Old Feb 10, 2013, 08:16 AM
bluescrn is offline
Find More Posts by bluescrn
bluescrn's Avatar
Joined Jul 2008
Smallest brushless quads?
Has anyone built a really small brushless quad?
There's quite a selection of mini quads around using 5" props (and I've built a couple myself), But I don't think I've seen anything smaller, not as an off-the-shelf frame kit, anyway.
Looking at the NanoWii control board, and maybe a set of 6A ESCs, it looks like it's got to be possible to go a fair bit smaller with mostly off-the-shelf parts... maybe about halfway between Ladybird-size brushed quads and models with 5" props?
So has anyone given it a try? - are there suitable motors (smaller than 1811s) and props (3-4"?) available?
bluescrn is offline Find More Posts by bluescrn
Old Feb 10, 2013, 09:19 AM
neobot is offline
Find More Posts by neobot
Joined Jun 2012
yep lots of vids on youtube search "micro brushless quad"
1S brushless quad copter(nano wii) testing_byJang (1 min 49 sec)
palmsize brushless quadcopter (3 min 50 sec)
or "nano brushless quad"
Nano quadcopter wii (2 min 22 sec)
Multiwii Nano Quadcopter V (8 min 41 sec)
even typing the above into google works, so why couldnt you do it instead of posting a thread asking to be spoon fed free information?
neobot is offline Find More Posts by neobot
Reply With Quote  (Disabled)
Old Feb 10, 2013, 09:34 AM
ver2go is offline
Find More Posts by ver2go
Joined Dec 2012
One reason I can think of is the terminology. Nano, Micro, etc.. quad, quadcopter, copter,multi,multirotor, I'm intertested in this myself, but more for a octo or x8. And I found that searching using variations yielded varying results because of the mix use of terminology.
ver2go is offline Find More Posts by ver2go
Old Feb 10, 2013, 11:23 AM
Sandav is offline
Find More Posts by Sandav
Time to learn to fly
Sandav's Avatar
Netherlands, Overste, Zwolle
Joined Feb 2012
What about the nanoquad from Flyduino.net?
I just started this built using all off-the-shelf parts.
5" props, 6A ESC's, tiny motors (although the price is pretty big).
Description:
The frame is designed for the nanowii flight controller.
I used this controller in another build an it's rocksolid.
check out warthox his video abusing this little quad.
mwc quad // nanoquad #1 (2 min 18 sec)
Sandav is offline Find More Posts by Sandav
Old Feb 10, 2013, 10:13 PM
ilektron is offline
Find More Posts by ilektron
Will fly for food
ilektron's Avatar
United States, CA, Carlsbad
Joined May 2011
Subscribed.
ilektron is offline Find More Posts by ilektron
Old Feb 11, 2013, 06:49 AM
AD. is offline
AD.
Find More Posts by AD.
AD.
Team Better Than Yours
AD.'s Avatar
London, UK
Joined Jul 2009
Didn't MIT build these quads about the side of a finger nail 10 years ago.
If you want a small quad to fly yourself though, Flyduino Nanoquad is the one.
AD. is offline Find More Posts by AD.
Old Feb 11, 2013, 03:16 PM
saskya is offline
Find More Posts by saskya
DR , EVIL
saskya's Avatar
Canada, QC, Montreal
Joined Apr 2012
Attachment 5524938
https://vimeo.com/53109820
What are the motor been use
saskya is offline Find More Posts by saskya
Old Feb 11, 2013, 03:37 PM
AD. is offline
AD.
AD.
AD.'s Avatar
London, UK
Joined Jul 2009
In the video, http://flyduino.net/T-Motor-Brushless-Multikopter-Motor
Although as they are a bit pricey a lot of people use Turnigy 1811 2900kv
Old Feb 11, 2013, 05:55 PM
ecreative is offline
Find More Posts by ecreative
It's all about Quadcopters
United Kingdom, England, Surrey
Joined Nov 2012
Does anyone have some build lists for a micro/nano/tiny/minuscule/little quads?
ecreative is offline Find More Posts by ecreative
Old Feb 12, 2013, 06:01 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
http://www.rcgroups.com/forums/showthread.php?t=1771565
sirbow2 is offline Find More Posts by sirbow2
Old May 28, 2013, 11:29 PM
Jetboatftw is offline
Find More Posts by Jetboatftw
Joined Oct 2009
Does anyone have anymore info on the nanocopter quad wii in video number three posted by neobot? Google doesnt give me anything but i assume it might be on a french forum or something. If someone could translate what hes saying in the beginning i would be grateful, the only thing i can see from the video is that hes using 3a esc's and maybe these motors http://www.hobbyking.com/hobbyking/s...ade_mCPx_.html
Jetboatftw is offline Find More Posts by Jetboatftw
Old May 29, 2013, 05:24 PM
flugratz is offline
Find More Posts by flugratz
Lead Zeppelin
Germany
Joined Apr 2013
I think they might be these motors:
4.6 gram weight 3700kv
http://www.hobbyking.com/hobbyking/s...idproduct=7025
video of a guy with a micro quad using them:
Multiwii Nano Quadcopter II (8 min 52 sec)
flugratz is offline Find More Posts by flugratz
Old May 29, 2013, 06:10 PM
Joined Oct 2009
Yeah they look more in the right kv range, thanks.
Old May 29, 2013, 06:31 PM
flugratz is offline
Lead Zeppelin
Germany
Joined Apr 2013
I hope they work on your build. I'm still trying to figure out what to get for my Nanoquad. I just can't see spending $150 for a set of those T-motors.
Old May 29, 2013, 06:57 PM
Joined Oct 2009
Yeah im also trying to figure out what to get for my build, it looks like 3x2 props is the smallest prop you can use and still get decent lift so now im trying to find some good motors.
Im also not sure if im going 1s or 2s yet, 2s would make it easier to use the flight battery for fpv too.
But accoring to this http://der-frickler.net/doku.php/mod...cro_motor_4_6g the motors only provide 52g of lift with 2s and i would like to get closer to 100g.
Ive found this test that gives 120g lift on 22700 rpm with 3020 props on a 4000kv 17g motor with 26w of power usage. http://www.wattflyer.com/forums/showthread.php?t=57635
I think the ad-c5 motors have to low watt rating to get the prop speed up so im looking for some more powerful ones close to 4000kv and still light weight. So far ive found these but i havent found any test data on them. http://www.hobbyking.com/hobbyking/s...ner_Motor.html
I also i have one of those i linked to first from project i never used so i might test it with a 1s lipo and see how much thrust i can get out of it.
And i agree those t-motors are to pricey. And i have more rc gear then id like to admit so now i want to find the right motors without having to go to trial and error but build threads for nano brushless quads are hard to find. Every thread i find seem to use 5 inch props.
For Sale Mini DVR Global Smallest Sport Camera For FPV RC4YFPV FPV Equipment (FS/W) 6 Jan 13, 2013 08:22 AM
Discussion Smallest quad components ara25demayo Multirotor Talk 1 May 04, 2012 07:36 PM
Build Log TINY TIM - teh smallest quad build chatch15117 Multirotor Talk 21 Apr 15, 2012 10:01 PM
Discussion What is the smallest quad control board? - 140x140mm Design boredom.is.me Multirotor Talk 7 Dec 30, 2011 01:46 PM
Build Log Worlds Smallest 8 motor Micro Quad "The Shredder" Z06 Tony Multirotor Talk 45 Apr 05, 2011 06:22 PM
