Old Feb 09, 2013, 01:09 PM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Nitroplanes sells electrics too.
Trisquire is offline Find More Posts by Trisquire
Old Feb 09, 2013, 01:16 PM
BillM is offline
Find More Posts by BillM
Wilkes-Barre/Scranton, Pennsylvania, United States
Joined Nov 2000
The instruction books in the Nitro Kadet Senior and Seniorita kits had Sig labels on them--at least that was true for the few that I have seen.
When the stock was depleated they were gone.
BM
BillM is offline Find More Posts by BillM
Old Feb 09, 2013, 03:23 PM
foamflyer is offline
Find More Posts by foamflyer
Trapped in California
foamflyer's Avatar
United States, CA, Arcadia
Joined Nov 2003
Wouldn't pilot skill play a part in this too?
foamflyer is offline Find More Posts by foamflyer
Old Feb 09, 2013, 03:24 PM
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
I guess we're assuming he's unskilled. Also, with glow engines, you have to account for dead sticks.
Old Feb 09, 2013, 05:03 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Originally Posted by Mike_Then View Post
That's quite a broad statement, don't you think? Have you pulled the covering off all ARFs and seen that they are indeed glued with super glue?
And yes, this should either be in the Nitroplanes.com section or at the very least the Fuel section.
Agreed on the first point. I have seen a number of different types of glues used on ARFs. My H9 Twin Otter was assembled with some type of white glue/PVA type glue.
No so sure about your second point. Lots of the Nitroplanes Kadets have been converted to electric, so mentioning a general airframe issue in here is not really off the mark. The post was about airframe quality concerns and the power is a non issue.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Feb 09, 2013, 06:05 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
phtttt ... i have bought like 11 planes from nitro planes,i know what im getting and know they will need some work to be up to flying. And they have stood behind the one or two i had trouble with, one was bad esc and one was bad servo. I PLAN on replacing the esc on any plane i buy (they put to light of an esc in all) I plan on fixing hinges,wheels,loos parts,bad glue.it is all part of betting what you pay for.
fastfwd is offline Find More Posts by fastfwd
Old Feb 09, 2013, 06:52 PM
DustBen is online now
Find More Posts by DustBen
DustBen's Avatar
United States, AL, Birmingham
Joined Dec 2011
So... sorta what you see is a "STARTER" ARF. It's started, and you have to finish up all the loose details.
Which is sorta the same thing I do every spring when I get out models I flew last October. I have to go thru them carefully to check for who knows what before intense summer flying.
Nothing wrong with going thru every detail of a new model to make sure it's actually ready to fly...
DustBen is online now Find More Posts by DustBen
Old Feb 10, 2013, 12:08 AM
Wingman26 is offline
Find More Posts by Wingman26
Wingman26's Avatar
Oklahoma
Joined Aug 2008
  • Nitro Planes didn't build it, Sig had it built.
  • I'll bet it said in the instructions to check the glue joints.
  • It can happen with any of them.
  • Not uncommon with Chinese assembled planes.
Wingman26 is offline Find More Posts by Wingman26
Old Feb 10, 2013, 10:50 PM
aurorae is offline
Find More Posts by aurorae
aurorae's Avatar
Joined Sep 2008
Do people expect to have to strip off the covering to reglue every joint?
aurorae is offline Find More Posts by aurorae
Old Feb 10, 2013, 11:05 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
I like the Nitroplanes $40-45 800mm EPO warbird kits so far. I fly the P-51D & just ordered the T-34. Sweet! Not as good as Alfa, but you take what you can get.
Not part of the discussion, but the Nitroplanes Airfield 800mm is OK. I had to do a lot of fixes, but it was not bad, compared to crappy clone helis FWIW.
I suppose the bargain basement balsa ARF is the same. Caveat Emptor (IT IS TRUE, even with our expectation of customer service and satisfaction nowadays). Good luck everyone!
eagle777 is offline Find More Posts by eagle777
Old Feb 10, 2013, 11:33 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Originally Posted by scottc39 View Post
Cloud_9
dont buy a eflight pulse 25 the landing gear dose the same thing, we dont know how hard the landing was, also all arfs are glued with super glue.
The Pulse 25 LG was fine for me, I made a few less than optimal landings in 2" grass and finally broke it. I fixed it, and found no fault with the original construction. Point is the construction is ok, but the landing has to be there also. This isn't a springly wire gear that bends and bounces you back up after a 10G landing. Perhaps you received a defective fuselage.
Super glue is as good as white for balsa AFAIK. I use it.
Old Feb 10, 2013, 11:40 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
This thread is super weird.
Piece is offline Find More Posts by Piece
Old Feb 10, 2013, 11:45 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Originally Posted by starcad View Post
My question is, Why didn't the person who owned the plane go through and re-glue everything before flying. I do that on every ARF I buy and especially the landing gear. Most of the time it either has to be replaced or beefed up somehow before any maiden.
BTW I have several Nitro Planes models and all fly fantastic as I still have my big Nitro Planes Pole Cat electrified.
So true. All the ARFs I ever had broke at the landing gear joints. There is no question. The first thing I do is beef up the landing gear area.
Of course you can always do it "after" it breaks I guess.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Feb 10, 2013, 11:50 PM
wilf370 is offline
Find More Posts by wilf370
rookie
wilf370's Avatar
Canada, SK, Saskatoon
Joined Dec 2012
Seemed to be an easy fix. if that area had been reinforced some other area would probly break .
Wilf
wilf370 is offline Find More Posts by wilf370
eagle777 is offline
Closed Account
Joined Aug 2007
I enjoy responding to things. How am I doing?
Discussion Before I buy a Stryker.... Idoitall Flying Wings 2 Jan 20, 2013 08:07 PM
Alert I sold futaba 9c Guy Wants Refund Before Returning Radio Forrest Gump 23 Trader Talk 87 Jan 10, 2013 06:14 PM
Careful! Safety reminder! Remove the prop before servicing your plane! oneagleswings Beginner Training Area (Aircraft-Electric) 11 Jan 04, 2013 10:46 PM
Discussion Does nitroplanes or the manufacturer test EDF units before shipping? texbird Foamy EDFs 3 Feb 07, 2011 07:39 PM
Before buying the Stick, some questions... Magna Parkflyers 4 Jun 26, 2001 02:29 AM
