Old Feb 12, 2013, 10:35 AM
tightwad is offline
Find More Posts by tightwad
Joined Dec 2012
2.6m Jamara Ventus HX2 cog
Does anyone know what the correct centre of gravity is for the 2.6m Jamara Ventus HX2?
I have as yet to maiden it and I'm told that these can be a nightmare to fly.
tightwad is offline Find More Posts by tightwad
Old Feb 13, 2013, 11:51 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
If no one answers you might consider asking the manufacturer
http://www.neuershop.jamara.com/inde...3e27f89a82899c
aeajr is offline Find More Posts by aeajr
Old Feb 21, 2013, 12:27 PM
tightwad is offline
Joined Dec 2012
Aeajr
Tried the makers web site but unable to obtain required info.
Still loking for the COG.
Can anyone help?
Old Feb 21, 2013, 04:53 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
If there is a spar or a wing rod, use that as your starting point.
If you can hand throw it, preferably over tall grass, that would be good. It should go something like this video.
> Video of a Hand Throw Test Glide
rc sailplane bird of time (0 min 17 sec)
If you can't hand throw it because you can't get a good enough grip then do it with 1/3 throttle. If it goes OK take it up. If it is hard to control, slowly power off and land it. Give yourself a LOT of room.
If it tends to sag at the tail, it is probably tail heavy, don't try to fly it.
> Test Flight Procedures
http://www.flyesl.org/forums/topic.asp?TOPIC_ID=226
> Performance Tuning Gliders
http://www.flyesl.org/forums/topic.asp?TOPIC_ID=227
Gordy's Balancing System
http://www.flyesl.org/forums/topic.asp?TOPIC_ID=255
TUNING THE ELEVATOR
Soaring Master Class Preview 1.mp4 (4 min 1 sec)
Old Feb 21, 2013, 05:06 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Here is a seller. Maybe they have some insights:
http://alshobbies.com/shop/lookupstock.php?pc=37512
Old Feb 25, 2013, 02:46 PM
tightwad is offline
Joined Dec 2012
Aeajr,
Thanks for the edifying information and help you've provided.
I finally managed to get the information via a very circuitous route from an Italian gentleman working in Germany.
For future reference I can now announce that the CG for the non powered version of the Jamara Ventus HX2 is 42-46mm back from the root leading edge.
All I need now is some decent weather and plenty of lift in order to fly it from our local slope whilst praying that it doesn't tip stall and spiral to earth.
Thanks again.
Tightwad.
Discussion TW 742-5 (6-CH) 2.6m&1.6m interchangeable Glide Brettis Foamies (Kits) 0 Feb 01, 2013 05:28 PM
For Sale Spare wings for Jamara / Windrider 2.6m Habicht maj74 Aircraft - Sailplanes (FS/W) 0 Dec 02, 2012 11:06 AM
Discussion AMD MINI VENTUS 2.6m Reviews wanted!!! wac Electric Sailplanes 0 Apr 22, 2007 04:22 PM
Help! HF Model 6m Ventus 2 cxM - advice on SLS motor choice needed guillaume83 Scale Sailplanes 13 Jul 25, 2006 07:38 PM
Sold Ventus Electric 2.6m CAT Power Aircraft - Sailplanes (FS/W) 1 Apr 10, 2006 10:53 AM
