Old Feb 09, 2013, 07:57 PM
hidaven is online now
Find More Posts by hidaven
United States, NJ, Roseland
Joined Apr 2009
best on road drive train?? need help!
I had a losi car before and the freakin spur gear kept stripping. I do not want to be spending hours swapping out pinions and spur gears on any car. out of all the manufacturers, traxxas xo1, your kyosho, ofna, hpi sprint flux......whats the most bullet proof drivetrain that doesn't need too much fixing? assuming your not too hard on the throttle. im sure the belts or shaft drive parts are solid, my concern is the pinion to the gear to the spur/ slipper clutch. and if you do need to swap them which brand is the easiest?
hidaven is online now Find More Posts by hidaven
Old Feb 10, 2013, 01:27 AM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Did you also adjust the gear mesh properly? And you are using the same module gears. Module defines the teeth spacing, and allthough some gears look compatible, these aren't unless the same module.
If you are looking for a new car, make sure it has a slipper clutch. This will allow the drive train to slip when excessive loads are applied, saving gears.
Btw, please don't cross-post the same question: http://www.rcgroups.com/forums/showthread.php?t=1828498
SoloProFan is online now Find More Posts by SoloProFan
Old Feb 10, 2013, 04:55 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You're going to need to provide more details as to what kind of setup you're running. Unless you're massively over powering a car, or don't have the mesh right you shouldn't be chewing up gears like that.
wparsons is offline Find More Posts by wparsons
Old Feb 12, 2013, 01:37 PM
fat1 is offline
Find More Posts by fat1
West Virginia
Joined Jul 2008
All cars require maintenance and repair. Part of the hobby, preventive maintenance and proper setup will reduce the need for repairs but not eliminate them.
fat1 is offline Find More Posts by fat1
Do you drive your on-road car "off-road"? Starguard Car Talk 21 Mar 01, 2016 07:14 AM
Question best way to create really large parallel 3s battery? help/input needed. dnorm Power Systems 11 Feb 10, 2013 02:40 PM
Discussion Can I bolt on some different on road rims/tires for my Trooper SCT 4x4? MrRetro Off-road Cars 2 Jan 30, 2013 04:54 PM
Help! Need help on repair. copycat_00 Crash Discussion 2 Jan 28, 2013 09:16 AM
Rant Drive Train Problems on the FM-1e? Your Help Ducati-Rider Motorcycles 10 Jan 18, 2005 06:00 AM
