Hi HD,
I use Audacity. It's an Open Source visual audio editor. It works great, and it's free. It will easily do what you require and a whole lot more. Pete |
EDIT: finally found the way to make it work in the terminal: python ./name.py Danny |
Pete, I hope you don't mind that I made some changes in your code (and put my name next to yours). If so, let me know, I will change it, if you want. The Raspberry now talks via serial to an Arduino. It reads an analog pin (A1) and reads pins 2->9. All pins have a 10K pulldown to ground. Now we can easily call 8 sounds by pushing a button (or in my case on the breadboard, connect two wires (5V to pin), yes I'm a bit lazy). Next step will be slicing the engine sound in a few steps and couple them to parts of the range from the analog pin.
Danny EDIT: welcome text and exit on pin Code:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
Version: 0.0.3
Author: blutoh and Dutchraptor
Purpose: using pygame mixer for rc boat sound effects with ArduinoRC control
Licence: gpl, see http://www.gnu.org/licenses/gpl.html
import pygame
import time
import os
import serial
# initialization
pygame.mixer.pre_init(44100, -16, 2, 2048) # setup mixer to avoid sound lag
pygame.init() # initialize pygame
# Basic Sound Effects System #
# The ambient effect is played like a music file. It begins when the sound #
# system is started and continues after the engines are shutdown. All other #
# effects are played at will. The pygame mixer allows multiple (up to 8) #
# sounds to be mixed and played simultaneously. #
# Serial commands between 1000 and 1500 are analog readings from arduino #
# Serial commands between 2000 and 2255 are digital readings from arduino #
# Replacing the menu with pin detection to trigger sound effects on arduino. #
# Now this works, we can expand the functiongroups and functions #
# The connection with a Nano with a NRF24L01 is also open or #
# a Arduino Mega with a NRF24L01 and functions hooked up #
# Ver: 0.0.3 #
# Have fun! #
# Blutoh and Dutchraptor #
# load up the necessary sound effects files for use
# sound effect files are in subfolder 'data', so join the path to the file name
try:
pygame.mixer.music.load(os.path.join('data', 'ambient.ogg')) # ambient fx
engStart = pygame.mixer.Sound(os.path.join('data','engStart.ogg')) # eng start
engRun = pygame.mixer.Sound(os.path.join('data','engRun.ogg'))
engStop = pygame.mixer.Sound(os.path.join('data','engShutdown.ogg')) # eng stop
horn = pygame.mixer.Sound(os.path.join('data','horn.ogg')) # horn fx
fogHorn = pygame.mixer.Sound(os.path.join('data','fogblast.ogg')) # foghorn fx
whistle = pygame.mixer.Sound(os.path.join('data','whistle.ogg')) # whistle fx
except:
raise UserWarning, "could not load or play soundfiles in 'data' folder :-("
pygame.mixer.music.play(-1) # play ambient fx as background, see lines 74 & 81
pygame.mixer.music.set_volume(.625) # set ambient sound to 5/8ths volume
ARDUINO = "/dev/ttyACM0" # lets setup the Arduino USB
print "Welcome to the Hybrid Serial Soundsystem"
def main():
ser = serial.Serial(ARDUINO, 9600) # setting up serial
prevVal = None
while 1:
# Read the serial value
ser.flushInput()
serialValue = ser.readline().strip()
# Catch any bad serial data:
try:
#c = convert + int(serialValue)
c = int(serialValue)
except ValueError:
serialValue = 0
try:
if serialValue != prevVal and c > 1000 and c < 1500:
# Print the value if it differs from the prevVal:
c = c - 1000 # bring back to normal 8 bit numbers
print "AnalogVal:",c, " Serialreceive:",serialValue
prevVal = serialValue
elif serialValue != prevVal and c > 1999 and c < 2256:
c = c - 2000 #bring back to normal 8 bit numbers
try:
if c == 0:
print "All functions Off 8-Bitcommand:",c, " Serial command received:",serialValue
if c >= 128:
print "Function 1: on 8-Bitcommand:",c, " Serial command received:",serialValue
c = c -128
engStart.play() # play start effects
time.sleep(6.5) # pause to allow start effects to finish
engRun.play(-1) # run the engine sound continously in a loop
#pygame.mixer.music.stop() # uncomment this line if you want ambient fx
# to stop while engine sound is playing
if c >= 64:
print "Function 2: on 8-Bitcommand:",c, " Serial command received:",serialValue
c =c -64
engStop.play()
engRun.stop()
time.sleep(8) # pause to allow stop sequence to finish
#pygame.mixer.music.play(-1) # If you uncommented line 74, then
# uncomment this line to start ambient effects
if c >= 32: # toggle ambient sounds on/off
print "Function 3: on 8-Bitcommand:",c, " Serial command received:",serialValue
c =c -32
if pygame.mixer.music.get_busy():
else:
if c >= 16:
print "Function 4: on 8-Bitcommand:",c, " Serial command received:",serialValue
c =c -16
fogHorn.play() # play foghorn
if c >= 8:
print "Function 5: on 8-Bitcommand:",c, " Serial command received:",serialValue
c =c -8
horn.play() # play other horn
if c >= 4:
print "Function 6: on 8-Bitcommand:",c, " Serial command received:",serialValue
c =c -4
whistle.play() # play whistle
if c >= 2:
print "Function 7: on 8-Bitcommand:",c, " Serial command received:",serialValue
c =c -2
if c >= 1:
print "Function 8: on 8-Bitcommand:",c, " Serial command received:",serialValue
pygame.quit() # exit
except ValueError:
pass
except ValueError:
pass
if __name__ == '__main__':
main()
Code:
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin2 = 2; // the number of the pushbutton pin
const int buttonPin3 = 3; // the number of the pushbutton pin
const int buttonPin4 = 4; // the number of the pushbutton pin
const int buttonPin5 = 5; // the number of the pushbutton pin
const int buttonPin6 = 6; // the number of the pushbutton pin
const int buttonPin7 = 7; // the number of the pushbutton pin
const int buttonPin8 = 8; // the number of the pushbutton pin
const int buttonPin9 = 9; // the number of the pushbutton pin
const int analogInPin = A1; // Analog input pin that the potentiometer is attached to
const int analogbuffer = 0; //
// Variables will change:
int buttonState2; int lastButtonState2 = LOW;
int buttonState3; int lastButtonState3 = LOW;
int buttonState4; int lastButtonState4 = LOW;
int buttonState5; int lastButtonState5 = LOW;
int buttonState6; int lastButtonState6 = LOW;
int buttonState7; int lastButtonState7 = LOW;
int buttonState8; int lastButtonState8 = LOW;
int buttonState9; int lastButtonState9 = LOW;
int buttonSend = 2000;
int buttonSendOld = 0;
int Sending = 0;
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
int outputValueOld = 0;
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 50; // the debounce time; increase if the output flickers
void setup() {
// initialize serial communications at 9600 bps:
Serial.begin(9600);
pinMode(buttonPin2, INPUT);
pinMode(buttonPin3, INPUT);
pinMode(buttonPin4, INPUT);
pinMode(buttonPin5, INPUT);
pinMode(buttonPin6, INPUT);
pinMode(buttonPin7, INPUT);
pinMode(buttonPin8, INPUT);
pinMode(buttonPin9, INPUT);
void loop() {
// read the state of the switch into a local variable:
int reading2 = digitalRead(buttonPin2);
int reading3 = digitalRead(buttonPin3);
int reading4 = digitalRead(buttonPin4);
int reading5 = digitalRead(buttonPin5);
int reading6 = digitalRead(buttonPin6);
int reading7 = digitalRead(buttonPin7);
int reading8 = digitalRead(buttonPin8);
int reading9 = digitalRead(buttonPin9);
if (reading2 != lastButtonState2) {
// reset the debouncing timer
lastDebounceTime = millis();
buttonState2 = reading2;
if (reading2 == HIGH){buttonSend=buttonSend+128;}
if (reading2 == LOW){buttonSend=buttonSend-128;}
if (reading3 != lastButtonState3) {
buttonState3 = reading3;
if (reading3 == HIGH){buttonSend=buttonSend+64;}
if (reading3 == LOW){buttonSend=buttonSend-64;}
if (reading4 != lastButtonState4) {
buttonState4 = reading4;
if (reading4 == HIGH){buttonSend=buttonSend+32;}
if (reading4 == LOW){buttonSend=buttonSend-32;}
if (reading5 != lastButtonState5) {
buttonState5 = reading5;
if (reading5 == HIGH){buttonSend=buttonSend+16;}
if (reading5 == LOW){buttonSend=buttonSend-16;}
if (reading6 != lastButtonState6) {
buttonState6 = reading6;
if (reading6 == HIGH){buttonSend=buttonSend+8;}
if (reading6 == LOW){buttonSend=buttonSend-8;}
if (reading7 != lastButtonState7) {
buttonState7 = reading7;
if (reading7 == HIGH){buttonSend=buttonSend+4;}
if (reading7 == LOW){buttonSend=buttonSend-4;}
if (reading8 != lastButtonState8) {
buttonState8 = reading8;
if (reading8 == HIGH){buttonSend=buttonSend+2;}
if (reading8 == LOW){buttonSend=buttonSend-2;}
if (reading9 != lastButtonState9) {
buttonState9 = reading9;
if (reading9 == HIGH){buttonSend=buttonSend+1;}
if (reading9 == LOW){buttonSend=buttonSend-1;}
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
// save the reading. Next time through the loop,
// it'll be the lastButtonState:
lastButtonState2 = reading2;
lastButtonState3 = reading3;
lastButtonState4 = reading4;
lastButtonState5 = reading5;
lastButtonState6 = reading6;
lastButtonState7 = reading7;
lastButtonState8 = reading8;
lastButtonState9 = reading9;
// read the analog in value:
sensorValue = analogRead(analogInPin);
// map it to the range of the analog out:
outputValue = map(sensorValue, 0, 1023, 1000, 1255);
if (outputValue != outputValueOld){
Serial.println(outputValue);
outputValueOld = outputValue;
// if anything changes in button state, send it
if (buttonSend != buttonSendOld){
Serial.println(buttonSend);
buttonSendOld = buttonSend;}
delay(20);
Danny,
I don't mind at all, in fact, I encourage it. As I said in the first post, this is a community project, Open Source. Right now it's just you an me in the community . But based on the view count, I think we have a lot of lurkers. Hopefully we'll get more participants as we go along, but if anyone is lurking, jump right in and speak up! The code looks great, sending the value over the serial line is much more efficient, I didn't think we would get there so quickly. A few questions:
Thanks, Pete |
The Arduino was programmed on my other computer. Once the program was on it, I just connected it to the USB port of the Raspberry. It did use the VIN and GND of the arduino te give it it own powersupply because else the pins and analog made the system instable. Apart from the USB I have no other connections to the Raspberry. I don't need the serial monitor for the Arduino, so connection was easy. If you really want to view what the arduino does, you can always use the softserial for that. But then you have to connect the arduino to the GPIO and use voltage dividers to bring it to 3.3V so the USB can be read by the ArduinoGUI. GND from the Arduino and Raspberry are connected to eachother throught the USB cable.
My setup is quit easy to build. The Arduino communication can be fully tested throught the serial monitor in the ArduinoGUI (both ways to and from the arduino). When everything works the way you want to, then it's time to connect it to the raspberry and start reading the values. I did nothing with the serial console. I didn't even know what it was untill now. Hope it's all clear. Any questions, please ask. Danny |
Danny,
Had to make some changes to run on my raspi: My default serialport is /dev/ttyAMA0 instead of /dev/ttyACM0, so I changed ARDUINO = "/dev/ttyACM0" # lets setup the Arduino USBTO ARDUINO = "/dev/ttyAMA0" # lets setup the Arduino USBWheezy kept trying to spawn a getty terminal on ttyAMA0, so I commented out this line in /etc/inittab: sudo nano /etc/inittabcomment out this line by putting the # at the beginning of the line #T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100reboot raspi: sudo rebootI'm not sure why there is a difference in the usb serial device name, trying to find out, but it's working now. Pete EDIT: For a quick synopsis and the latest installation package, go directly to this post. |
#!/usr/bin/env pythonThis will point to the python interpreter and you wont have to include python on the command line. Then set the permissons to executable with: chmod 755 filename.py Then you can just type: ./name.py to run the program Pete |
OK, I'll try that. Like I said before, I'm just learning Linux and Python, started about 4 or 5 days ago. I can use all the help there is. I'm not a programmer by profession, just learning by doing. The famous trail and error methode.
By the way, is there in the end a possibility to start the raspberry and automatically start the soundprogram? A small soundbit to attention the user that it has started up would also be nice then (is there a standard linux tune like windows when it starts?). Most of us don't have monitors in our boats (the 3,5" would look nice). I'm going to try and make a battery connection with a 5V regulator to the Raspberry. I read that I can use the 5V GPIO for that. There's also a pcb waiting for me to solder with a small amplifier (Velleman) for the sounds. What's next? Are we going to send all the commands from the arduino system to the Raspberry? Or are we going to make a menu in the arduino program in which we can select with defines which commands are send and which not (my preference). That way we can also use sounds for cranes, helicopters, winches and so on. If we do that, we should probably name the sounds after the commands, in my case a crane sound would be for example 2064 for up. I think that will be our next challenge. How do we make it easy for everone to use. Come on people, hop on board and join the fun. Even if you don't have a clue how to program. Give some ideas. There is a lot of knowlegde out there. This soundsystem and the Full Arduino Control system are open source. So everyone is invited to join in, make changes, expand and share. That way WE all can make it better and build ourselves a control system WE want. The big compagnies are letting us down by just making car, plane/heli transmitter with only 8 channels (max) or cost way to much. We only have the old models to choose from and the 2,4gHz isn't an option. That's one of the reason why I started to make my own system. Pete also has his reasons. But the main reason is FUN. Danny |
![]() Quote:
) But we have to crawl before we walk. Pete |
Later I also want to develop an implementation for those who are not using the arduino control system , to be able to trigger sounds remotely. Some type of interface
That is not very hard to do with a little Arduino Nano translator that reads the channels of a standard receiver (codes to be found on the internet). Then it can throw the commands to the Raspberry. Who wants to pickup the challenge. Danny |
New Files
The program has been modified to play a sound on startup, to signal that it's loaded. There is a new program, serialsoundfx.py, version 0.0.3b, and a new sound file, appStart.ogg, in the data folder. All files, old and new, are contained in the soundfx.zip archive file.
Danny,
I got the details worked out for autostarting the soundfx pkg on boot up. Had to create a shell script for the system to manage the execution of the program. The problem is that once it's configured, starting and stopping the soundfx program is going to be a big pain. So while we are still in development mode, I don't think we should implement that yet. Once we get close to production quality, then we can implement and test. Anyway, here are the details: EDIT: An additional step added: Change the path path for all sound files to explicit, necessary when the program runs as a system service only (autostart): Example: pygame.mixer.music.load(os.path.join('/home/pi/soundfx/data', 'ambient.ogg'))Change the file permissions on the script: chmod 755 startsoundfx Copy the startsoundfx script to /etc/init.d: sudo cp ./startsoundfx /etc/init.d/startsoundfx Register the application: sudo update-rc.d startsoundfx defaults To manually start the program: sudo /etc/init.d/startsoundfx start To manually stop the program: sudo /etc/init.d/startsoundfx stop To remove the script from auto start-up: sudo update-rc.d -f startsoundfx remove Shell script 'startsoundfx' code: Code:
#! /bin/sh
# /etc/init.d/startsoundfx
### BEGIN INIT INFO
# Provides: startsoundfx
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Simple script to start a program at boot
# Description: A simple script which will start / stop a program a boot /$
### END INIT INFO
# Carry out specific functions when asked to by the system
case "$1" in
start)
#echo "Starting"
python /home/pi/soundfx/serialsoundfx.py
stop)
# echo "Stopping!"
killall python
echo "Usage: /etc/init.d/startsoundfx {start|stop}"
exit 1
esac
exit 0
