Pin: 28; Small Winch)
  • The receiver relays 21002 to the sound system
  • The sound system begins playing the small winch sound effect
  • The operator now releases button #28 to stop the small winch
What command is sent by the transmitter, or what signals the sound system to stop playing the sound effect? If I am tracking pin state internally to the sound system, I need to know what event triggers the "stop" action for a loopng sound.
For example, with the ambient sound, I track the pin state internally , when the same command code is sent again, I toggle the sound on or off.
Pete
Old Mar 08, 2013, 10:54 AM
Joined Jul 2008
Pete,
Following your instructions (it's .zip instead of .txt btw), I get a Text file busy error after the ./install_soundfx.bin step.
What did I do wrong? I thought I'd take a look if I could change the code to explain.
EDIT: found it. Save as didn't asve the complete file. save did.
Danny
