Old Feb 10, 2013, 03:55 PM
AEMontoya is offline
Find More Posts by AEMontoya
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
I just tried the lowest advance possible as well as the highest PWM settings possible. The problem seems worse than before. My settings are shown below.
AEMontoya is offline Find More Posts by AEMontoya
Old Feb 10, 2013, 03:59 PM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Originally Posted by jjmouris View Post
Note, you are very close to burning this speed controller as you can clearly see it is not running well. So i would advise against repeated testing if you notice something is still not working well.
Joe
My CC125 burned on the fourth flight with almost the same setup, although I did not notice any such problems. The replacement CC180 worked flawlessly ever since...
I would get rid of the soft cutoff...
WimH is offline Find More Posts by WimH
Old Feb 10, 2013, 04:56 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Originally Posted by Mark Haigh View Post
Steve,
What timing would you recommend for your 'Y' wind motors.
Cheers,
Mark
Low timing gives the best efficiency---but the "Y" motors can take some advance(up to 15 degrees) which will give a little more power.
Steve
sneu is offline Find More Posts by sneu
Old Feb 10, 2013, 05:00 PM
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
When you say get rid of the soft cutoff, what do you suggest I replace it with (the default hard cut-off, I assume)?
Also, what exactly was the setup that you flew before where the cc125 burned up?
Old Feb 11, 2013, 12:54 AM
George Shering is online now
Find More Posts by George Shering
Scotland
Joined May 2005
I would save the P125's for use with the big mod and 4S to 6S. Works well with a Neu 1512/1.5D or similar.
Note: This seems to be an older CC125. If the power FETs are the "leggy" ones which have a 12V gate voltage maximum then they are not suitable for the "big mod". See www.f5b.co and the big mod description for details.
George Shering is online now Find More Posts by George Shering
Old Feb 11, 2013, 11:47 AM
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
Assuming that the problem is not ESC settings, the only two remaining sources for the problem would be the motor and the battery (everything else has pretty much been ruled out).
What are the likelihoods that the brand new motor (from manufacturer) or the brand new Thunder Power battery could cause this problem? Unfortunately, I don't have any other 2s lipos to drive the motor, and I don't have any other motors that run on 2s for further testing.
Old Feb 11, 2013, 04:04 PM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
I don't see anything wrong with the voltage, so the pack is fine.
You assume that running a motor is just a case of the right settings on the ESC. That is not entirely true. It could very well be that the CC firmware is not compatible with running this drive. Neu has made changes in the stator design and so even if this setup was fine in the past, that may not be the case now.
Please try the budget controller and see how that runs.
jjmouris is offline Find More Posts by jjmouris
Old Feb 11, 2013, 04:08 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
The stator design was done years ago and I doubt it has any influence here.
First try changing the PWM to the highest available setting.
Steve
Old Feb 11, 2013, 08:20 PM
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
Steve
Steve, I did try the highest possible, to no avail. Please take a look at Post #16. Lastly, is it possible to rotate the 6.7 gearbox on my motor so that I can match the motor mount hole pattern with that of the gearbox without having the motor wires at an awkward angle?
Old Feb 11, 2013, 09:58 PM
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
It appears that I have resolved the issue. I have changed the PWM rate to the 2nd highest available (16 kHz), increased the motor start power to 85, and increased the throttle response to 7. I have now ran through the battery pack twice for a total of about 35 bursts, and have not had a single starting or braking problem.
Thanks to everyone for the help; hopefully I won't be back on here regarding the same problem.
AEM
Old Feb 12, 2013, 05:54 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Hi, if you would be willing to post the Excel file (zip it) from either your last batch of testing or your next flight, then I can have a look more closely just to see the startup behaviour. Using Roy's program to overlap the runs. Guess that your start power is good for the working voltage but would like to see what the little spike does on average.
Note, unless I am mistaking George's firmware uses 16Khz also when the motor is at speed.
Old Feb 12, 2013, 11:26 AM
AEM
AEMontoya's Avatar
Bay Area, CA
Joined Sep 2009
It looks like Steve Burns also uses 16 Khz with his cc180/cc125 setups. I will gladly send you the zipped Excel file. I haven't recorded any runs with the Unilog since I "fixed" the problem, but I will today or tomorrow. I have never exported the Unilog data to Excel before, either.
Is there anything in particular I should now about exporting the data to Excel from Logview?
AEM
Old Feb 12, 2013, 11:31 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Euhm I don't use Logview, not sure. Send me the Logview file?
Old Feb 13, 2013, 05:16 AM
Scotland
Joined May 2005
It runs at 13kHz, but notably also at start up. So it starts with lots of small pulses to get low power. Castle 1.56 drops the PWM to 1.5 kHz to get low start power with bigger current pulses which are more dangerous when things go wrong. The stock low cost controller starts at 8kHz with the shortest pulse they can manage which is why it is too brutal on 6S.
Old Feb 13, 2013, 07:57 AM
sneu is offline
sneu's Avatar
Joined Dec 1999
It can be clocked only every 90 degrees which won't help.
Steve
Help! Quad motor not starting. ESC maybe? Spacenutz Multirotor Talk 10 Jan 27, 2013 07:53 AM
Help! Motor/ESC problem after soldering?? low beeps and motor wont start calle3 Micro Helis 0 Jan 14, 2013 12:58 PM
Discussion Hexa--5 motor starts and one delayed--??? quadman Multirotor Talk 3 Apr 19, 2012 03:45 AM
Discussion Why one of 6 Motor Delayed start??? quadman Multirotor Talk 5 Jan 12, 2012 09:18 PM
Question Align 35A Governor ESC delay at start up thanhTran Mini Helis 2 Jan 02, 2006 01:34 AM
