Old Feb 11, 2013, 05:59 AM
asaak is offline
Find More Posts by asaak
asaak's Avatar
Joined Mar 2012
Landing gear skywalker 1900...always break..don't know what to do!
Hi!
I have a skywalker 1900. My first landing gear was a carbon fiber one from hobbyking. The weight of the plane is around 3 kgrs . The landing gear broke on a landing ( The part close to the wheel is the most fragile ). Then I did one using an aluminum bar...but again broken. Yesterday I went to fly and again the same happened., It wasn't a smooth landing but it wasn't a hard one either. However, the same, the aluminium bar bends. I don't know what to do. Do you think I must remove the landing gear and throw it by hand? It is 3 kgrs...and I am afraid It is not going to be an easy way to take off...I am not considered a bad pilot rather I think the kind of aluminium bar I use for the landing gear is too soft.
What do you think? Do I have to remove the landing gear??
I will post pictures from the landing gear later.
asaak is offline Find More Posts by asaak
Old Feb 11, 2013, 06:25 AM
asaak is offline
asaak's Avatar
Joined Mar 2012
This is the carbon fiber one:
This is the aluminum one :
As you can see I also put a rod throw the two parts of the landing gear..but even with this it bends, and it even pop up from the wood part that it is glued to the fuselage.
Old Feb 11, 2013, 07:28 AM
asaak is offline
asaak's Avatar
Joined Mar 2012
This is the result of a landing on a soft grass field
Uploaded with ImageShack.us
Old Feb 11, 2013, 08:47 AM
modelerchina is online now
Find More Posts by modelerchina
Canada, ON, Mississauga
Joined Apr 2006
belle landing
modelerchina is online now Find More Posts by modelerchina
Old Feb 11, 2013, 08:49 AM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Why bother. Just belly land.
blueprint is offline Find More Posts by blueprint
Old Feb 11, 2013, 10:11 AM
raRaRa is offline
Find More Posts by raRaRa
Joined Nov 2010
Land more smoothly!
raRaRa is offline Find More Posts by raRaRa
Old Feb 11, 2013, 10:14 AM
asaak is offline
asaak's Avatar
Joined Mar 2012
I think it has something to do with the aluminium I use, I think it is too soft. I've seen users from this forum with the same type of landing gear and it does not suffer as much as mine.
Old Feb 12, 2013, 05:02 PM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
My SW is about 2.2kg and u can launch it with my left non master hand easily. It flys out of my hand most times! But I'm running a 3536 1400kv SK motor with a 9x6 prop and 60amp ESC all on 4s 5000mah and its totally over powered but I'd prefer more power than not enough and cruising at about 45-55kph on 6-7 amps is awesome.
Have you tried a simple straight axel with slightly bigger wheels?? I've seen alot of guys on here doing that, try the search function for SW landing gear and it should bring up alot of threads I reckon.
Teamsherman is offline Find More Posts by Teamsherman
Old Feb 12, 2013, 07:07 PM
Meez is offline
Find More Posts by Meez
3D Crazy
Meez's Avatar
Putrajaya, Malaysia
Joined May 2010
use piano wire because it's flexibility and robust. If you hard landing, it just bent and easy to repair. I use it on all my SW's (3 so far). Can't remember the size in inches, hard for us to remember because we use metric. I think diameter around 3.5 or 4mm............
Dont bother to harden it because most important thing is your fuse still save from hard landing.
Meez is offline Find More Posts by Meez
Old Feb 13, 2013, 12:03 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
I use piano wire. Then I braced it with springs and cord. It will take any landings I can throw at it.
ashdec87 is offline Find More Posts by ashdec87
Old Sep 02, 2014, 01:16 AM
Depronicus is online now
Find More Posts by Depronicus
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
Of course. There's no reason for that plane to have any bothersome, unnecessary landing gear.
It's very similar to an EasyStar, and they have no landing gear at all.
Hand-launch it, and belly it in.
Depronicus is online now Find More Posts by Depronicus
Careful! TREX 600- 1 side of landing gear breaks off mid flight - HOLY ^&*# WHAT DO I DO NOW? djdaveq Electric Heli Talk 12 Sep 19, 2007 06:33 PM
What happens if you don't know what you're doing when towing.... 96S14 Scale Sailplanes 5 Nov 22, 2004 02:22 PM
