Old Feb 11, 2013, 05:16 PM
flamer is offline
Find More Posts by flamer
Joined Nov 2010
replace flex cable too much slippage
Hi guys, my large boat has a very torquey motor, and its designed to drive through the ocean, through swells and through currents etc. It works very well (plenty of power) however after a few minutes the flex cable starts to slip in the collet. The collet stays on the motor shaft just fine, its the flex cable that is slipping heaps. The cable is now getting crushed by the amount I have to tighten it and I think its time to replace it anyway. it was silver soldered too.
What I want to do instead is, buy a square end flex cable 1/4" weld the round end onto a prop shaft and then use the square end to connect to the motor.
I have not seen too many collets for this though, so any suggestions on where I could get one would be appreciate. so the flex cable is 1/4" and the motor and a 6mm solid round shaft.
flamer is offline Find More Posts by flamer
Old Feb 12, 2013, 08:09 AM
highflyerbill is offline
Find More Posts by highflyerbill
Gordonsville,Virginia
Joined Nov 2009
I would first try one of the aeromaine laminates couplers I have found them to be the best around . www.aeromarinerc.com
highflyerbill is offline Find More Posts by highflyerbill
Old Feb 12, 2013, 09:38 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Make sure there isn't too much solder where the collet is grabbing as well, that will make it slip worse. You want just enough at the tip to stop it from unraveling.
wparsons is offline Find More Posts by wparsons
Old Feb 12, 2013, 06:44 PM
flamer is offline
Joined Nov 2010
There isn't too much solder on it, to be honest I was using it without solder and it was slipping, so I added the solder to the tip later which didn't make any difference.
aeromarine seems to be down at the moment, the biggest problem I have is there are very few collets that fit my setup, took me AGES to find the one I currently have I would not be surprised if its the only one made to my specs. I could go down a size in the flex shaft which would give me more options, but the size of the motor (airplane outrunner) and the prop (900mm 4 blade) I am not sure that would be a wise thing to do.
Old Feb 12, 2013, 11:34 PM
CornelP is offline
Find More Posts by CornelP
CornelP's Avatar
Bucharest, RO
Joined May 2009
Give it a try with this one:
http://mbp-rc.de/collet-clutches-6-x-63-SZK
CornelP is offline Find More Posts by CornelP
Old Feb 13, 2013, 04:27 AM
paultbg is offline
Find More Posts by paultbg
paultbg's Avatar
United Kingdom, England, Birmingham
Joined Jul 2012
Depending on the size of the motor shaft / flex cable you can use either this one:
http://www.ebay.co.uk/itm/2810618048...84.m1558.l2649
or this one
http://www.ebay.co.uk/itm/2810614384...84.m1558.l2649
Regards
paultbg is offline Find More Posts by paultbg
Question How much is too much? CarPainter Composites Fabrication 9 Feb 03, 2013 12:33 PM
Discussion Wing flex, when is too much flex ? StewieRC Electric Plane Talk 17 Jul 15, 2012 09:17 AM
Question How much is too much wing flex TXTATE Foamies (Scratchbuilt) 6 Sep 21, 2006 11:24 AM
Matt S: Any BT mods for this new heli? blades flex too much Norb Electric Heli Talk 6 Mar 04, 2005 06:37 PM
Tiger Moth pushrod flexes too much..Help, Please DavidJ Parkflyers 15 Jan 08, 2003 09:10 PM
