Old Feb 08, 2013, 11:43 PM
JohnAV8R is offline
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Clark Y airfoil flies inverted
I made this small wing for an indoor flyer. It has a 15% Clark Y air foil, foam ribs, and is only covered on the top surface with saran wrap.
I dropped the wing and noticed that it quickly flipped onto its back and glided away rather well. I tried this again trying to keep it upright for a test glide, but it always quickly rotates upside down and then goes into a flat glide (wing is up side down).
Is this characteristic inverted flight only because there is no covering on the bottom, or is it the air foil?
I have a small Winglet 2 which flies very nicely and it has a curved bottom airfoil which is different from the top airfoil.
John
JohnAV8R is offline Find More Posts by JohnAV8R
Old Feb 09, 2013, 12:37 AM
slebetman is offline
Find More Posts by slebetman
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
It's the airfoil. If you look at an inverted Clark-Y or any high camber airfoils you'll notice that the inverted camber becomes a reflex - which is what is needed for a flying wing to fly.
But it's not really efficient. It works, and actually works very well but can't compete with a properly designed flying wing airfoil with an S shaped camber line.
Still, if you're just building a sport model for fun it's usually good enough.
slebetman is offline Find More Posts by slebetman
Old Feb 09, 2013, 01:46 AM
andrecillo76 is offline
Find More Posts by andrecillo76
andrecillo76's Avatar
Germany, BW, Stuttgart
Joined Oct 2009
As slebetman wrote, you can flip a Clark-Y, but it will have four or five times the drag of a good selected airfoil. Also, due to leaving the top(?) of the wing open, the airfoil is something different than a Clark-Y. It's rather a sort of cambered plate...
Cheers
Andrés
andrecillo76 is offline Find More Posts by andrecillo76
Old Feb 09, 2013, 02:32 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Originally Posted by andrecillo76 View Post
As slebetman wrote, you can flip a Clark-Y, but it will have four or five times the drag than a good selected airfoil. Also, due to leaving the top(?) of the wing open, the airfoil is something different than a Clark-Y. It's rather a sort of cambered plate...
Cheers
Andrés
.....which is why it's flipping.
Stuart A is offline Find More Posts by Stuart A
Old Feb 09, 2013, 10:53 AM
sp250 is offline
Find More Posts by sp250
sp250's Avatar
Shropshire UK
It flips inverted so as to become stable, although as said above, it is not efficient.
It does this because there is no tailplane opposing the pitching moment of the wing section. Have seen many times in thermal comps a model which lost its tail (usually from a mid-air) coming down slowly and semi controlled (flap and aileron because there is no elevator) but inverted.
One time in the 80's I saw a model landed on the spot this way.
John
sp250 is offline Find More Posts by sp250
Old Feb 09, 2013, 12:24 PM
JohnAV8R is offline
Joined Oct 2005
Thank you gentlemen for the answers. I’m never too old to learn something new.
John
Discussion Clark Y airfoil in dxf or dwg format? magic612 The Builders Workshop 22 Mar 18, 2012 10:26 PM
Discussion Pietenpol airfoil VS Clark Y Griffin Modeling Science 41 Oct 28, 2010 07:22 AM
Discussion Clark y airfoil jensenkg The Builders Workshop 4 Mar 22, 2008 09:18 AM
Plank With "Clark-Y-ish" Airfoil? Buzz_Man Flying Wings 94 Sep 24, 2004 02:50 PM
