Old Feb 17, 2013, 04:58 PM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
-- unless there was thrust at some vector to stabilize it, the silly thing would simply tumble
SOMETHING must keep a non symmetrical foil from pitching .
No trim drag ?
On a more realistic note - i flew my new little VisionAire yesterday - it has 3 axis stabilization which is so well integrated that you don't even know it's there - the plane simply flies with no twitchiness and -once pointed or rolled to an attitude- remains there till you deliberately change it- uncanny!!
just like Uncle Sams multimillion dollar stuff.
The times -- they are a changing----
richard hanson is online now Find More Posts by richard hanson
Old Feb 17, 2013, 06:30 PM
b36roxs is offline
Find More Posts by b36roxs
Joined Sep 2006
edit
b36roxs is offline Find More Posts by b36roxs
Old Feb 18, 2013, 12:33 AM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Originally Posted by b36roxs View Post
Okay thats true I was thinking that lift in front of the CG would give the pitch up that reflex provides.
If the CG is far enough back then yeah, that happens. But it's not a self stabilizing sort of thing because now the CG is behind the neutral point. You can see this for yourself if you try to "fly" a simple flat wing. It'll go into a rotating tumble because this arrangement with the balance point so far behind the 1/4 chord point isn't at all stable.
BMatthews is offline Find More Posts by BMatthews
Discussion KF Swifty wing - need advice on powering this flying wing bbz Foamies (Scratchbuilt) 3 Jan 20, 2013 02:16 AM
Question Flying wing with split drag surface on tower for pitch control? kcaldwel Modeling Science 83 Jan 05, 2013 12:51 PM
Discussion How to reduce drag on a F-22 raptor? Nethole Pusher Prop Jet Models 0 Jan 13, 2007 02:23 PM
Is a flying wing generaly more drag efficeint? Mat Modeling Science 32 Dec 16, 2004 03:47 PM
Whale Wings--Increased Lift/Reduced Drag... Mikey C. Electric Plane Talk 13 May 12, 2004 08:39 PM
