Old Feb 09, 2013, 06:32 AM
68 stang 19 is offline
Find More Posts by 68 stang 19
United States, FL, Valparaiso
Joined Jan 2012
Help!
First F22 scratch build and burned motor
not sure what happened, I have a 11.1 v 500mah battery with a 2050kv motor and a 7x5 propeller...plane weighs about 9.9 oz with battery. I would only get about 3 mins of flight time per pack. The wires from the motor started smoking after third battery. ..any ideas?
68 stang 19 is offline Find More Posts by 68 stang 19
Old Feb 09, 2013, 06:40 AM
Whiskers is online now
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
It looks like it is over-propped but more details of the motor will be required.
Post a URL for where you bought it or at least tell us what it is.
Whiskers is online now Find More Posts by Whiskers
Old Feb 09, 2013, 07:12 AM
Joined Jan 2012
Bought it from Don at strongrcmotors.com....great guy to deal with and im sure it was all my fault. ..on his website I bought two C20 pro motors
Old Feb 09, 2013, 02:58 PM
Whiskers's Avatar
Joined Feb 2010
Don is indeed a fine gentleman.
The prop recommended for that motor is 7 X 3.5.
Your 7 X 5 is possibly too savage. 6 X 5 may be better.
Make sure the motor is free to turn and that nothing is dragging on it and that no dirt has got into the works.
You will not get much flight-time with those little 500mah batteries. You can only get low miles from a small tank.
Old Feb 09, 2013, 03:08 PM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
3s on a C20 with a 7" prop is definitely overpropped! If you have a watt meter, test the system and see just how many amps it's drawing. I fly several c20's but only on 2s, and even then with a 6-7" prop.
Don may chime in, but I'd think i would use at least a 24 gm (blue wonder) motor with a 9oz plane even though the F22's are pretty good floaters. A 1700kv BW will fly super with a 7x6 sf prop (it's the pick for our SEMFF warbirds and combat flyers). What do they recommend on the F22 thread?
springer is offline Find More Posts by springer
Old Feb 09, 2013, 10:21 PM
Joined Jan 2012
As I said before, I'm sure I'm the idiot who screwed it up, I just want to learn from it and not let it happen again. Can someone recommend a good 2S battery that will work with this plane? As well as give it longer than 3 minute flight times? Thanks again and I will keep ordering from Don for more motors and other items as well! Thanks and great learning from all of you...the EXPERTS!
Old Feb 10, 2013, 08:50 AM
Thechittyfather is offline
Find More Posts by Thechittyfather
Damn this gets addictive.
Thechittyfather's Avatar
United Kingdom
Joined Oct 2011
Try reading through this. It helped me loads when I was starting out.
http://www.rcgroups.com/forums/showthread.php?t=1136470
In answer to your last question about which 2s. It is essentially a balancing act. The bigger the battery (more mah not size although they go hand in hand) the longer you can fly but you will hit a point where the weight of the battery is too much for the size of plane and the extra power required to drag the battery around will out weigh the extra capacity.
If you built from plans then go with the recommendation as the designer will have done the working out for you and will probably have used the battery to get the centre of gravity just right.
If this is your own design then you will need to play around till you get the best combination. Have a read through the link above and then come back with any questions. I'm far from an expert but I've been where you are now.
tCF
Thechittyfather is offline Find More Posts by Thechittyfather
Old Feb 11, 2013, 07:26 PM
Joined Jan 2012
tCF
I've been flying the past two days with no issues. Put the 6x4 propeller back on it and now getting about 7 min flight times per pack on the new, but same motor that I burned. Also, learned to put the APC propeller on properly with letters facing towards front of plane. Motor is only warm after my runs! Thanks for all the help...now if I could just figure out a better fuse to make that isn't so flimsy!
Old Feb 11, 2013, 07:44 PM
Whiskers's Avatar
Joined Feb 2010
All sorted? Good!
Ah! The old Prop On Backwards trick. We had a guy turn up to our field with a nice ARF pusher and there is no way we could get him to change his 'backwards' prop.
Explanation, logic, reason and everything else we could think of to make him understand were useless.
Perhaps a good smack in the kisser would have worked, but for some strange reason we didn't do that, we just gave up.
Old Feb 11, 2013, 09:05 PM
Joined Jan 2012
Originally Posted by Whiskers View Post
All sorted? Good!
Thanks...might try the 7x5 again installed correctly and see if there's much of a difference
Discussion First scratch build F22 complete 68 stang 19 Foamies (Scratchbuilt) 8 Feb 10, 2013 01:32 PM
Discussion First F22 build... 68 stang 19 Foamies (Scratchbuilt) 10 Jan 27, 2013 06:42 AM
Question First Scratch Build Questions elmtree Scratchbuilt Multirotors 9 Jan 23, 2013 10:00 PM
