Old Feb 10, 2013, 09:07 PM
Riserflier is offline
Find More Posts by Riserflier
Joined Jun 2004
Mark,
I am not visualizing "...chordwise" 1/8" square basswood doublers to the top sparcap...". Would you mind adding a bit more description?
Riserflier is offline Find More Posts by Riserflier
Old Feb 10, 2013, 10:39 PM
MrE is offline
MrE
Find More Posts by MrE
MrE
United States, WA, Gig Harbor
Joined Aug 2007
Same question here. Im not able to picture how that would be done.
MrE is offline Find More Posts by MrE
Old Feb 11, 2013, 10:40 AM
jcstalls is offline
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Well, this is what I see. Sorry for the rough drawing as I just whipped this up with MS Paint and my very limited talents.
Jared
jcstalls is offline Find More Posts by jcstalls
Old Feb 11, 2013, 11:03 AM
TOSSPilot is offline
Find More Posts by TOSSPilot
So. Cal
Joined Jan 2005
That is what I had envisioned when I read the suggestion. It is a great idea and does not add much weight.
My original intent was to do less work on the spar by just buying direct carbon replacements. I love to build but have limited time so I like to stay with laser kits that slot together without too much customization. I find these small tasks take considerable time for me to implement (five hours thinking about it before the 30 minutes of actual labor). All fun but I need to stay on track to get the job done.
TOSSPilot is offline Find More Posts by TOSSPilot
Old Feb 11, 2013, 11:09 AM
So. Cal
Joined Jan 2005
Based on Marks suggestion of adding strength to the top spar only -
Is it correct to assume that the top spar cap is the weaker component due to compression vs. tension and therefore, if I wanted to do less work but add some strength to the wing, I could just add the carbon tape to the top spar and skip on the bottom?
Or do you really need to do both, even though the bottom cap is using lighter carbon tape? Not sure how much the disparity between the two creates problems.
Or use the solid carbon rod on the top and use bass wood on the bottom? Then, the extra weight is only maybe an 1 once. Does this bring the structure back into balance in some way?
Old Feb 11, 2013, 11:48 AM
LVsoaring is online now
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
If your goal is to save time and money, and the way to do it is by adding carbon to only one side, then most definately add it to the top.
LVsoaring is online now Find More Posts by LVsoaring
Old Feb 11, 2013, 03:45 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
Because fibrous materials have roughly twice the tensile strength that they have in compression, I modified a lot of my models in the '70s by doubling the top spar cap in thickness... They were a lot stronger and the weight penalty, especially when tapered toward the tip... wasn't much.
My biggest problem of late is not spar strength, but flutter resistance... and my heavy winch-pedal foot...
Darth Carbon Lover...
schrederman is offline Find More Posts by schrederman
Old Feb 11, 2013, 04:05 PM
markdrela is offline
Find More Posts by markdrela
Cambridge, MA USA
Joined May 2001
One 1/8 x 3/8 x 48 bass sparcap weighs about 18g. The same size in carbon will weigh 60g, which is a lot of added weight and also insane overkill. The Mirage wing would shred in many other ways before that sparcap would fail.
You can add a 0.014" carbon strip instead, but that's prone to delaminations, and will require making the spar notches deeper.
Adding the 1/8" square doublers will double the wing's bending strength with a minimum of fuss, and you can still use wood glue for everything. The 1/4" shear web on the Isthmus Models kit should be just barely adequate for the doubled load, since the original Mirage had a 1/8" shear web.
Extending the sparcap notches in a handful of ribs is pretty easy, and it doesn't have to be precise -- two quick cuts with an X-acto will do it. Easier than deepening all the notches for the alternative carbon strip.
markdrela is offline Find More Posts by markdrela
Old Feb 11, 2013, 04:09 PM
Cambridge, MA USA
Joined May 2001
Roughly doubling the sparcaps' bending strength is all that's reasonable IMO, because the rest of the wing won't be able to take much more than that. So making the spar even stronger is in effect adding dead weight.
Old Feb 11, 2013, 04:16 PM
Cambridge, MA USA
Joined May 2001
On the Mirage, flutter resistance is obtained by using a stiff covering like regular Monokote on the center panel to give it torsional stiffness.
It's OK to use Ultracote-Lite on the tips, but be sure to scallop the trailing edges if you do so. Light trailing edges = increased flutter resistance.
Lighter tips also reduce yaw inertia which improves handling. On a RES glider you cannot make the tips light enough.
Old Feb 11, 2013, 10:02 PM
Joined Nov 2002
I agree that tip weight is a definite handling problem. I read once that you recommend glassing balsa D-tubes on a bias on the Bubble Dancer, for flutter resistance. Just the center panel or the entire wing? Also what weight glass. cf, or Kevlar would you recommend?
Sorry for somewhat hijacking the thread...
Darth Carbonator...
Old Feb 12, 2013, 12:22 AM
So. Cal
Joined Jan 2005
Mark:
Thank you for the follow up and bringing reaffirming the ease of installing the bass spar cap doublers. After considering the overall design and the intented use of the plane, it makes sense to be modest with this modification. So, I will give it a try.
I had debated about doing the scallop trailing edge and whether it added much weight savings but had not considered other benefits regarding flutter. Good to know this step is worth the effort.
Craig
Old Feb 12, 2013, 12:36 AM
So. Cal
Joined Jan 2005
Darth Carbonator...
Good next topic since it came up. Hijack away
On the same topic, what about diagonal cross braces in the bays behind the spar? How much benefit does this provide vs. the added weight?
Old Feb 12, 2013, 09:31 AM
Cambridge, MA USA
Joined May 2001
Mostly pointless.
One way to make the Mirage wing mostly flutter-proof is to add a D-tube to the center panel out of light 1/16" balsa. The upper part needs to be faceted to preserve the turbulation effect of the stringers. The bottom can be curved as usual. Most of the added work is to remove 1/16" from all the center rib outlines ahead of the spar to make room for the sheeting. But all the ribs are the same, so all the ribs can be modified in one stack. The 1/8" square bass stringers are replaced by 1/16" x 1/8" very hard balsa stringers. The faceted D-tube is made by installing flat balsa "planks" which are butted over the stringers. You start at the spar and go forward. Then trim the overhang from the LE, and finally install the LE strip. This is actually easier than installing one curved D-tube sheet in one piece.
This mod adds essentially no weight, because the basswood stringers go away, and you can also now use a very light covering for the center panel rather than Monokote.
Old Feb 12, 2013, 09:37 AM
Cambridge, MA USA
Joined May 2001
Darth Carbonator...
Glassing just the center panel D-tube with 0.75oz bias glass should be sufficient for most RES ships which have 1/16" sheeting. This will make a better match to a very strong spar with carbon.
But the BD has 3/32" 8-10lb (firm) balsa sheeting on the center panel, and really doesn't need this glass for flutter resistance. It may be good for insurance to suppress splits in the D-tube sheeting from landing dorks. Such splits do degrade the torsional stiffness quite a bit.
Question Carbon reinforcement for Woody Wing Spar Niko03 Thermal 15 Jan 08, 2013 11:42 AM
Discussion Carbon fiber spars/? methods of fabricating Stan_in_AR The Builders Workshop 1 Dec 19, 2007 02:02 PM
Discussion Moth Spar Cap - Alternative Method jtoro Slope 21 Mar 21, 2006 03:29 PM
Carbon Fiber/Spruce Spar Cap Construction Questions Joe Minton Sailplane Talk 1 Nov 10, 2003 08:53 AM
[B]Carbon Fiber/Spruce Spar Cap Construction Questions [/B] Joe Minton Sailplane Talk 2 Nov 10, 2003 07:50 AM
