Joined Jan 2007
Aft tailed designs can have their minimum trim drag with a positive stability margin. Having the lowest trim drag and a stable configuration at the same time is a great advantage.
http://aero.stanford.edu/Reports/MultOp/multop.html A stab span of about 20% of the wing span, with an aspect ratio half that of the wing, and a small positive static margin will minimize drag with an aft tail. Kevin |
Joined Jan 2007
Bruce,
Minimum trim drag does not usually occur with zero load on the stabilizer. For most aft-tailed configurations, the overall aircraft drag is actually lower with a slight down load on the stab. This occurs because the stab is in the downwash field of the wing. The interaction stab in the tilted flow field means the airplane makes less drag if it the stab lifting down slightly - the stab negative lift vector is rotated forward by the downwash. An electronic stability system doesn't have to have trim drag in the conventional sense. Let's take a plank wing design for example. If the CG is behind the wing AC (usually taken as the 1/4c), then there is fixed nose up moment at 1G unaccelerated flight. To balance this nose up moment, the electronics must control the wing Cm to provide a nose down moment. The wing nose down moment is dependant on the dynamic pressure and the wing Cm (M = Cm*c*q; q = 1/2 * ro*V^2). When flying fast, the wing only has to have a very small negative Cm because the dynamic pressure is high (the V squared term), so the flap may actually have to be reflexed on a cambered airfoil. When flying slowly (low dynamic pressure), the wing has to develop a large Cm. The flap will have to be deflected downward, making a highly cambered airfoil, which is what you want for low speed flight. Of course this set-up is pitch unstable with out the electronics to artificially provide stability. If properly designed, the minimum airfoil drag for a given airspeed can occur with the average camber setting required for moment balance. This means the trim drag is basically zero, and the airfoil camber is optimized for the airplane speed. This can be done without any CG shifting. Conventional sailplanes use airfoil camber changing to optimize the airfoil for the flight speed as well. They use their powerful stabilizer to balance the wing moment changes with minimum drag. Kevin Quote:
Kevin,
I agree (and Ilan's chart is a lot to digest!). All I was trying to suggest is that trim drag does not inherently improve longitudinal flying qualities. It's interesting from the chart that for an aft-tail design with a span ratio of about 3 to 1, the static margin for minimum drag (about 8% or so) also happens to be a good choice for longitudinal flying qualities! |
In the case of the "flying wing"- which has no other device than it's own shape - the shape must obviously be such that it will hold this desired angle that's trim /trim drag- - can't avoid it calculate all you like - it has to be . |
Also, I don't get why people started arguing about the impossibility of eliminating trim drag. Of course it's impossible. But that is not the topic of this thread. It's about REDUCING trim drag. Specifically for flying wings. And it's definitely possible with the right airfoil design and careful CG positioning (and perhaps some active stabilization to make the wing flyable at a CG that has minimum trim drag). Compared to a competition thermal duration wing, sure, you can't improve much because they've already been optimized to have minimum drag (in fact, doesn't their existence prove that it can be done?). Compared to a Zagi or Assassin you can certainly make significant improvements. |
I have seen an RC oblique flying wing fly. It used AOA feedback for longitudinal stability (and several servos per elevon to ensure enough bandwidth). Its maiden flight was quite smooth (sweep was increased beyond 45 degrees). All without any trim drag (well under certain conditions anyway).
http://www.b2streamlines.com/Morris.html |
| Thread Tools | |
| Discussion KF Swifty wing - need advice on powering this flying wing | bbz | Foamies (Scratchbuilt) | 3 | Jan 20, 2013 02:16 AM |
| Question Flying wing with split drag surface on tower for pitch control? | kcaldwel | Modeling Science | 83 | Jan 05, 2013 12:51 PM |
| Discussion How to reduce drag on a F-22 raptor? | Nethole | Pusher Prop Jet Models | 0 | Jan 13, 2007 02:23 PM |
| Is a flying wing generaly more drag efficeint? | Mat | Modeling Science | 32 | Dec 16, 2004 03:47 PM |
| Whale Wings--Increased Lift/Reduced Drag... | Mikey C. | Electric Plane Talk | 13 | May 12, 2004 08:39 PM |
