Old Feb 10, 2013, 10:21 PM
Dave180 is offline
Find More Posts by Dave180
Joined Dec 2012
C grain balsa
Hello. I'm scratch building a GLH. They call for 3/32" C grain balsa all empennage for the tail. I see it for sale at Sig Mfg. I don't like the shipping charges/ oversize box fee's. What would be the best alternative to using this? I'm going to look up the word empennage because I don't know what that means.
Dave180 is offline Find More Posts by Dave180
Old Feb 10, 2013, 10:25 PM
Dave180 is offline
Joined Dec 2012
Ok empennage means tail feathers of an aircraft. Learn something new every day.
Old Feb 11, 2013, 01:16 PM
planeman is offline
Find More Posts by planeman
High Exalted Poohbah
planeman's Avatar
Atlanta, GA USA
Joined Sep 2001
If you only need a sheet or two, try the large box craft stores like Hobby Lobby and Michael's. They usually have a pretty good balsa display. I would call first to make sure before I wasted my time though.
I assume you know "C" grain balsa when you see and feel it.
Planeman
planeman is offline Find More Posts by planeman
Old Feb 11, 2013, 08:11 PM
Dave180 is offline
Joined Dec 2012
I have both those stores nearby. I'll check them. I didn't see any at the regular hobby shop. I assume they're suppose to label it. I usually just go through what they have and look for something stiff with heavy grain patterns. But it would be nice get C grain. I could just do some lamination cross grain.
Edit: I did 1/32" plywood to 3/32" balsa. Its pretty stiff. Used 15 minute epoxy and a hair dryer to thin it out. Probably more heavy but who cares.
Old Feb 12, 2013, 03:14 AM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
http://www.specializedbalsa.com/bals...sification.php
Where are you located and how much do you need?
Kimber is offline Find More Posts by Kimber
Old Feb 14, 2013, 12:44 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
'SEE' grain
"C" grain is 'speckled'- if you didn't know-very little straight grain.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Feb 14, 2013, 09:35 PM
packardpursuit is online now
Find More Posts by packardpursuit
Joined Jan 2009
C- grain is indeed "speckled". However it also fits the criteria for "vertical grain", so the grain is infact the straghtest/strongest available for a given weight density (pounds per cubic foot). Light Balsa is 4-6 pound range, while medium, is usually around 8 lbs per cubic foot. 12 lb is rock hard, but the strongest. Anyone wishing to understand balsa and its application to model aircraft should Google Sig's explanations and charts. They have been linked here many times.
I've never seen a local retail outfit that sells balsa provide a grading system. 99.9 x's out of 100 hobby clerks won't have a clue.
packardpursuit is online now Find More Posts by packardpursuit
filling balsa grain after primer for vaccume forming RCFlyer55 The Builders Workshop 8 May 01, 2005 04:51 PM
Filling balsa grain - what's state of the art? asennad The Builders Workshop 3 Oct 10, 2003 10:04 AM
Questions - balsa grain, notching ribs, and round formers dimple The Builders Workshop 3 Apr 08, 2003 11:16 PM
Best grain filler/primer for painting balsa? All__talk Electric Plane Talk 9 Feb 27, 2002 01:14 PM
