Old Mar 06, 2013, 11:46 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Originally Posted by 706jim View Post
Cool. Almost sounds like a twin cylinder outboard motor.
Not quite like it
2 cylinder nitro rc outboard, vintage glow engine,toy motor (0 min 59 sec)
coriolan is offline Find More Posts by coriolan
Old Mar 06, 2013, 11:56 PM
706jim is offline
Find More Posts by 706jim
Canada, ON, Thunder Bay
Originally Posted by coriolan View Post
Not quite like it
http://youtu.be/-LinuIVQRXw
Believe it or not, I have the IDENTICAL engine to yours that I picked up over 40 years ago. I ran it once and knocked one of the propeller blades off when it touched the gunwale of the aluminum boat I was launching the model from.
Probably the MOST amazing thing about this is that I FOUND the broken blade (still have it!) and hope to JB weld it back onto the prop hub.
But what are the chances that we would own the same engine?
706jim is offline Find More Posts by 706jim
Old Mar 07, 2013, 12:07 AM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
This engine isn't mine I had an Allyn .049 as a kid and ran it in a 20" hull, not very fast but was impressive back then. Since then I have build build a few 1/2A boats but only inboard. I don't think JBWeld would hold for a broken prop, you could probably adapt a small Octura prop to the Allyn more easily.
Old Mar 07, 2013, 10:39 AM
706jim is offline
And I own THAT engine as well! It actually ran quite well but this was before the days of affordable R/C, so the boat it powered was sort of "free flight".
I'll post a photo of the two of them once I remember how to do it.
Old Mar 07, 2013, 04:43 PM
AirplaneFreak100 is offline
Find More Posts by AirplaneFreak100
as the name says!
AirplaneFreak100's Avatar
Barbados
Joined Sep 2012
micro outboards
hard to believe
AirplaneFreak100 is offline Find More Posts by AirplaneFreak100
Old Mar 07, 2013, 05:40 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
There was quite a few small outboard in the 50's, Allyn "Sea Fury"/Fuji/WenMac/SuperTigre etc...
http://www.modelenginecollecting.com...-outboard.html
http://www.rojobcn.com/technic/barco/supertig29.htm
And #130 which is a home made build based on Cox TD .010:
http://www.craftsmanshipmuseum.com/KnappCol.htm
Most can still be found on the bay
Old Mar 07, 2013, 06:34 PM
as the name says!
Barbados
Joined Sep 2012
how do they run i mean like get the prop to p
spin perpendicular to cylinder direction?
is there a tube on the inside?
Old Mar 07, 2013, 07:05 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
Some uses bevel gear(Allyn,SuperTigre,Faden) other have a cable or just a spring like the WenMac!
Old Mar 08, 2013, 12:37 AM
Brutus1967 is online now
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
Originally Posted by AirplaneFreak100 View Post
micro outboards
hard to believe
Believe it...
New fuel, original prop, lowered motor (0 min 0 sec)
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Mar 08, 2013, 12:44 AM
Reginald is online now
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Fuji, Atwood...the twin was an in-outboard and yes, that Wen-Mac Mk-2 is an original factory drive unit
Reginald is online now Find More Posts by Reginald
Old Mar 08, 2013, 12:51 AM
The Netherlands
Joined Nov 2009
WOW... how was that Wen-Mac supposed to work?
I do not see a V-groove for starting, no idea how that shaft would go through a sealed stern tube without leaking.... and the prop seems to be a bit big for the engine?
Really curious, me....
Brgds, Bert
Old Mar 08, 2013, 05:48 AM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I think they used the same method they used to start tether cars. By flipping the flywheel like it was a tether car tire connected to the engine. Now one could probably use a old leather belt strap too.
earlwb is offline Find More Posts by earlwb
Old Mar 08, 2013, 05:54 AM
Reginald's Avatar
Belgium
Joined Aug 2004
That's right. This version is the Wen-Mac Aquamite model 4, see page 241 of the AM Encyclopedia
Old Mar 08, 2013, 06:37 AM
The Netherlands
Joined Nov 2009
that would be very informative, if I had any Idea how tether-cars were started.
But unfortunately, I only know they exist(ed). Over here in Europe, I elieve they have never been really widespread, and I have not even seen one IRL even on shows, meetings or other displays.
Brgds, Bert
Old Mar 08, 2013, 08:59 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Brgds, Bert
You can see them spinning/flipping the rear driving wheel on some of the cars in these videos. Another method was a old gas engine with a rubber wheel/tire bolted onto it and they use it as a bump starter. The cord method was using a cord or leather strap and using both hands with it wraped around the flywheel to pull on it to start the engine. Also for cars they would use a broomstick handle and push the car to start it. The cars were direct drive, no clutch.
Old Rail car racing from the 1940's.
http://www.youtube.com/watch?feature...v=cEocgbNdMNM#
http://www.youtube.com/watch?NR=1&fe...&v=_JJi2tm2u9A
Cool SUPER SMALL ENGINES (and turbines)! INCLUDING WORLD's SMALLEST AirplaneFreak100 1/2A Planes 69 Apr 09, 2013 07:29 AM
Discussion World's Smallest 3channel Helicopter stusvend Coaxial Helicopters 1 Jan 29, 2013 11:02 PM
For Sale World Models P47 Brushless factory motor included! fnlrun Aircraft - Electric - Airplanes (FS/W) 8 Jan 24, 2013 12:42 PM
Discussion World's smallest engine? PeteSchug Scratchbuilt Indoor and Micro Models 13 Nov 01, 2011 02:36 AM
The World's Smallest Inline Diesel Engine aerogel Scratchbuilt Indoor and Micro Models 14 Jun 06, 2005 02:47 PM
