Old Dec 28, 2003, 05:08 PM
jimsky is offline
Find More Posts by jimsky
Trying to defy gravity...
jimsky's Avatar
USA, NY, East Northport
Joined Dec 2003
NiMH Self-Recharging Effect???
OK, pulled off my first real day of flying today with my Slow Stick. I was able to run a Powerizer NiMH battery pack (8 cell @ 1100maH) down until the ESC shutoff. Must have flown for about 20 minutes with varying throttle settings.
Wanting to know what the actual cutoff voltage was I measured the battery voltage when I got home, but found the battery "self-recharged" and it read 10.38 volts using a high impedance digital handheld volt meter. I know some capacitors can have a self recharge effect, but is this behavior typical for NiMH batteries?
jimsky is offline Find More Posts by jimsky
Old Dec 28, 2003, 05:29 PM
flatfour is offline
Find More Posts by flatfour
Right Honorable Member
flatfour's Avatar
Chicago Midway, Illinois, United States
Joined Jul 2003
Yes, this is typical for NiCd and NiMh cells.
If you try to run the pack again without recharging, you will find it quite dead.
If you want to know the cutoff, you will have to connect a meter while the motor is running. The voltage will jump up quickly after the load is removed.
flatfour is offline Find More Posts by flatfour
Old Dec 28, 2003, 06:08 PM
jimsky is offline
jimsky's Avatar
Joined Dec 2003
Thanks, for the quick answer.
Old Dec 29, 2003, 02:31 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
It's not really "recharging" it's just that the high load current drags the battery voltage down. When the load is removed the voltage recovers but the battery still has very little charge in.
That's just one of the reasons why you can't tell how much capacity is left in a battery by measuring the voltage .
Steve
steve lewin is offline Find More Posts by steve lewin
Question NiMh self-discharge zippogeek Batteries and Chargers 2 Jun 04, 2003 06:46 PM
NiMh self discharge - how long? bernie01 Batteries and Chargers 1 Feb 22, 2003 03:29 AM
