Old Feb 10, 2013, 01:47 PM
xzodiackxs is offline
Find More Posts by xzodiackxs
Joined Jun 2012
Upgrading from a glow trainer ( alpha 40 ) to a performance plane .
I had my alpha 40 for a while and I can do some aerobatics ( loops , rools , inverted ) and I'm able to do some extremely good 3D hovers and I would like to upgrade to a more performance wise plane , I'm currently looking at the Hangar 9 Sundowner 50 and then hopefully moving on to 3D .
Do you guys think moving on from alpha 40 to Sundowner 50 is a good transition to sport planes ?
xzodiackxs is offline Find More Posts by xzodiackxs
Old Feb 10, 2013, 02:41 PM
Kyler1 is offline
Find More Posts by Kyler1
United States, SD
Joined Aug 2010
I would get a low wing "trainer" type before I would get a all out 3D plane. A plane like an Escapade, Four Star 40, H9 twist, are all great 2nd planes. A twist might be the best if you want to start some 3D.
Kyler1 is offline Find More Posts by Kyler1
Old Feb 10, 2013, 02:56 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
3DHS Slick is a great sport plane that will transition well to 3D as well.
I agree the Sundowner is NOT the best plane for 2nd. It will not 3D at all.
Old Feb 10, 2013, 02:57 PM
gene6029 is offline
Find More Posts by gene6029
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
I have a Twist & have had several different size motors on it over the years so it has a wide flight envelope from mild to wild. It will fly great on a 40- 55, 2stroke or 56-82 four stroke. Easy to transport in one piece. Takes off in allmost zero rollout, and can land in just as small a spot. I'd say that would be a good choice.....Gene
gene6029 is offline Find More Posts by gene6029
Old Feb 10, 2013, 02:58 PM
Joined Jun 2012
I"m don't want to transition to a 3D plane right now , just a fast and nice aerobatic plane like a sundowner .
Old Feb 10, 2013, 03:49 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
The Sundowner is NOT a aerobatic ship - it is a fast, plyon type racer.
If you want a nice aerobatic plane the the Sig Four Star would be my recommendation. The Ultra sticks are also a blast. Another good choice would be the Pulse series.
Old Feb 11, 2013, 05:31 AM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Originally Posted by pda4you View Post
...Another good choice would be the Pulse series.
My second plane is a Pulse 125 with a DLE 20 - a great mix.
grosbeak is offline Find More Posts by grosbeak
Old Feb 11, 2013, 06:55 AM
whiskykid is offline
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
if your looking at getting into 3D at all, then I would suggest atleast getting into a 30cc size plane!
this is just my opinion,but it seems to me, that 30cc is where planes seem to start getting close to a 2 too 1 power to wieght ratio, which is what you are looking for, when looking at a 3D plane!
ok with that said,a well set-up 3D plane,(with a mild set-up 12* ta 15* on most flying surfaces)will fly better and easier then most trainers!
I would start building say like a 30cc MXR, SBACH,or even an EXTRA 260, start off with a mild set-up, if you are able to take off and land, with a four channel high wing aircraft, then you should be fine with a modern airfcraft!
of course, this is all irellivant, if you don't plan on flying, larger aircraft, of atleast 30cc size aircraft!
whiskykid is offline Find More Posts by whiskykid
Old Feb 12, 2013, 10:51 AM
F16DCC is offline
Find More Posts by F16DCC
United States, NM, Holloman AFB
Joined Oct 2007
The aircraft I always recommend for a second is the Stinger II by Great Planes. It is a VERY nice sport flyer with no bad tendencies. The wing loading is light, so landings are only a tad hotter than that trainer (which I used to have an Alpha 40 as well). The control surfaces are very large and when put on full rates and increasing the elevator to 1 1/4" deflection it becomes a 3D aircraft with ease. If you're wanting 3D with it make sure to get a 55AX so you can swing a bigger prop. Mine has a 46AX with 11x6 and will do harriers all day long but wont hang the prop very well due to lack of power. But I wanted mine for sport flying and it does every maneuver I can throw at it, and it does them very well.
F16DCC is offline Find More Posts by F16DCC
Sold Alpha 40 Trainer with OS 40FP - Toledo Show Pick Up Farwell Aircraft - Fuel - Airplanes (FS/W) 3 Mar 28, 2013 10:20 PM
For Sale Hangar 9 Alpha Trainer .40 - RTF (RTF) KwilliamsFLA Aircraft - Fuel - Airplanes (FS/W) 1 Feb 10, 2013 05:05 PM
Idea GoPro/Alpha 40 Trainer RTF trimble95 Fuel Plane Talk 4 Jan 15, 2013 02:12 PM
Which plane? Moving from 40-size Hangar 9 Arrow glow plane OakenGoby Parkflyers 10 Oct 16, 2005 10:47 AM
Skyward - 40 Glow trainer from 1993 finally built and electrified :) KreAture Electric Plane Talk 36 Jul 25, 2005 04:06 PM
