Espritmodel.com Heli Air
Old Feb 12, 2013, 02:09 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
Joined Aug 2009
What really gets my GOAT is you buy someting that the seller claims is so good. Then after you buy it the first time you fly it it crashes because of the substandard parts they use.
Oh, so you expect a seller to tell you when they're offering you a cheap piece of junk? Seems logical and perfectly reasonable... Riiiigggghhhhhtttt.... The only vendor I know of which does this is HobbyKing, but they have a lot of "abnormal" marketing practices and it seems to work pretty well.
As for the crashing, are you sure it's really the parts' fault and not because of the substandard skills you used?
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Feb 12, 2013, 02:20 PM
United States, IN, Bloomington
Joined Sep 2012
They way I see it Butane is that if you put sub standard parts, or bad glue/solder joints in the air then its still your fault even if someone else sold it to you like that. The pilot is ultimately responsible for what they put in the air. So if a hinge comes loose on my plane during a flight and as a result crashes... its my fault.
btown2 is offline Find More Posts by btown2
Old Feb 12, 2013, 02:56 PM
Mar/cotics Anonymous
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
Originally Posted by btown2 View Post
No standardization of parts.
This is driving me bat crap crazy. Why can't we standardize a few things in this hobby? Why in the year 2013 do I have to physically cut off pieces of my servos to get them to fit into a receiver?
I bought a plane at a swap today. It had Futaba servos installed on it. I got home to find out that my ar600 isnt keyed so if I want to use those servos with it I have to cut off pieces of them. That is just ridiculous.
Please tell me that I can get some sort of converter so that I don't have to damage PERFECTLY GOOD SERVOS.
Yes, the best converter you should buy for those types of servo's is a futaba Fasst receiver and tx.
cryhavoc38 is online now Find More Posts by cryhavoc38
Old Feb 13, 2013, 08:39 PM
GoatZilla's Avatar
Joined Sep 2005
Originally Posted by rafe_b View Post
Ah yes, we're all collectively responsible for corporate malfeasance. Profits are private, but "oopsies" are public. Nice system. What are we supposed to do, boycott every product that doesn't satisfy us, down to the last detail? Good luck with that plan.
Thank you for providing an example.
For everyone else:
Logically, if servos are meant to be modular components, they should not have wires dangling out of them. This is because the length of wire necessary is dictated by the airframe and NOT the servo. There's no way for the servo maker to know who much wire you actually need unless it's... not really intended to be modular.
That means the wiring should belong to the airframe.
The current system is nonsense. You swap servos and you wind up having to either extend wires (implies some obnoxious extra connector bulge somewhere in the middle of the run, or cutting/resoldering), or do some silly coiling thing with the extra wire.
Three female connector holes on the receiver (yes, the receiver has it backwards too) and three female connector holes on the servo. No keyed connectors; just label the holes. Cut the connecting wires to the right length. Once.
Like I said, we'll probably have to just wait for a combination of the status quo mouthpieces to die off and some less-indoctrinated manufacturer to unilaterally do something that makes sense.
GoatZilla is offline Find More Posts by GoatZilla
Old Feb 13, 2013, 09:10 PM
Joined Mar 2009
Standardization = socialism
Freedom = Dealing with a million different plugs and adapters, all of which cost 10 times more than they should.
djacobox372 is offline Find More Posts by djacobox372
Old Feb 13, 2013, 09:16 PM
"Get off the runway!"
Da Big_G's Avatar
United States, TX, Hutto
Joined May 2012
For everyone else:
You're kidding, right?..You want to add the complexity (for some) soldering/crimping micro-connections and add to the crash rate for noobies?
These "status quo mouthpieces" you speak of are did quite a good job, IMO. If you want what passes for education today designing and building our ever-complex radio control systems we are indeed screwed. Opps, I forgot. We don't design or build these R/C systems anymore. We out-sourced that about 30 years ago. As long as the Far Eastern cultures surpass us in education, it's best we let them tell us how thing are to be designed and built.
Da Big_G is offline Find More Posts by Da Big_G
Old Feb 13, 2013, 09:40 PM
Joined Jan 2009
Ah I love the smell of generational warfare in the morning, and the arrogance of youth in full bloom.
rafe_b is offline Find More Posts by rafe_b
Old Feb 13, 2013, 09:51 PM
Da Big_G's Avatar
Joined May 2012
That's what we need...a new manufacturer to come along dictating a new modular component format for our hobby that will render all existing hardware currently in use obsolete. The modular approach is great for 1 model design. I have maybe 20 models and can move the flight gear between them in a few minutes. Plug and play....
Old Feb 14, 2013, 08:34 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Reminds me of the HR poster:
Hire a teenager, while he still knows everything.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Feb 14, 2013, 08:35 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
This is why many aircraft companies recommend you use another standard component called a "Servo Extension." This allows you to make the wire part of the airframe if you choose while not necessitating it for those who disagree with you.
Andy
Site Sponsor
Old Feb 14, 2013, 11:31 AM
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
That worked well for common language. Everyone speaks Esperanto. Right?
Anyone remember the old DeBolt "Live Wire" planes. Most had a "standard" radio compartment. All you did was mount the radio system - receiver, batteries, etc - to a "standard" tray and with the removal of four screws, you could move the whole shebang to another plane in minutes. And we're talking a vacuum tube (valves on the east side of the big ditch) system with windup escapements.
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old Feb 14, 2013, 11:33 PM
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
Fear not. It wont be too much longer before someone develops a wireless radio system., Then connecors and wire lengths will become moot.
BM
BillM is offline Find More Posts by BillM
Old Feb 15, 2013, 12:14 AM
Go ARMY! Beat Navy.
Dave Craig's Avatar
United States, NC, Southern Pines
Joined Dec 2012
Wow what a great rant! "Hire a teenager...." you kill me! Still laughing. As one who is becoming a full fledged member of the "old group" as soon as I read standardization, I thought, someone must have been in the Army.
Here's a servo for you....This baby is cutting edge!!
Dave Craig is offline Find More Posts by Dave Craig
Old Feb 15, 2013, 01:39 AM
numanair's Avatar
United States, WA, Kirkland
Joined Sep 2010
BM
And you'll be binding to the wrong servos. Then we'll have servomatch to fix that. Of course you can't mix and match servo and receiver brands/protocols.
numanair is offline Find More Posts by numanair
Old Feb 15, 2013, 10:54 AM
gnofliwr's Avatar
Joined Jan 2001
WOW! That was from the days when only the battery had three wires (or should I say, "the battery had only three wires") - the servos had four. IIRC, the Kraft brick was part of a low cost two channel system - bolt it in and hook up two pushrods, what could be simpler?
- Roger
Careful! My 1st real issue with Banana Hobby... TxToast Banana Hobby 1 Dec 31, 2011 09:17 AM
Discussion I'm her biggest fan!!Video of my daughter with Autism!!! lutach Life, The Universe, and Politics 10 Apr 03, 2008 08:20 AM
Question Motor issue on my Hobby-lobby Yak 55 egens Power Systems 1 Jul 21, 2007 10:12 PM
Discussion My issue with my remote OblivionLord Beginner Training Area (Aircraft-Electric) 10 Dec 17, 2006 03:32 PM
