Old Feb 24, 2013, 10:12 AM
invertmast is online now
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Air loads from flying will also cause the gear transit time to change, sometimes preventing it from locking completely
invertmast is online now Find More Posts by invertmast
Old Feb 25, 2013, 12:14 PM
StarHopper44 is offline
Find More Posts by StarHopper44
United States, NC, Richlands
Joined Jun 2011
While studying the situation yesterday, I spotted something that just might be the culprit. Where the air tube afixes to the holding tank, immediately off the tip of the metal nipple the tube was kinked rather smartly where it turns & runs the opposite diection. Gonna pull some slack back towards it & tape a section to a bulkhead or maybe side of the tank & test 'er again.
StarHopper44 is offline Find More Posts by StarHopper44
Old Feb 25, 2013, 03:26 PM
Cougar429 is online now
Find More Posts by Cougar429
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
If you have enough tubing cut that kinked portion away and work with a good area of tubing. That kink is now set and will likely try to close again.
Cougar429 is online now Find More Posts by Cougar429
Old Feb 25, 2013, 04:50 PM
Joined Mar 2004
If these are spring down retracts, the kinked supply line isnt going to change anything
Old Feb 25, 2013, 05:49 PM
Cougar429's Avatar
Canada, ON, Windsor
Joined Apr 2008
I'm suspecting there may be other kinks.
Old Feb 25, 2013, 07:16 PM
Joined Mar 2004
That would make more of an issue for the gear going up as well. If they are spring down, the air pressure is released to the atmosphere at the valve, not returned to the storage tank. So if they were kinked, you would see slower retractions as well.
The spring down function is normally pretty stout to ensure a positive down lock, as that is the only way to get the positive lock.
Personally, if the original owner loosened the nose gear unit to allow slack in the steering lines to get the nose gear to lock down, it needs to be re-tightened correctly and new steering pull pull lines made. They should only be tight enough to allow positive steering and nosd banjo string tight like you would do on a rudder or elevator pull pull cable setup
Old Feb 26, 2013, 05:30 AM
Joined Jun 2011
Hmmmm. Well, thanks for that insight IM -- I know so little about these things I don't know what's happening (inside) going up OR down so....any info's a learnin' experience for me!
I'll say this. First time I saw the gear operated (& every time since) I thought it kind've unique to anything I'd seen before. Namely, there's a noticeable delay of 2-3 seconds before anything happens, then they retract 1-2-3 ie almost each one individually. This with starting pressure of 115# which is what OO advised. Down's pretty much a solid THUNK - which makes me wonder even more why that dang nose isn't firmly locking.
We've got a spell of bad weather coming in so no flying for at least next few days. I'll make an effort to get a video shot of the ops & post up for reference - maybe seeing 'em in action will tell it much better than I can explain.
But again, big thanks to you all for the info being provided; it's sincerely appreciated!
Old Feb 26, 2013, 06:12 AM
Joined Mar 2004
The one two three is a setup thing. The gear is going to retract in an order that begins itu the shortest air line, them the next shortedt, etc etc.
Discussion Noob is being noob (annoying for sure) bonesaw618 Multirotor Talk 10 Jan 26, 2013 12:31 PM
Sold Robart 654 Nose Gear Strut $40 Bucks Shipped FlyBoyTha1 Aircraft - General - Miscellaneous (FS/W) 0 Jan 13, 2013 12:26 PM
Wanted Robart Retracts windsock23400 Aircraft - General - Miscellaneous (FS/W) 0 Jan 13, 2013 12:13 AM
Wanted Robart 1/4 Balsa USA Cub #690B Ice Aircraft - Fuel - Airplanes (FS/W) 3 Jan 07, 2013 05:48 PM
For Sale Ryan STA Oleos From Robart.... Gost Rider Aircraft - General - Miscellaneous (FS/W) 1 Jan 04, 2013 10:53 AM
