Old Dec 27, 2003, 10:44 PM
dru is offline
dru
Find More Posts by dru
dru
San Diego Calif.
Joined Jul 2002
Cool
Brushless motor and single conversion Rx
I tried to search on this but only got info on brushed motors.
Do brushless motors put out any more or less RF noise compared to a brushed motor? I would like to know because I am going to return a couple of my Christmas prizes on Monday and get my first brushless motor and ESC. It will be going in my 27 inch foamie Edge with a single conv Rx and am a little worried about doing a figure 9 landing because of lock out.
Thanks.
Dru.
dru is offline Find More Posts by dru
dru is offline
dru
dru
San Diego Calif.
Joined Jul 2002
Thanks.
Dru.
Old Dec 27, 2003, 11:19 PM
sguty is offline
Find More Posts by sguty
Senior Member
sguty's Avatar
Redmond, WA, USA
Joined Oct 2000
Traditional wisdom says the brushes and commutators on a brushed motor put out a lot of RFI. I've found I needed to create a rough simulation of a Faraday cage on brushless planes with long leads to the motor and/or long servo leads (e.g., EDFs) by wrapping the wires in Al foil--doubled the range-check distances with the motor on.
Steve Guty
sguty is offline Find More Posts by sguty
Old Dec 28, 2003, 12:14 AM
mark_q is online now
Find More Posts by mark_q
KG7TTQ - Las Vegas
mark_q's Avatar
Joined Sep 2003
It has been my experience there is far less RF created in brushless set-ups. No brushes means no sparks, a large source of electrical noise. I am running JR600 rx, Berg 5DSP rx and Hi-Tech Electron 6 rx in my planes and I have NEVER had any glitching or subsequent electrical noise. In all cases I am using Castle Creations Pheonix controllers.
I think your safe - Mark
mark_q is online now Find More Posts by mark_q
Old Dec 28, 2003, 12:25 AM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
I run single conversion all the time on my brushless motors with no problem! The motor is not the problem but you can get glitches from outside interference that a dual conversion might filter out. I've had a few hits generally without carnage. However it was while I was flying in a area under construction with a lot of 2 way radios in use.
boomer
boomerace is offline Find More Posts by boomerace
Old Dec 28, 2003, 03:17 AM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
I run brushless motors and single conversion receivers without problems too.
"Single conversion" does not mean "low quality", there are better and not so good single conversion receivers too.
I have Jeti Rex5+ and Schulze single conversion receivers. I did a range check test with the ACT SmartScan double conversion receiver and the above two.
I found the Schulze to be the best, useful distance in the percentage of the Schulze: ACT 70%, Rex5 30%
(It was a simple test, the 3 receivers are switched on same time, servos on the outputs. One guy is observing the servos, the other is walking away with a closed antenna transmitter. Range is ok if it is possible to control the servos, and errenous movements are not too high...)
mmormota is offline Find More Posts by mmormota
Old Dec 28, 2003, 06:41 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Less, as posted, but depending on the particular Rx and where you fly, I would consider returning your SC receiver and get a dual conversion, or at least a good DSP Rx (i.e. Berg), instead..
..a
Old Dec 28, 2003, 08:01 AM
Fantam is offline
Find More Posts by Fantam
Go Leafs Go!
Fantam's Avatar
Georgetown,ON,Canada
Joined Jan 2002
I am using a GWS Naro receiver (single conversion) on a Formosa with a Mpjet brushless motor. I have never had a glitch and I sometimes let it get pretty far away too. It's so fast that it's hard not too.
Fantam is offline Find More Posts by Fantam
Old Dec 28, 2003, 09:50 AM
dru is offline
dru
dru
San Diego Calif.
Joined Jul 2002
I have 3 Cirrus MXR4's, 1 Dymond micro Rx, 2 Hitec Feathers. Where I fly is out in the middle of no where. I am about 70 miles east of San Diego so I have only 1 neighbor. I fly my glow planes without a glitch. They all have dual Rx's. The 4 Electron 6 Rx's I have have work very well.
I don't worry to much about a glitch when I have a $15.00 motor gear box on the nose. It is that I am now flying with a $100 brushless motor ESC combo and I am not made of money.
As money and time make it possable I am going to start to replace the Single conv Rx's with dual ones.
Dru.
Old Dec 28, 2003, 05:35 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
I use Berg-5 rx's with my BL motors and have never had a glitch.
Chuck
Chuck is offline Find More Posts by Chuck
New CD-Rom Brushless Motor Company Conversion Motor Works T_Hill Product Announcements 10 Jun 05, 2004 05:03 PM
Alert Help Me Find Special Single Conversion Rx JimHSoars Radios 5 Dec 29, 2003 04:03 PM
CH 46 GWS single conversion Rx crystal (micro) jbutkovci Aircraft - Electric - Airplanes (FS/W) 1 Sep 13, 2003 07:37 AM
CH 46 GWS single conversion Rx crystal jbutkovci Aircraft - Electric - Airplanes (FS/W) 0 Sep 12, 2003 08:02 PM
