Old Feb 10, 2013, 09:07 PM
duker733 is offline
Find More Posts by duker733
Joined Nov 2012
Question
Which receiver should I use?
Just picked up a used Hangar 9 P-47 Thunderbolt with a Saito 125 Golden Knight engine. So stoked!!
Need to put a Spektrum receiver in it. I have a DX8.
Not sure of which one I should use? It does have retracts as well, so I guess it'll need at least 5 channels.
What's the difference between these 2?
Spektrum AR600 6-Channel Sport DSMX Receiver
Spektrum AR6210 6-Channel DSMX Receiver
Would one of these be better to use than the other? Not sure.
Here's a picture of it
duker733 is offline Find More Posts by duker733
Old Feb 10, 2013, 09:10 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
6210 is a better choice IMHO.
Old Feb 12, 2013, 04:23 PM
F16DCC is offline
Find More Posts by F16DCC
United States, NM, Holloman AFB
Joined Oct 2007
Go with the 6210 since it also has remote receiver so will have less chance of signal loss. The 600 that I had liked to loose signal from time to time for a few seconds. Luckly that was in my trainer and each time I was able to recover.
F16DCC is offline Find More Posts by F16DCC
Old Feb 12, 2013, 04:37 PM
duker733 is offline
Joined Nov 2012
6210 it is thanks guys!
Old Feb 13, 2013, 02:53 AM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Great buy there, The 125 should yank that plane around pretty good. A guy at our field flies one of those with a SA91 in it and it does spirited scale flight.
scootrb4 is offline Find More Posts by scootrb4
Old Feb 13, 2013, 11:26 AM
Chip01 is offline
Find More Posts by Chip01
United States, TX, Weatherford
Joined Dec 2006
Also make sure you are using a 5 cell battery (6Volt battery) or better. You reduce the risk of browns, or receiver drop out caused by the battery voltage dropping to low. Make sure the receiver battery is at least a 1000 milliampere hours in capacity, I would even suggest more is better. It is a cheap expense when you consider that the life of your airplane depends on the receiver battery. You can run out of fuel, have an engine die and dead stick it home. But if the battery dies, or you receiver does not get enough voltage to work and the servos do not have enough power to work, then you are out of control. So quite possibly the receiver battery is the most important element in your airplane.
Chip01 is offline Find More Posts by Chip01
Old Feb 13, 2013, 02:34 PM
F16DCC is offline
Joined Oct 2007
Ahmen to that! After a friend lost a plane due to not enough juice in the battery I've always ran over kill with 3000mah minimum, and now with my digital servos I run a 4500mah LiFe.
Old Feb 13, 2013, 04:21 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Yea I love the LiFe packs too. Plenty of power ability and lighter than NiCad/NiMh.
And running at 6v is nice as well for speed and torque of the servo.
Old Feb 13, 2013, 11:02 PM
duker733 is offline
Joined Nov 2012
I am running a spektrum 4.8v NiMh 1500 mah battery. I cannot go up to 6 volt because my JR 791 servo for the retracts says 4.8v max. So I hope this is sufficient.
Old Feb 14, 2013, 09:33 AM
F16DCC is offline
Joined Oct 2007
You'll be fine, you'll just need to charge it after every 2 - 3 flights depending on what kind of servo's you're running and if they bind up or not.
Or buy a new retract servo rated at 6v and get a LiFe battery of substantial mah and never look back.
Discussion Which PnP Quadcopter should I go with? casualsunday Multirotor Talk 6 Feb 02, 2013 04:33 PM
Discussion Which battery should I try first? highflyer38 Power Systems 3 Jan 28, 2013 07:13 PM
Question Help, which system should I buy for a 3d Ian123456 Electric Motor Design and Construction 5 Jan 20, 2013 02:49 PM
Discussion Which route should I go? Telechat Micro Helis 3 Jan 20, 2013 09:30 AM
Discussion Which receiver should I use for a weasel? Noobs r us Slope 9 Jan 27, 2008 07:38 PM
