I never have had one, but have heard from others that because the wing section has a lot of camber, that thermal is "in section" and cruise is slightly reflexed, and speed is more reflex.
If the statement about the camber in the wing is true, then what I have heard should be as well. Good luck with the plane! R, Target |
Latest blog entry: Stork 4 Pro X-tail from...
contact Joe Nave at RC Soaring. He sold then when they were available.
http://www.rcsoaring.com/ Sherpa |
You should use flaperons on every model. Its more efficient in roll that way. The longer span the flaps, the more you mix them to the ailerons.
Happy you got info from folks that flew the plane. R, Target |
Every flight condition EXCEPT launch.....And landing mode too (thanks Marc!)
I have flaperon mixing shut off in launch mode because I don't want to unload the wing completely just to bank or turn a bit. Flaperon mixing in any other mode make the wing require less total deflection to get the same roll response. I use the same philosophy for snapflap. It on in all flight modes EXCEPT launch....(and landing mode) For snapflap though, you want roughly the same camber position at full elevator in each flight mode, so that means more snapflap when you are in reflex, than in thermal. Recently, I broke this general rule and have been playing with more snapflap in thermal mode...reason being that I rarely pull full up elevator when flying in thermal circles. That way, I get the snapflap I need at the stick position I use most. R, target |
What about differential and rudder mix for the Zenith, Marc?
I assume with the 3.7 you probably use more rudder mix than with lesser span, Those settings would probably be helpful to MM. R, Target |
Well, my aileron-rudder mix is not the norm. I tend to not use as much as some. In thermal and cruise, my mix is only about a 20-25% mix, and I fly my left stick alot, especially in thermalling. In cruise, I want just enough mix for a smooth standard rate turn wile searching. In reflex, I use none.
Like I said, that may not be the norm with most, and Mal may need more to start with. Marc |
| Thread Tools | |
| Sold Zenith 3.5 or 3.7 RTF Great Deal $550.00 | orbitone | Aircraft - Sailplanes (FS/W) | 4 | Jan 11, 2013 06:02 PM |
| Found Looking for 7 or 9 channel DSM2 Orange RXs with satelites. | crosby | Aircraft - General - Radio Equipment (FS/W) | 0 | Jan 03, 2013 05:31 PM |
| For Sale 3.7 Zenith for sale | zaptherio | Aircraft - Sailplanes (FS/W) | 0 | Jul 12, 2012 02:25 PM |
| For Sale Zenith 3.7 For Sale!!!! | Jflyer1 | Aircraft - Sailplanes (FS/W) | 6 | Jan 11, 2011 09:24 PM |
