Old Mar 01, 2013, 09:35 AM
Fig Newton is offline
Find More Posts by Fig Newton
Fig Newton's Avatar
United States, TX, Burnet
Joined Jan 2013
Spoilers arrived and they have been mounted. I will see if I can come up with some pics and video this weekend. First flight with them was great. Mild wind conditions and I got in quite a few low passes where I could check out their performance. I have them set up on the 5th channel (gear) and a mix on my DX6i. Flip the gear switch and the spoilers come up. Depending on the toggle of the mix switch they either come up halfway or full. So far, from what I have observed and my purpose of spoilers full deployment might be the most used option.
They really do a good job on reducing the glide. There was a slight nose up when they deploy but it's perfectly manageable so far, and it also slows up the glider a little. It's fun to watch the glider accelerate and change glide ratio when you pull them in too.
I did some quick tests from higher up where I nosed it over and hit the spoilers. It seems to help control the dive speed and keep it from getting too fast. I also tried out full right or left rudder and full up elevator. With the spoilers up the spin is at a much slower rate and steadier, with a good amount of sink. I goofed around with them for about an hour flight and am happy to report I am pleased with them. The install went well and the results are quite noticeable.
Fig Newton is offline Find More Posts by Fig Newton
Old Mar 01, 2013, 10:46 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Since those are verticle deployed spoilers they could be called airbrakes. They will induce quite a bit of drag.
The other kind, the barn door type that bring a flat plate up at an increasing angle induce a little different behavior. They will usually induce a nose down result.
aeajr is offline Find More Posts by aeajr
Old Mar 06, 2013, 08:27 AM
baldy is online now
Find More Posts by baldy
United States, NJ, Chatham
Joined Mar 2003
aeair,
Did you ever try the Radian wings with flaps that I sold to
you?
Tom Unger
baldy is online now Find More Posts by baldy
Old Mar 07, 2013, 02:56 AM
socommk23 is offline
Find More Posts by socommk23
always looking for clouds
socommk23's Avatar
Joined Aug 2010
flaps work awesome on my bros radian.
i also have ordered these airbrakes but to fit to my 3 meter condor. whats the quality like?
socommk23 is offline Find More Posts by socommk23
Old Mar 07, 2013, 06:00 AM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
second that
Originally Posted by aeajr View Post
Were we talking about contest flying where the landing may be scored in inches from a point, and the difference between first and 10th place can be a matter of seconds on a clock? Then a glide path tool can make a huge difference, and can be called necessary.
When you would be happy landing within 10 feet of a mark for fun flying and there is no clock running, then it is not.. At best it is a nice to have.
So since this hobby is "modeling" would this be "remodeling"?
If its FUN do it!! Adding unneeded weight is never good so if you do it, do it light
The flap route has more useful ways to be operated so may be more FUN.
ozmo01 is offline Find More Posts by ozmo01
Old Mar 07, 2013, 06:46 AM
socommk23's Avatar
Joined Aug 2010
the whole hobby is sposed to be fun. so do what makes ya happy.
Old Mar 07, 2013, 07:06 AM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Both types will create a nose-down condition ...
tkallev is offline Find More Posts by tkallev
Old Mar 07, 2013, 07:11 AM
socommk23's Avatar
Joined Aug 2010
not in all cases! some airbrakes can and do induce a nose up attitude.
Old Mar 09, 2013, 12:08 PM
Fig Newton's Avatar
Joined Jan 2013
I have a couple more flights in with the spoilers/air brakes from HobbyKing. I am thoroughly pleased with them. They really work well and while the glide ratio drops dramatically, their deployment doesn't affect the flyablility of the plane. It makes landing a lot nicer when you can come in way too high, hit the spoilers, and still put it down right in front of you. I have also been trying things like going up and deploying spoilers and trying to loop. It just will not do a loop with them out, which is a good thing in my opinion. They also seem to keep the speed under control in a dive and I don't feel like I am about to rip the wings off anymore. Of course you really don't even need to dive with them on, but it's good to know they help out.
Having them on the plane seems to be a little confidence boost as well. I hit a thermal the other day that was amazing how fast the plane was going up. I stayed in it much longer knowing that I had a backout plan if I needed.
Old Mar 09, 2013, 12:30 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Originally Posted by baldy View Post
aeair,
you?
Tom Unger
Yes, I did. They work fine. I put a pair of hitec HS-55s and have them on a Y cable to the left stick of the DX5e that came with the RTF. I have moved throttle to the gear switch.
They do add a degree of camber control which can be useful for thermal climb and reflex for wind penetration, as you would expect.
They do help shorten the landing with more control on location, also as you would expect. Will be helpful for ALES contest landings and for tight landings when slope soaring.
However, most of the time I fly it with the standard wing. Quick and simple to set-up and I don't have a lot of problem with landing control on the standard set-up. But for contests and tight landing areas I will use the flapped wing.
For anyone who is looking for a flapped Radian wing, the one I got from Tom is very well done. The servo pocket is routed out and the flaps are nicely hinged. I am very happy with it and would recommend his wing set-up to anyone.
Discussion Adding Spoilers to Your Radian for ALES harrye Electric Competition Soaring-F5J/ALES/e-Soaring 6 Mar 01, 2012 11:48 PM
Discussion Which Spoilers (for a Radian)? dmt Electric Sailplanes 12 May 07, 2010 08:56 AM
Discussion spoilers on radian lsb1949 Electric Sailplanes 11 Apr 11, 2010 07:46 PM
Link Radian with Spoilers RECORDCAP Parkflyers 5 Feb 25, 2010 10:17 PM
Discussion Radian spoiler/flap mods Andy W Electric Sailplanes 18 Oct 26, 2009 10:27 AM
