Old Feb 10, 2013, 03:57 AM
_AL_ is online now
Find More Posts by _AL_
Slow builder
_AL_'s Avatar
Australia, NSW, Hornsby
Joined Jul 2005
Help!
Cheap TX hack
HI,
I recently bought a cheap & .... cheap micro RTF from HK. When it arrived I was impressed with the airframe but less than impressed with the electronics. After resoldering the pos wire from the battery box the TX started working & when I resoldered the rudder servo wire the rudder started working.... Good start except......
The TX is set in mode 3 or 4 (I use mode 1) & I can't even taxi it without my brain getting confused. I need to swap the left & right sticks.
The whole stick/ pot assembly is held in place by being soldered directly to the board. I thought about cutting pins, gluing the sticks to the board & running wires from the pots back to the circuit board but I'm starting to think I'd be better cutting the printed circuits up where they run into the chip & simply crossing the pot signals using wire.
Pic of the board below.
Is it possible (without being an electrical engineer) to simply break the path to the chip & cross over using thin wire? Could it be as simple as breaking the copper path with a dremel & soldering wire to one side below the break & the other side of the board above?
Any suggestions on how best to tackle this?
If it can't be done I'll simply install an AR6400 brick, the main excercise is to see if I can do it. If it works that will be a bonus.
Any advice appreciated.
Al
_AL_ is online now Find More Posts by _AL_
Old Feb 10, 2013, 04:04 AM
_AL_ is online now
Slow builder
_AL_'s Avatar
Joined Jul 2005
Tried to make it a little clearer what I'm thinking...
Old Feb 10, 2013, 08:26 AM
boaterguy is offline
Find More Posts by boaterguy
Thermite + ice = Big boom.
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
If you cut the traces on both pots, neither of them will be connected and swapping the wires won't do anything.
Find out what kind of microcontroller is in there and see if you can try to find the firmware for it, then it would be an easy reflash.
boaterguy is offline Find More Posts by boaterguy
Old Feb 10, 2013, 09:39 AM
microfan is offline
Find More Posts by microfan
Germany
Joined Nov 2012
I see no reason, why your plans shouldnt work. If you have no need to swap the not neutralizing side, you normally should be fine this way. If there have been factory adjustments made, you might have some off center issues.
microfan is offline Find More Posts by microfan
Old Feb 10, 2013, 04:59 PM
dmccormick001 is offline
Find More Posts by dmccormick001
Dave the Rave
dmccormick001's Avatar
Joined Jun 2007
Have you tried getting the TX into a "programming" mode that might allow you to choose a different mode? A lot of TX have this ability, yours might have gotten itself into the mode it's in inadvertently. Most of the time it's accomplished by holding down some menu buttons, or perhaps some trim buttons, as you turn the unit on. I have a hard time believing that any company would build a radio nowdays that would not be compatible with the mode most R/C pilots in the US use.
dmccormick001 is offline Find More Posts by dmccormick001
Old Feb 10, 2013, 05:15 PM
wilf370 is offline
Find More Posts by wilf370
rookie
wilf370's Avatar
Canada, SK, Saskatoon
Joined Dec 2012
He is looking for mode 1 that is not popular in the us
wilf370 is offline Find More Posts by wilf370
Old Feb 10, 2013, 07:46 PM
jakestew is offline
Find More Posts by jakestew
United States, ID
Joined Sep 2011
Yep, it might just be better to learn to fly with normal controls, unless you're a lefty.
jakestew is offline Find More Posts by jakestew
Old Feb 10, 2013, 09:02 PM
boaterguy's Avatar
Canada, ON, Ottawa
Joined Apr 2009
I'm lefty, and I would never be able to use a mode 1.
Old Feb 11, 2013, 12:54 AM
_AL_ is online now
Slow builder
_AL_'s Avatar
Joined Jul 2005
Thanks for the responses so far.
Boater Guy. Imagine pot 1 is the elevator & pot 2 is the throttle. I'm thinking cut the track on the board between pot 1 & the microcontroller, solder a wire below the cut for track one & solder above the cut for pot 2. reverse for the other side. Obviously there wil be 3 wires per pot so 3 cuts per control. Does that make sense? Essentially, move the sticks electronically without moving them physically.
DMcCormick, the TX looks like the cheap Parkzone RTF TX but it's a HK knockoff & the quality is very poor. Even if I knew how to activate programming mode, I doubt I'd find any instructions on how to identify how to, or what I'm changing. That would be the easiest way but I don't like my chances.
Jakestew. I've tried to taxi it & I'm like a cow with a gun. There is no way this brain is going to adapt to that mode. I'd give myself a 0.001% chance of making it past the 3 second mark if I actually got it off the ground.
Microfan. That's something I didn't think of. I'm thinking I'm going to try anyway & see what happens.
If anyone has any other suggestions I'd be happy to listen. I'll probably have a crack at it later in the week & I'll post pics of the carnage.
Al
Old Feb 11, 2013, 01:28 AM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
Each pot has 3 pins, center pin is the output. So only 4 cuts needed. If you put a meter between outer pins they will be connected GND or V+ being used as a voltage divider.
I've marked on your picture in blue solder point you need black being cuts. Couldn't do other side pic just not clear enough.
But before cutting get you multi meter out and find out where center pin is connected too on chip and that will be your next solder point. Should only need cables fingers crossed.
Sorry if i got something wrong. Anyone watching say if i got it wrong
SadSack is offline Find More Posts by SadSack
Old Feb 11, 2013, 04:31 AM
jakestew is offline
United States, ID
Joined Sep 2011
Mode 2 is the normal way your brain works. It's the way real planes fly, flight simulators, video games, PTZ cameras, and every other normal joystick operated device works.
Lefties might find mode 1 a little easier since fine motor control is better in your dominant hand, and mode 1 lets them control at least one of the important controls with that hand.
All I can suggest is playing some flight or rc sims, or just any other normal joystick type activity. Breaking yourself of bad habits like funky control schemes is worthwhile in the long run.
If you're determined to be set in your ways... the hack should be easy. One pin of the pot should be fed with a voltage, and another is the output the controller reads.
AFAIK there's no 100% standard way of hooking those up. The center pin is the "wiper" and is what moves with the pot. Each side pin is on opposite sides of the resistor material. So basically the center pin moves closer or further away from each of the side pins, which gives more or less resistance.
You'll want to figure out what pins are going where. I can't quite see in the pics where the traces are all going. It's not necessarily the center pins you need to swap.
Old Feb 11, 2013, 09:05 AM
Dave the Rave
Joined Jun 2007
Yeah, but most radios allow you to switch from 1 to 2. I figured he's in mode 2 now.
Old Feb 11, 2013, 02:12 PM
SadSack is offline
Joined Aug 2008
Mode1 or mode 2 ain't a bad habit. you want fine control of the motor!??? There's a bad habit you need to break.
Thanks, I wasn't very clear in what I wrote.
Old Feb 11, 2013, 02:47 PM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
But many don't.
I have changed over a few of these cheap toy transmitters. The hardest part is unsoldering and removing the gimbals (necessary to get the spring centering and ratchet changed over). To swap the elevator and throttle functions you only have to cut two tracks. Best to cut them right at the pot center terminals, then you have a good place to connect the wires to.
You can also swap the trim buttons if you want, but it's not strictly necessary (just remember where the controls used to be, and operate those trims!).
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Feb 11, 2013, 11:24 PM
JMP_blackfoot is online now
Find More Posts by JMP_blackfoot
JMP_blackfoot's Avatar
United States, OH, Galena
Joined Jul 2003
Mode 2 is the normal way your brain works...
...only in the parts of the world where is is predominant...
JMP_blackfoot is online now Find More Posts by JMP_blackfoot
Discussion Uberlite 2-1 parkzone Tx hack? rcnutt Scratchbuilt Indoor and Micro Models 0 Jan 31, 2013 07:29 AM
Discussion cheap controller board + tx all in one ?? saskya Multirotor Electronics 17 Jan 24, 2013 07:53 AM
Wanted Looking for a CHEAP Tactic Tx to fly my Dr.1 chakotay Aircraft - General - Radio Equipment (FS/W) 2 Jan 23, 2013 02:42 AM
Discussion Cheap HK TX issue _AL_ DIY Electronics 5 Jan 11, 2013 05:26 AM
Discussion WALKERA 2.4 TX hack -can YOU hack it? aaronstomfoolery Radios 2 Oct 29, 2011 04:44 AM
