Old Feb 11, 2013, 11:41 AM
bladeskiller is offline
Find More Posts by bladeskiller
Athens
Joined Aug 2008
Unusual problem with Hitec HS-325
Last weekend i had an unusual problem with the throttle servo of a calmato trainer plane. The servo was a new (out of the box) Hitec hs-325. During fourth flight ,when i gave full throttle to make a loop ,i realized that my engine had stoped responding to my commands. After making planty off cyrcles to burn up the fuel ,i landed the plane safely. Investigation showed that throttle servo was dead. It was not jammed like having stripped gears, just dead.
After returning home i opened up the servo. No stripped gears and no sign of fried electronic components. So i unsoldered the motor of the PCB and tried to power sypply it using a NIMH battery. No move. I supposed it was fried but my multitester showed opencircuit instead of shortcircuit ,which is the usual sign of a fried motor. I thought that brushes were worn out ,so i opened up the motor. What i found was that the brushes and the collector were in perfect contition ,so the problem could not be worn out brushes. I decided to use my multitester directly on the collector sectors to find out that the rotor windings had lost their connectivity. The winding terminals seemed to be well soldered on the collector sectors. No sigh of a broken wire but no sigh of connectivity as well.
Now ,the only thing i can suppose is that the winding wire either was cold-soldered on the collector terminals or it was soldered without removing the winding-wire insulation properly. So ,although that initially it was fine ,after a few flights the winding wire lost its connectivity with the collector sectors.
I use Hitec hs-325 servos for many of my planes and one of my nitro helis ,all of them having many hours of flying and i have never experienced any kind of problems. It is the first time i have an issue using hs-325 (fortunately the throttle). I was considering Hitec servos as very good servos but after that ,i am really concerned. I remind that it is not a classic problem of a fried motor or a fried motor drive. After investigation It is clear that there is a bad soldering issue.
The question is. Is it an isolated incidence or there is something wrong with quality control of newer batch of Hitec servo motors? Who knows?
bladeskiller is offline Find More Posts by bladeskiller
Old Feb 11, 2013, 12:22 PM
ChillPhatCat is offline
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
I would not say there's anything wrong with the servos, it just sounds like you got a lemon there... One anecdotal tale doesn't spoil the bunch. I have a couple 325's and they work fine, and I've had a bunch of HS servos in general and never had one die from normal operation. Sometimes there are failures and you just can't predict, every plane has an expiration date.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Feb 11, 2013, 09:17 PM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
You should have sent the servo back I'd bet they'd have sent you a new one back to HiTec I mean
jetmech05 is offline Find More Posts by jetmech05
Old Feb 11, 2013, 10:49 PM
exf3bguy is online now
Find More Posts by exf3bguy
exf3bguy's Avatar
United States, CA, Sacramento
Joined Oct 2011
How much quality control are you expecting them to do on a 15.00 servo? Consider it lucky if they batch test 1 out of 100.
exf3bguy is online now Find More Posts by exf3bguy
Old Feb 12, 2013, 03:19 AM
Athens
Joined Aug 2008
@ jetmech05
We are talking about a 17 euros servo. It would be more costly sending it back to Hitec service than just buying a new one. Furthermore, as an electronic technician , i had the curiocity to find out by my shelf what exactly was the cause of the failure.
Given that such an issue into the motor could not be a result of misusing, i decided to crosscheck if it's a known issue or it's just a piece that "escaped the net" of Q.C.
@exf3bguy
I expect that they have better Q.C. than identical (on paper only) specifications cheap Chinese servos, offered in 1/3 of the price. And ,to be honest they have. As i have written before ,i have used hs-325 on many of my models for years without any kind of issues and only one of them proved to be a so called "lemon". On the other hand ,i had tried in the past some cheapo servos that gave me tons of "lemonade". .
Old Feb 12, 2013, 11:49 AM
AMA 537620
Joined Oct 2008
That's normal price for most standard servos, which doesn't point to bad QC. Also, you can't expect them to test every swervo either, 1/100 tested would be a pretty good rate... I doubt even $100 - $200 servos are tested any more frequently... In fact, I doubt they test more than 1/1000 for most servos.
Discussion Hitec HS-75BB jitters with AR8000 hack_1979 Radios 6 Mar 25, 2013 10:09 AM
Sold Hitec servos , HS-55 . HS-56 & HS-5245 Dennis Everett Aircraft - General - Radio Equipment (FS/W) 2 Jan 11, 2013 11:44 PM
Sold 2 Brand New In Box Hitec HS-5625MG Servos with Blue Servo Arms $75 Shipped Mahu Aircraft - General - Radio Equipment (FS/W) 5 Jan 09, 2013 08:59 PM
Sold 3 Hitec HS-5625MG Servos with Blue Servo Arms Like new $85 Shipped Mahu Aircraft - General - Radio Equipment (FS/W) 4 Jan 06, 2013 12:33 AM
Sold Pica Pitcheron N.I.B. $325.00, now with 2 Hitec Hs 85Mgs checkenbach Aircraft - Sailplanes (FS/W) 6 Oct 06, 2010 01:30 PM
