Old Feb 10, 2013, 11:36 AM
sweatybetty is offline
Find More Posts by sweatybetty
sweatybetty's Avatar
United States, OR, Roseburg
Joined Jan 2012
tower coat
anyone tried it? results?
thanks
sweatybetty is offline Find More Posts by sweatybetty
Old Feb 10, 2013, 02:41 PM
pd1 is online now
pd1
Find More Posts by pd1
pd1
United States, MA, Haverhill
Joined Jun 2006
I've used it. It seems about the same as Econocote.
pd1 is online now Find More Posts by pd1
Old Feb 12, 2013, 01:12 AM
dgliderguy is offline
Find More Posts by dgliderguy
Where's the lift?
dgliderguy's Avatar
United States, WA, Snohomish
Joined Mar 2001
I can't tell the difference, myself. They color match well, too. Maybe Towerkote is just Econokote with a different label.
dgliderguy is offline Find More Posts by dgliderguy
Old Feb 12, 2013, 08:41 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
I've used it plenty. Only 'issue' is the limited range of colours, but that's survivable . It demands lower working temperatures on my covering iron, but that's no big deal - I use a digital thermometer to check and set my covering iron and, being al little nerdy, have a spreadsheet of covering temps by covering makes.
Real good part is the price!
D
Dereck is offline Find More Posts by Dereck
Old Feb 12, 2013, 01:11 PM
Where's the lift?
dgliderguy's Avatar
Joined Mar 2001
Agreed, Towerkote is a bargain. The downside of Towerkote (and Econokote) is that it doesn't hold up to time very well, especially with glow power. The more you wipe it down the more the gloss wears off, and the seams lift. A Towerkote-covered glow model looks like hell after a season or two.
If that doesn't matter to you, or you are flying electric, then yeah, go for it. I like it for covering foam, where the low temp application and stretchy characteristics allow a good finish with no wrinkles and a painted-on look.
Old Feb 12, 2013, 03:50 PM
GarryOgilvie is online now
Find More Posts by GarryOgilvie
Professional sink locator
United States, NC, Greenville
Joined Dec 2012
Dereck,
So what is the best temp for Towerkote? and other coverings that you have used?
GarryOgilvie is online now Find More Posts by GarryOgilvie
Old Feb 12, 2013, 03:52 PM
Where's the lift?
dgliderguy's Avatar
Joined Mar 2001
225 degrees for the low-temp stuff.
275 degrees for Ultrakote.
Nuclear blast for Monokote....
Old Feb 13, 2013, 08:52 AM
Dereck is offline
Joined Dec 1996
Originally Posted by GarryOgilvie View Post
Dereck,
For tacking Towerkote down, I use 225 degrees. For shrinking, I use my 'Hangar 9' heat gun on high, but am very careful with how close to the covering that heat gun gets.
My thermometer came from Radio Shack, though they can be hard to find now that they're more like 'Telephone Shack'. I believe these remote/IR thermometers are popular with RC car racers, so that kind of hobby shop may be a sourse. I don't use any kind of cloth 'sock' over my covering iron. temp readings are taken off the main part of the iron. Learning how long it really takes your covering iron to stabilise at a temperature is a good idea.
Other coverings? Solarfilm, though not for a while now. Solarfilm Lite, AKA SoLite and many other names - look for a weight of 0.6oz/square yard - 176 - 194 deg for tacking down, 230 - 250 deg for shrinking, or heat gun on low.
Monokote - 275 deg for tacking down, 280 - 300 for iron shrinking or heat gun on high.
Econokote - 225 deg for tacking down, 225 - 245 for shrinking, heat gun on high, but carefully.
and a minor dabble with Coverite Space Age film - 250 deg for tacking down, 325 for shrinking with iron.
No comment on 'fuel proof' characteristics of any, I haven't flown wet power for a while now.
Hope that helps. There's not a lot of lawyerbabble included, but trying little pieces out before hurtling into covering that quarter scale B17 is a good idea
D
For Sale Tower Hobbies Balsa x3! TOWER HOBBIES: Box-A-Balsa Assorment 1 (x2), 12 Balsa Sheets Paulsitive Non R/C Items (FS/W) 3 Jan 21, 2013 02:35 PM
Question Minwax/coating, lead edges and hinge areas cram Painting and Finishing Tips 4 Jan 20, 2013 12:19 PM
Discussion Conductive Coating Spray Paint Altimat Multirotor Electronics 0 Jan 06, 2013 08:48 PM
Question Mahogany Boat--Last Epoxy Coat/Finish Coat cicerokid Scale Boats 7 Feb 04, 2012 08:07 AM
Discussion Coating or not coating the fuse ... gortounet The Builders Workshop 2 Sep 02, 2008 03:04 PM
