Closed Thread
Old Feb 12, 2013, 12:11 AM
Joined Dec 2012
Centering Servos using a digital pitch gauge.
Hello everyone.
First of all, I am a newbie.
But I think I found a neat trick for using my digital pitch gauge to help set up my servos to exactly 90 degrees.
1) Hold the DPG (digital pitch gauge) up against the side of the servo body.
2) Zero the DPG. Aligning it with the servo's body.
3) Now line up the appropriate edge of the DPG with the centerline of the servo arm. The reading shows you how close you are to a perfect 90.
Here's another trick to help make this work.
a) I stuck the tips of two toothpicks (the round kind) through a couple of well separated holes in the servo arm.
b) Next, I laid the shaft of a long hex driver against the toothpick tips. In this way the hex driver' shaft acted like an 'extension' of the centerline of the servo arm.
c) And I was then able to rest the DPG on on the hex driver's shaft.
Though I must admit, my DPG has a magnet, allowing it to cling to the hex driver shaft, making this much less awkward than it sounds.
d) Finally, remove the toothpick tips, and then put the link ball onto your servo arm.
Comments?
Maybe this has been done before?
Maybe I'm just making mountains out of molehills.
SoftSpeaker is offline Find More Posts by SoftSpeaker
Old Feb 12, 2013, 09:28 PM
Site Moderator
KrisM's Avatar
Joined Oct 2011
Sorry, but this is cross-posted. I'll leave this one open:
http://www.rcgroups.com/forums/showthread.php?t=1830135
KrisM is offline Find More Posts by KrisM
Administrator
Closed Thread
New Product Flybarless Digital Pitch Gauge for R/C Helicopter Daniel.A design Electric Heli Talk 5 May 22, 2013 03:56 PM
Sold RC Logger Digital Pitch Gauge ohsnap Aircraft - Electric - Helis (FS/W) 2 Jan 29, 2013 06:44 PM
Sold BNIB Align AP800 Digital Pitch Gauge - $30 Shipped Warren Aircraft - Electric - Helis (FS/W) 0 Jan 22, 2013 08:25 PM
Sold RC Logger Digital Pitch Gauge skeetter Aircraft - General - Miscellaneous (FS/W) 0 Jan 14, 2013 10:15 AM
Sold NIP Digital angle gauge **used to make a digital pitch gauge** Blik Aircraft - General - Miscellaneous (FS/W) 1 Dec 28, 2011 10:20 PM
