Old Feb 13, 2013, 07:55 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Originally Posted by kcaldwel View Post
What do you mean by "work"? It appears to still have wings...
Fortunately, on a fuselage "wing" with that low an aspect ratio the lift curve is so shallow it never really makes much lift (and therefore induced drag) before the wings stall.
Kevin
Mark Sorrell Designed the hipebipe around a wing shaped fuselage, and in doing so was able to reduce the wing area of the aircraft overall. Whether the lift is gained by ski effect or bernoulli (I"m not getting into an argument on downwash) is kind of immaterial, as the effect is certainly there.
It does work, I was making a joke.
Curare is offline Find More Posts by Curare
Old Feb 13, 2013, 10:14 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I tried to find some images of the Hyperbipe running in airshows with smoke from the engine. No luck. But I think if there were any where the plane was pulling any amount of G that the smoke would be greatly curling around the coners of that fuselage to the point where the lift it makes is rather draggy lift.
Does it lift? Most certainly. ANY body with any width will provide SOME lift. I'll bet that the lift from the fuselage of an airliner is significant. But the key is how much drag is associated with that lift. And frankly I'm willing to bet that the Hyperbipe would fly better with less "speed bleed" under high G if it had a regular streamlined fuselage.
BMatthews is online now Find More Posts by BMatthews
Old Feb 13, 2013, 11:49 PM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
As for the questions posed by the OP. I think the only good way to find out is to build a model and place one in a wind tunnel.
The second best option is to model it using CFD. But you'll still need to verify it with a wind tunnel because not many CFD programs are designed to test lifting bodies and the errors caused by assumptions made by the programmers tend to quickly build up for unconventional planforms.
slebetman is offline Find More Posts by slebetman
Old Feb 14, 2013, 08:59 AM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
That's only sort-of true. CFD isn't really limited by the shape of the object being studied, but instead by flow phenomena occurring. This is especially true for turbulence modeling, which is the main unsolved problem in CFD at the moment. Turbulence models are necessary because directly resolving all the turbulence in most practical aerospace applications would require a grid with way too many points to be solved in any reasonable amount of time. These turbulence models are validated for fairly specific flow regimes - generally like attached flow over an airfoil. The more the flow that you are simulating deviates from the validated case, the less confidence you will have in your turbulence model, and generally the less accurate it will be.
That said, a lifting fuselage shouldn't result in any flow behavior that is too unusual unless it is blunt or at high angle of attack. If it is streamlined and in the attached flow regime, the standard turbulence models should work fairly well, I would think.
Of course, I do agree that CFD does need to be validated, even in fairly "normal" flow regimes. Also, not all CFD codes are created equal. Just because you are running CFD doesn't necessarily mean your answer will be any better than something from some other method.
Montag DP is offline Find More Posts by Montag DP
Old Feb 28, 2013, 01:31 PM
ssgtakeo is offline
Find More Posts by ssgtakeo
Joined Sep 2004
Originally Posted by mouna roy View Post
hi,
i want to know how a fuselage can work as a wing?where will be the induce drag create:tipside or bottom side??? how the induce drag can be minimize?? and by which shape i can get the max lift??? plz i need help i m working on a thesis......
You're a student right? You're asking other people to do you work for you? That's integrity for you.
ssgtakeo is offline Find More Posts by ssgtakeo
Old Mar 01, 2013, 02:34 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
It's called research.
Stuart A is offline Find More Posts by Stuart A
Old Mar 02, 2013, 08:16 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
hi,
You miss the entire concept of a lifting body/device/wing.
ANY shape which creates a difference in pressure as it moves thru the air -will create lift
ANY SHAPE
Will it do it efficiently?
That is a totally different question.
The induced drag will shift as the angle at which the "shape' travels along the way --
there will always be a combination of lift and drag . as long as it is moving -relative to the surrounding air
ALWAYS
It is your job to sort out the correct shape for the particular task-
there is no one perfect shape .
richard hanson is online now Find More Posts by richard hanson
Question Blaster 2 crash, how do I repair the cracked wing and fuselage? thaysdchi Hand Launch 10 Oct 25, 2013 02:02 PM
Discussion fuselage as a wing mouna roy Auto Gyros 1 Feb 11, 2013 10:43 PM
Sold Parkzone T-28 Fuselage & Wing -- $40 + shipping jeb6684 Aircraft - Electric - Airplanes (FS/W) 3 Jan 30, 2013 08:51 AM
Sold EFLITE T-34 Mentor Parts (Wing, Fuselage, Tail) Pierat Aircraft - Electric - Airplanes (FS/W) 4 Jan 18, 2013 08:59 PM
Discussion Wing and Fuselage storage edbu1 The Builders Workshop 4 Jan 08, 2013 06:05 AM
