this is a very good unit, 30mm, low amp draw and plenty of flow
![]() fan unit: http://www.bananahobby.com/at-minif8...8098-prd1.html and motor: http://www.bananahobby.com/at-minif8...8099-prd1.html comes with all the screws for assembly, goes together in a couple minutes, will go several minutes on a 3s 250mah pack, a 3s 500mah pack should get you 6-7 minutes, more if you only need less than the equivalent of full throttle, and its fairly lite. Joe |
Do you think these units will fit into the HobbyKing A-10 Warthog 30mm?? |
| Thread Tools | |
| Found Pair of 27mm or 30mm edf units | rcbobcat55 | Aircraft - Electric - Power Systems (FS/W) | 0 | Jun 03, 2012 08:46 PM |
| Cool Check these out! 8 blade rotors for 30mm and 40mm EDF by AEO!!! | NitroCharged | Micro EDF Jets and Power Systems | 149 | Aug 06, 2011 12:43 AM |
| Discussion Axon Micro F4 Phantom II 30mm/40mm EDF Jet | metroidrc | Micro EDF Jets and Power Systems | 544 | May 15, 2011 03:03 PM |
| Discussion Any micro EDF kits out there (30mm or 40mm?) | Wayno-san | Foamy EDFs | 13 | Dec 11, 2010 05:39 PM |
| Wanted Looking for 30mm or 40mm EDF setup | profilefan | Aircraft - Electric - Power Systems (FS/W) | 0 | Apr 23, 2010 09:27 AM |
