Old Feb 10, 2013, 12:08 PM
rivers is offline
Find More Posts by rivers
Joined Dec 2004
Emeter v2 rpm sensor compatibilty
Hyperion's Emeter brushless RPM sensor not working with my Eagle Tree V4 logger. Has anyone had success with this combination? The Emeter rpm unit is a phase sensor. It taps into one motor phase line as opposed to 2 lines for a ET sensor. It has a 3-wire servo plug wired off the sensor board. The live mode rpm display dial is not moving while a test motor runs??.
Note: I have configured the setup page for 14 poles and 1:1 gearing to match my test motor.
rivers is offline Find More Posts by rivers
Old Feb 10, 2013, 06:15 PM
rivers is offline
Joined Dec 2004
Just noticed something odd. I plugged a 7.4 volt battery to the elogger. Measured the voltage at the RPM connector pins. From the black pin (meter common)to the middle pin (red) The voltage reads -5 volts. I was expecting +5 volts. Is a negative voltage normal?
Old Feb 10, 2013, 10:05 PM
rivers is offline
Joined Dec 2004
eLogger now working with a Hyperion brushless RPM sensor. The problem was a wiring misunderstanding. The Hyperion sensor must be supplied with power from the Hyperion Emeter unit, which was measured at +3.3 volts. The logger's RPM pins are reversed from normal servo convention, so black is power and red is ground. Power going to the sensor does not go the eLogger, only signal and ground connect. A Y cable is needed to make the hookup between the 3 elements.
The sensor/logger combo works, but the hookup is too cumbersome with so many parts. I would not recommend using a 3rd party RPM sensor. I tried it because I had one on hand, but now I will be purchasing an Eagle Tree RPM brushless sensor.
Old Feb 19, 2013, 03:29 PM
rivers is offline
Joined Dec 2004
Delete
Last edited by rivers; Feb 19, 2013 at 05:38 PM. Reason: Post redundant ; Filed a support ticket instead
Sold Medusa Power Analyzer Pro Basic w/RPM sensor Mountain Soarer Aircraft - General - Miscellaneous (FS/W) 3 Jan 31, 2013 03:23 PM
For Sale eagletree brushless rpm sensor steveiewonder Aircraft - General - Miscellaneous (FS/W) 1 Jan 20, 2013 07:28 AM
Question Optical RPM sensor dpelletier Hitec/Multiplex USA 6 Jan 18, 2013 03:23 AM
For Sale HITEC Basic Telemetry Acro Pack with FREE Optical RPM Sensor $60.00 Shipped! flyinhigh025 Aircraft - General - Radio Equipment (FS/W) 1 Jan 13, 2013 10:47 PM
Question Turnigy Rpm Sensor matchpoint Power Systems 0 Jan 11, 2013 10:42 PM
